CANADA Canada
Old 09-16-2014, 03:54 PM   #169
jvincent
jvincent's Avatar
I had a chance to look at the video with your comments.
Originally Posted by Slick View Post
T5 - Given your great entry onto Rocky Road I was expecting to see you hit 170. So you could brake later and I'd probably stay in 4th instead of shifting into 5th. That way it is only 1 gear down for the turn, or go straight from 5th to 3rd if you can do that.
I thought I was high enough RPM that the shift wouldn't cost me, but it did. I usually just ride it to the redline in 4th. I did go straight from 5th to 3rd. The gear calculator in HLT thought I was in 4 for a bit.
T8 - I would try the tight line into Temptation as it suits our cars very well. That means brake and then turn in against the first curbing, then out to 1/4, 1/2 track, then back in 1/4, then apex. Don't be afraid to let the car run out wide close to that curbing on right, as it will be less steering input and smoother for throttle application.
Ahh, Temptation. I tried the tight line on some other laps. I'll check to see if I went through there faster. A nice feature of HLT is that you can see the time gained/lost vs a reference lap and can zoom in to the exact location on the track.
T15 - Shift early before turn-in to 4th. You're only full throttle for a sec before apex, where it should be opposite. Turn-in, maintenance throttle to position the car to grab the apex and then full throttle down the hill from that point because you need to plant the rear of the car down. At the 2:21 time in your video you should have your foot to the floor until 2:25.
Got it. Not sure what I was thinking there. I usually take that corner in 4th.
T17 - Stay right edge (don't go out to left like many do) on entry. You can then brake hard in a straight line and even if you go too deep, there is still more track ahead (if you enter from left and go deep, there is nowhere to go as you are already on the edge). You'll see that the grass is worn away on the right at entry, this is the apex.
T18 - Do not apex the middle of 18 but go left with tires at the curb of pit entry. This will give you the best approach to 19 and 20.
Got it. I was trying a wider line to see if it helped with 18, but as you pointed out I ended up apexing 18 early.
Front straight - not sure if you were backing off after this hard lap, but you are only at full throttle at beginning of straight, then you tend to lift partway through. You will gain the most by maximizing the amount of time you stay on-throttle at the highest speeds.
I think there was somebody catching up to me, so I started to slow down so he could get by in the next straight since I had just had a clean lap.
Great vid, love the Harry's timer with data overlay. Seeing your gearing and throttle position really helped me analyze.
Hope this helps!
Thanks again for the help.
I didn't use the video the first time out, but now that I have been recording my laps I find it really helps because I can see where I'm making mistakes and which corners I am more consistent on.
I really wasn't expecting to gain any time on Sunday since I was out with my daughter for fun but since I ended up being much smoother through the turns my overall time was much better. Go figure.
Old 09-16-2014, 03:59 PM   #170
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Yeah, there's another 5 secs in there easily. Will try to hop in with you at MCO, are you cleared to Solo?
Slick is offline   Reply With Quote
Old 09-16-2014, 04:29 PM   #171
jvincent
jvincent's Avatar
That would be great if you could. I'm not cleared for solo yet by the MCO, but I'm not sure how it works for riding with instructors.
Old 09-22-2014, 10:19 AM   #172
Slick
Slick's Avatar
Helmet cam vid from yesterday's MCO track day, at 10am.
Was a Twins/Miata fun wet session!
[ame]http://youtu.be/qINd-21PejI[/ame]
1:50 grey BRZ
4:10 Kenny gives me the "finger" point-by
4:50 "unidentified Black FRS" - lol
5:10 Black Miata and a "moment"
5:50 Black 3 series
7:10 Red Miata
7:50 Green Miata
9:30 Boss Mustang and Prelude
11:00 Blue Civic
11:30 Audi TT
14:50 Black S2000
18:30 Grey BRZ
Old 09-29-2014, 01:20 PM   #173
ManimillioN
Drives: Toyota Echo
For those who go to CMP, here is a Civic doing 2:26s and a 2:25
Sorry for the non-frs content. At least I'm contributing by posting :P
[ame="http://www.youtube.com/watch?v=Y_L_qypKU1k"]Civic EG Shakedown - Calabogie Motorsports Park - YouTube[/ame]
ManimillioN is offline   Reply With Quote
The Following 2 Users Say Thank You to ManimillioN For This Useful Post:
normancw (09-29-2014), Slick (09-29-2014)
Old 09-29-2014, 01:40 PM   #174
Slick
Slick's Avatar
Nice driving Mani.
