Old 09-27-2014, 06:22 PM   #267
steve99
Drives: FT86
Originally Posted by subaruferrucci View Post
Is there a away to make it so we dont have to switch between the New def files and the original def files?
Its all to account for calid modifications, must always use matching definitions.
Always open rom and check some tables to see all looks ok as per first post
Old 09-29-2014, 01:23 AM   #268
tech86
Drives: 86 GTS
Had some strange behaviour with a hard rev cut in 5th gear over 6000 rpm and then a couple times in 4th. It basically felt identical to the stock redline hard cut.
Anyone seen that with the E85 OFT tunes? Using United E85 (107 Octane)
http://www.datazap.me/u/tech86/oft-stg2-el-e85-map
http://www.datazap.me/u/tech86/oft-stg2-el-e85-map-0
tech86 is offline   Reply With Quote
Old 09-29-2014, 03:56 AM   #269
steve99
Drives: FT86
are you manual or auto as the auto roms do not have soft rpm limit only manuals.
fuel trims and afr look a bit ordinary afr bit rich top end for e85 11.6 from memory olfuel table was 12.2 , probably worth doing maf scale next time your on petrol or transfer the maf scale from a v2 petrol tune to the e85 tune i am pretty sure nothing was done to e85 tunes from V 1.5 to v2 so it still got the rich anf safe maf scaling.
Old 09-29-2014, 06:40 PM   #270
tech86
Drives: 86 GTS
Manual but it is a bit rich, no arguments there.
There is almost nothing different between the v1.59 and v2.061 OFT Stg2 EL A01G maps, 3 tables in total (none related to fuel or MAF) and a CAT DTC which I though was strange.
Am I taking the MAF scale from a v2.061 stg1 or stg2 petrol tune? They both look slightly different to the E85 one.
Old 09-29-2014, 07:03 PM   #271
steve99
Drives: FT86
The stage2 maf scaling is much better the stage1 maf scale apears to be jacked up about 10% to make eveythig run rich.
if yu transfer the stage2 petrol maf scale to e85 tune check afr and knock but that scale is much better even better if you do your own.
with that weird rpm limit make sure you have the flat foot shift delta set to zero as it can sometimes cut in if you rest yur fot an clutch as it works off cutch switch
Old 09-29-2014, 07:30 PM   #272
tech86
Drives: 86 GTS
I'll give that a try before going back to factory tune on 98 and scaling it myself.
Definitely wasn't touching the clutch pedal but I don't see FF/LC in RR. Are they defined for A01G?
Old 09-29-2014, 08:27 PM   #273
steve99
Drives: FT86
yu have to use oft defs as its a patch to rom code
tech86 (09-29-2014)
Old 10-03-2014, 07:58 AM   #274
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Anyone who's download the OFT specific Ecuflash definition - please re-download - I have made some updates to the definitions.
Td-d is offline   Reply With Quote
The Following 2 Users Say Thank You to Td-d For This Useful Post:
B-R-Z (10-03-2014), XCO (10-03-2014)
Old 10-03-2014, 10:29 AM   #275
XCO
Drives: GT86
do you also have an updated A01J ecuflash def? i noticed in your updated RR def that included the MAF correction after start table, the FFS and LC tables are missing.
TIA
XCO is offline   Reply With Quote
Old 10-03-2014, 03:01 PM   #276
Td-d
I don't include the LC and the FFS because they are proprietary code - what you can do is open up the RR definitions that are on the OFT site, and copy the LC and FFS code into the xml. Pretty straightforward, give a shout if you struggle.
The Following User Says Thank You to Td-d For This Useful Post:
XCO (10-03-2014)
Old 10-04-2014, 10:47 AM   #277
Td-d
ZA1JD00D (2015 USDM AT) definition is up: http://www.romraider.com/forum/posti...mode=post&f=34
steve99 (10-04-2014)
Old 10-04-2014, 05:17 PM   #278
steve99
Drives: FT86
any chance you could email me that rom
Old 10-04-2014, 05:45 PM   #279
Td-d
Sure, no problem.
Old 10-04-2014, 06:33 PM   #280
MFB
Avo Turboworld Phil Rep
Drives: Forester 2009 XT on e85
@XCO, use notepad plus. That's easy to work with using XML
MFB is offline   Reply With Quote
The Following User Says Thank You to MFB For This Useful Post:
XCO (10-05-2014)
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 12:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 10:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 08:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 10:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 07:27 AM
