#15 |
Too much fun - spend way more than i budget for gas each month because i go on cruises at night for "fun".
#16 |
Drives: 2003 S2000, 2008 Fit
FYI... If you're anywhere that uses road salt, less than one year and you will have a nice coating of rust under your car on damn near everything... But if you're OK with rattles and creaks, I think you'll be fine with whatever this car can dish out. You will need a low profile jack if you change your own tires
Sent from my SGH-I747M using Tapatalk |
#17 | |
| The Following User Says Thank You to raven1231 For This Useful Post: | Tcoat (09-29-2014) |
#18 | |
#19 | |
Is there any way to fix this rust issue underneath? I used krown rust protection last year, and when changing my exhaust i still noticed tons of rust (couldn't get my old exhaust off without a torch!) Is this bad for the car? The salt here is ridiculous but it's my DD |
#20 |
Drives: 17 Alfa Romeo 4C
25000 miles and NO issues with my stock FR-S. PROS: 7400 redline, light agile handling, perfect neutral seating position and great MPG for DD. Cons: torque dip although I've read that a tune can eliminate this. Build quality is questionable although this is what you get for a light weight car that costs 25K. Chirping has never bothered me.
#21 | |
No rice, no life
Drives: 2013 Asphalt FR-S
Here's the estimate for my turbo build back when I was talking with the shop. Hopefully they don't mind me posting this. I censored the individual prices but everything should have been roughly street price or MSRP. This should give you an idea of all the random stuff you will need. (Of course, if there is a problem, feel free to PM me and I'll take it down) ![]() As you can see, things add up. This build would have gotten me around 290-310hp. Yes, there are cheaper equivalents for many of these parts, but I'd rather spend the extra money up front so I don't have to worry about it catching up to me later on. Also, when I was speaking with other turbo owners, it seemed like $10k was generally what they all paid for their builds. All in all, this would have increased the money spent on the car to $35k, then my wheels/suspension and catback which bring it up to about $40k. And if we're talking $40k cars here, may as well get an Evo with a $300 flash tune
#22 |
Drives: 2008 Cobalt, soon to add an FR-S
I would never pay a shop to install anything... Most of your money would have went towards labor. Also, I know how to shop for parts, and going to a shop directly is not the way to go when you're trying to find deals
#23 | |
hmmmm.........maybe THAT is what happened to your Cobalt ....... ![]() Hi BankerBait ..... jest ah messen wich ya ..... ![]() humfrz |
#24 |
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
My pros and cons
PROS Amazing driver position Great lightweight chassis Good looks Easy to mod and work on Nice interior (Australian Toyota model has awesome seats) Good transmission Big boot (trunk) for a small sportscar CONS Cheap easily scratched interior plastics Torque dip (Fixed with header and tune) Rear seats are pointless |
| The Following User Says Thank You to Wise For This Useful Post: | Tcoat (10-01-2014) |
#25 | |
Besides loads of fun when you tell your 6'7" buddy to ride back there! Last edited by Tcoat; 10-01-2014 at 08:30 AM. |
| The Following User Says Thank You to Tcoat For This Useful Post: | Wise (10-01-2014) |
#26 |
Drives: 2018 BMW M240i
Rear seats are not pointless. I have 3 teenage boys varying in height from 5' 10 to 6' 1 and all but the 6 1' can and do get in the back seats.
Is it the most roomy and comfy ride? Hell no. Does it work? Hell yes. Cons for me: Not typical toyota fit and finish quality. No one major thing but tons of little things.
Torque dip Transmission not smooth - grinds and/or shifts hard when cold, shifting into gears quickly at high rpms Not listing it as a con because I knew this when I bought it but I do, at times, wish it had more power. |
#27 |
Drives: 2015 FR-S Ultramarine Metallic
Biggest con I have is that it sits low to the ground and I am 6'4" so need the door to swing fully open to get out and in. Fit inside fine but getting out with a close parked car is a pita. I have pushed it back a few times to get in.
#28 | |
Drives: 2015 FR-S (Halo)
On topic: Rear seats are fine. The car isn't a 4 seater, it's a 2+2. All 2+2s are the same. My 6' friends sit in back all the time. It's not a hummer but whatever. It makes for good cargo space as it's about 3x taller than the trunk. HPFP issue is an issue with a huge amount of HPFPs in general. Nothing they can really do. my 2015 has crickets too. If you can find non ethanol gas, great. Stock exhaust is awful and the fact that the trunk's valet button is in a perfect position to be pressed daily by cargo are the two things I hate most. Sent from my HTC One_M8 using Tapatalk
| Cons to a lowered weight pulley set? | WallsAndFoundations | Engine, Exhaust, Transmission | 139 | 03-23-2015 03:15 PM |
| Colour options - pros & cons | Sanzie99 | Scion FR-S / Toyota 86 GT86 General Forum | 44 | 07-03-2014 12:07 AM |
| KW V3's pros & cons | Shaolin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 22 | 02-25-2014 09:58 AM |
| cons of mushroom filter? | ft86me | Forced Induction | 13 | 10-22-2013 02:37 AM |
| cons of buying online? | chickdigger802 | BRZ First-Gen (2012+) — General Topics | 35 | 09-03-2013 10:42 PM |