What kinda power is that thing putting out?
I'm guessing weight is under 2000 lbs? (looks semi-stripped but I don't see a cage)
Old 09-29-2014, 05:50 PM   #175
ManimillioN
Drives: Toyota Echo
Nice driving Mani.
Thanks Andre.
It isn't under 2000lbs for sure, I think the owner said about 2200 ? It is a fairly mildly built car, has a lot more room to go.
I would have preferred a fwd car to be more tail happy than this one, but for its current owner, this is a safe setup for him to learn on.
It is making 223whp, but the tune is very rough on it, you can hear it in the video that it crackles even under WOT at points, let alone part throttle. It is quick, but nothing crazy, the chassis feels great. I was actually very very surprised how great it was. Definitely have a different outlook of the Civic's now.
The Following User Says Thank You to ManimillioN For This Useful Post:
normancw (09-30-2014)
Old 10-03-2014, 10:36 AM   #176
ManimillioN
Drives: Toyota Echo
Saturday October 4, 2014 and Sunday October 5, 2014
Old 10-05-2014, 06:57 PM   #177
jvincent
jvincent's Avatar
Beautiful day at Calabogie today. Temperature was not too hot and not too cold. It was nice and sunny too.
There weren't very many cars out today so it was really easy to get clean laps where you didn't need to pass or let anyone by. That said, there were some nice cars out. Several Porsches and GT-R to name a couple.
Managed to cut almost 3.5 seconds off my previous best time! Now at 2:43.6. Also hit a new top speed mark, 173.7 kph.
Thanks again @Slick for the advice, it certainly helped.
Since I wasn't sure if I would go today I didn't swap in the track pads. It made for a couple of interesting moments braking into turn 6 after a hot lap when the OEM pads started fading out pretty seriously. I knew it might be an issue so I was keeping an eye out for it, but I didn't expect to be as sudden as it was. Last time on OEM pads for me unless we are going to be running in the rain.
The Following User Says Thank You to jvincent For This Useful Post:
FRSToyota86 (10-06-2014)
Old 10-05-2014, 07:09 PM   #178
CarGuy
Track Rat
CarGuy's Avatar
Drives: '14 Subaru BRZ
Great afternoon on the track for sure! Was great to run with you out there today. The air was cool and dense and helped everyone make more power. I was at least 2 kph faster at the end of Rocky Road because of it. You'll be knocking that lap time down no problem with better pads and tires next season.
CarGuy
'12 BMW 128i (daily driver)
'14 Subaru BRZ (track car)
Racing is life. Anything before or after is just waiting. - Steve McQueen
CarGuy is offline   Reply With Quote
Old 10-05-2014, 07:29 PM   #179
jvincent
jvincent's Avatar
Good to see you (and Norm) out as well.
See everyone next season.
Old 10-05-2014, 08:49 PM   #180
normancw
normancw's Avatar
Drives: 128i
It was a beautiful day. It was great being able to just show up without having to register. It would have been a bummer to register for yesterday with the rain. Hopefully they will have the same on Saturday Oct 18 and Sunday Oct 19.
I noticed a bit more power too - my top speed was 2.7 kph faster. I had a best lap of 2:32.2
normancw is offline   Reply With Quote
Old 10-05-2014, 09:23 PM   #181
jvincent
jvincent's Avatar
Just looked at some of the log data. I actually got up to 174.6 on one of my fast laps but lost time in other places.
Definitely more powah in the cool air.
Old 10-06-2014, 12:21 AM   #182
normancw
normancw's Avatar
Drives: 128i
[ame="http://youtu.be/U6AGdD7j6c4"]http://youtu.be/U6AGdD7j6c4[/ame]
The Following 2 Users Say Thank You to normancw For This Useful Post:
FRSToyota86 (03-15-2015), Slick (10-06-2014)
First 3 Days of the FR-S (Deer On Road) kanundrum Scion FR-S / Toyota 86 GT86 General Forum 31 06-30-2012 02:02 AM
Insurance for track days? Hanakuso Tracking / Autocross / HPDE / Drifting 24 06-25-2012 08:19 AM
6 Days to go.............. Neilus AUSTRALIA 51 06-03-2012 03:24 AM
SCCA and Track days Primo86 NY / NJ / CT / PA 4 06-01-2012 07:07 PM
A little bit disappointed in these three days dodof Scion FR-S / Toyota 86 GT86 General Forum 49 11-30-2011 02:18 PM
