Old 05-26-2014, 07:58 AM   #15
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Originally Posted by 1Cor10:23 View Post
Was able to get -1.26 on each side. Shop said doubling up could get 1.5+ for sure. I'll run it as is for now since I'm only really doing it for closer to even wear at the track. Likely coils for next season.
That's decent enough. And I'm assuming you aren't rubbing at full lock? I have 17x8 +48 in the front, and based on your 17x9 + 35 up front, it appears I can fit 235's if you can fit 245's
drewbot is offline   Reply With Quote
Old 05-26-2014, 09:07 AM   #16
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
I'd double check that with others...the offset might be tight? + know that +45 RPF1's barely fit stock and people typically coil it. It's fairly well documented that 17x9+35 clears stock, lots of posts in the 17x9+35 RPF1 thread.
1Cor10:23 is offline   Reply With Quote
Old 05-26-2014, 09:19 AM   #17
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Yeah I think I did. Not to hijack your thread, but you can use this website to check fitment against a known fitment: http://www.willtheyfit.com/index.php...et2=48#content
The Following User Says Thank You to drewbot For This Useful Post:
1Cor10:23 (05-26-2014)
Old 09-26-2014, 09:52 PM   #18
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
@1Cor10:23
Just ordered Raceseng plates too. Did you DIY or get it installed elsewhere?
Sent from my OnePlus One
Old 09-27-2014, 03:07 PM   #19
1Cor10:23
1Cor10:23's Avatar
@1Cor10:23
I got them installed at a shop, need to do alignment afterward anyway.
The Following User Says Thank You to 1Cor10:23 For This Useful Post:
drewbot (09-27-2014)
Old 10-02-2014, 08:21 PM   #20
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
Great name! Good luck with the build. I started one also... @drifting4jesus build
Ryaquinn is offline   Reply With Quote
The Following User Says Thank You to Ryaquinn For This Useful Post:
1Cor10:23 (10-02-2014)
Old 12-22-2014, 03:56 PM   #21
1Cor10:23
1Cor10:23's Avatar
Ohlins R&T install - coming Spring 2015!
Old 12-22-2014, 03:57 PM   #22
1Cor10:23
1Cor10:23's Avatar
Mishimoto thermostatic oil cooler install - coming Spring 2015!
Old 10-28-2015, 09:03 PM   #23
1Cor10:23
1Cor10:23's Avatar
Bumpidy - going to actually keep this up to date for next season...
Old 01-18-2016, 11:13 PM   #24
ottoyu34
ottoyu34's Avatar
Drives: Mazda3
Build looking sick, any bracing planned?
Hope to meet you soon.
ottoyu34 is offline   Reply With Quote
Old 03-19-2017, 06:16 AM   #25
BoWScotland
Drives: Toyota GT86 Auto - Hot Lava
Hi
Could i ask how (what hardware and software) you used to generate the track diagram, car position, speed etc in (the bottom left hand corner) of your great YouTube video of 'September, 2014 - Open Lapping @ TMP - 126.1'
Thanks very much indeed
BoWScotland is offline   Reply With Quote
Old 02-20-2018, 02:46 PM   #26
1Cor10:23
1Cor10:23's Avatar
Originally Posted by BoWScotland View Post
Hi
Sorry for the late reply! It's Harry's lap timer (available on android or iOS).
Function and Form Type II Kosmos Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 03-13-2016 10:48 PM
ModBargains.com | Avant Garde Form & Function - Which is your Favorite? ModBargains.com Wheels and Tires 8 12-21-2013 03:36 AM
FS: SOCAL: Function and Form coilovers barely used mr. slim Brakes, Suspension, Chassis 7 05-16-2013 10:32 PM
Form > Function SportInjected BRZ First-Gen (2012+) — General Topics 359 04-24-2013 04:20 PM
Roofline: Form over function. ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 15 04-24-2011 12:27 AM
