Old 09-28-2014, 08:15 PM   #1
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
No crank no start issue
So I got my car back from the dealer after I spun a rod on cylinder 3. Warranty replaced my engine with a new one no questions asked. Drove it today, washed my car, took it for a drive finally after the wash and car just died on me, popped the clutch and nothing.
So I try starting the vehicle and doesn't even crank over. Feels like a dead alternator, starter charging issue. Everything works, I even jump started and nothing. Checked all the grounds, connections, fuses. On the fuses it did have a popped EFI(CTL), replaced it and pops right after I put the key foward. I had my car in the shop for 2 weeks, kind of sucks to take it back but if I need to I will.
I just want to see if anyone has had this issue. I already googled and search around.
When I get home I will try the second key, maybe anti theft kicked in and disabled everything and for some weird reason it de-programmed the key.
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 09-28-2014, 08:42 PM   #2
Dude how hard did you search?
The post immediately before this was the same issue!!!! http://www.ft86club.com/forums/showthread.php?t=30517
Dead short someplace. Take it back they likely did it.
Old 09-28-2014, 09:07 PM   #3
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
I just google searched lol.
Muchos thank you bro. Appreciate it. I know what to do when I get home. Thanks
The Following User Says Thank You to *KID* For This Useful Post:
Tcoat (09-28-2014)
Old 09-29-2014, 07:22 AM   #4
steve99
Drives: FT86
what you found is one cause another similar fault was shorted coil pack, sometimes coil pack shows signs of overheating/melting
Car won't start - doesn't try to crank at all, but lights are working HELP cdo221 Issues | Warranty | Recalls / TSB 28 06-06-2018 07:30 PM
Unichip issue - cannot start car 355rockit Software Tuning 18 05-29-2014 05:38 PM
I can reproduce the struggle-to-start issue chenshuo Issues | Warranty | Recalls / TSB 19 04-17-2013 03:42 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 03:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 04:44 AM
