Old 09-25-2014, 01:26 AM   #15
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Just curious, are the gains shown on the dyno typical of what people would get with a nameless header + tune?
Fizz is offline   Reply With Quote
Old 09-25-2014, 02:51 AM   #16
M23
Drives: 86
Wow. Those cliffs look 1000x steeper than pikes peak. Not to mention much narrower and much more big boulders and rocks that are very close to the road. This makes pikes peak look like disneyland. Amazing.
M23 is offline   Reply With Quote
The Following User Says Thank You to M23 For This Useful Post:
Circuit Motorsports (09-27-2014)
Old 09-25-2014, 11:45 AM   #17
Weasel Soup
Veteran RallyCrosser
Weasel Soup's Avatar
Drives: 10 Series FR-S, 95 Escort Rally Car
Originally Posted by Circuit Motorsports View Post
A few more photos from today's racing:
Besides the extra ride height it looks like they trimmed off the lower portion of the rear bumper behind the rear wheels. Which is probably a good idea; this past weekend I had a co-driver at a RallyCross and he attempted to remove part of the rear bumper by tagging a berm with it.
Everything should be attempted twice. Once to satisfy curiosity, and the second time to see if you like it.
My Journal
2016 SCCA RallyCross National Champion - Prepared Rear Wheel Drive
Weasel Soup is offline   Reply With Quote
Old 09-25-2014, 02:00 PM   #18
xwd
They look like BOS dampers maybe, they are one of the few I'm aware of where the hose connects at the top. $$$$
http://www.bos-engineering.com
For instance here is a set off an Impreza rally car:
Old 09-26-2014, 10:30 AM   #19
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
Originally Posted by gramicci101 View Post
That thing is astonishing. Do you know what suspension is on it? I saw the external reservoirs in the engine bay.
The car runs a Barattec suspension, made in Argentina. This suspension is produced by Team Barattero, a rally racing developer.
- Bob
Circuit Motorsports is offline   Reply With Quote
The Following User Says Thank You to Circuit Motorsports For This Useful Post:
gramicci101 (09-26-2014)
Old 09-27-2014, 12:03 PM   #20
Circuit Motorsports
I really don't have enough data on the nameless header to declare these results typical. The Nameless Performance dyno charts do show massive torque gains in the same area and seem to support the results.
The exhaust on the rally car is not typical of a street driven car in that the exhaust is only the header with a straight pipe -- nearly 0 restrictions. As restrictions in the exhaust are added, I would expect the gains to reduce a bit, but I believe you can still expect a huge torque gain right in the stock torque dip area, and the torque/power gains and curves to be similar throughout the power band.
- Bob
GT86_PRAGUE (12-18-2014)
Old 09-27-2014, 12:25 PM   #21
Circuit Motorsports
Updated race standings, added additional photos and videos.
Check out the latest video - it's a hill climb stage on dirt/gravel that begins at 11,000ft. and climbs to 13,500ft.! Serious unprotected drop-offs everywhere!
- Bob
Old 09-27-2014, 09:20 PM   #22
YodrOne
Drives: 2013 Scion FRS
Thanks for sharing all of this amazing info and footage! Awesome to see the little beast do so well. Those cliffs are obscene. Talk about getting the blood pumping...
The speed was correct, it was the corner that was too tight.
YodrOne is offline   Reply With Quote
The Following User Says Thank You to YodrOne For This Useful Post:
Old 09-28-2014, 12:05 AM   #23
predator800
Drives: 2015 Scion FRS
Yes. Thank you for all the work you put into this thread. It was very enjoyable to follow.
predator800 is offline   Reply With Quote
The Following User Says Thank You to predator800 For This Useful Post:
Circuit Motorsports (09-29-2014)
Old 09-28-2014, 09:35 AM   #24
acro
Drives: GT-86
One question what grade oil is he running and does he use a oil cooler
acro is offline   Reply With Quote
The Following User Says Thank You to acro For This Useful Post:
YodrOne (09-28-2014)
Old 09-29-2014, 03:07 PM   #25
Circuit Motorsports
He ran this rally without an oil cooler, but an oil cooler was planned -- just ran out of time prepping for this rally. Fortunately, the outside temps were on the cool side.
These engines are pretty hard on oil, and that was a big concern knowing the car would be running @7000+ rpm for extended periods of time.
He is running Motul 300V 5w30, and has changed the oil after each race day.
- Bob
acro (09-29-2014)
Old 09-29-2014, 03:10 PM   #26
Circuit Motorsports
Final race results are posted in post #2: http://www.ft86club.com/forums/showp...96&postcount=2
Old 09-29-2014, 04:54 PM   #27
GirlRepellent
GirlRepellent's Avatar
Drives: Evo X FE/FRS 10 Series
Whoa. Thanks for sharing.
Why are you considering removing the Toda throttle body?
GirlRepellent is offline   Reply With Quote
The Following User Says Thank You to GirlRepellent For This Useful Post:
Old 09-29-2014, 10:46 PM   #28
Circuit Motorsports
The stock throttle body is plenty big for this motor. I believe the larger throttle body results in a reduction of throttle resolution with no power gain.
- Bob
GT86 CS-R3 Rally Car - pics and pricing announced mav1178 Tracking / Autocross / HPDE / Drifting 16 08-25-2014 03:31 PM
My photos from WRC Rally Finland 2014 rumors Other Vehicles & General Automotive Discussions 2 08-06-2014 06:33 PM
Toyota GT86 CS-R3 rally car update mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-02-2014 12:17 AM
Toyota announces GT86 CS-R3 rally car Whitigir Scion FR-S / Toyota 86 GT86 General Forum 9 11-20-2013 11:27 AM
BEST EVER Mitsubitshi Evo Rally POV Video. LS13 Off-Topic Lounge [WARNING: NO POLITICS] 1 08-20-2013 09:43 PM
