Old 04-27-2012, 05:07 PM   #43
OrbitalEllipses
Drives: Attitude
Backing plates of the pads grinding through the rotors.
Those don't appear to be differential bore calipers.. ie not STI calipers.
They probably are; the outer bore shapes are not different, only the interior piston bore is different. I just packaged my calipers up so I can't take a look at them, but I'm pretty sure the outer shape isn't different from forward to trailing piston.
Old 04-27-2012, 08:45 PM   #44
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Good call
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-30-2012, 06:12 PM   #45
86knecht
Drives: 2003 BMW 325i
Couldn't you keep the brake calipers on the same side and take the rotor off with the caliper, hold it up right and bleed one caliper at a time?
Its a little more work but would be worth it if does the trick
86knecht is offline   Reply With Quote
Old 04-30-2012, 07:37 PM   #46
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
It would be entertaining to watch someone deal with holding the rotor, caliper and wrench to open and close the bleeder.
I would never bother as the STI fronts don't address the backs. I like balanced upgrades and would prefer an engineered system that addresses all concerns and just does the one thing larger brakes are usually needed to do (hold more heat).
Most people want fixed calipers, especially with brand names painted on them for appearance, not performance. As long as people can be honest with themselves and understand that they are dumping a lot of cash on an appearance wear item which, at best, won't help performance and at worse will reduce performance then I'm all for it.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-30-2012, 09:02 PM   #47
86knecht
I think the stock brakes would work well with the power that is given.
SS lines and a good pad with some high temp fluid would be perfect for the everyday track guy.
Some people would be amazed at what a race pad could do
Old 01-13-2014, 04:56 PM   #48
cammaxon
Drives: 13 BRZ LTD
Will the Sti Brembos work with the factory wheels? I have a set of 18s for the summer but I want to continue to use my factory wheels for winter.
cammaxon is offline   Reply With Quote
Old 01-13-2014, 05:20 PM   #49
Vten
Drives: Too heavy
You need a spacer , at least 15mm to clear out , I'm not sure about the rear , but I would do at least 20mm if you do that 15mm front to even out the look ...IMO
Vten is offline   Reply With Quote
Old 01-13-2014, 05:27 PM   #50
OrbitalEllipses
Drives: Attitude
Corret @Vten. There's too much interference from the spokes of the stock wheels I measured at least 15mm when I test fit Brembos some time ago.
@cammaxon you would not be able to run stock wheels in winter with STI Brembos.
Old 01-13-2014, 06:04 PM   #51
cammaxon
Drives: 13 BRZ LTD
Am I reading that if I use spacers front and rear, that I would be able to use brembos and oem wheels?
Old 04-12-2014, 02:25 PM   #52
cammaxon
Drives: 13 BRZ LTD
Finally got around to doing this mod, it was REALLY easy.
Those Brembos, fixed caliper? Or not? [Patent inside!] madfast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 155 12-08-2011 02:06 PM
