Old 09-23-2014, 11:07 PM   #85
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Originally Posted by diirk View Post
Did you cut the bottom out of it to get it to mount flush?
Yeah. Notched the control unit itself and then drilled some recesses that could slide the control unit into. No bracket needed, but requires some commitment lol
Jyn is offline   Reply With Quote
Old 09-23-2014, 11:22 PM   #86
diirk
diirk's Avatar
Drives: 4Runner
Any pics of the install or mods required?
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 09-25-2014, 12:55 AM   #87
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Originally Posted by Jyn View Post
Idk if you were mounting your controller still, but here's a little cell phone pic from my build thread (in my sig):
and the trunk setup. It's not really "show" yet - I'll revisit everything and hardline it probably next year. Just wanted to get a good idea of how everything would be layed out first.
This setup looks perfect.
Old 09-25-2014, 02:27 AM   #88
Jyn
Noob
Jyn's Avatar
Didn't take pics during the install, but I just listed the high level overview of "mods" you have to do - cut some notches in the controller, cut the bottom of the tray, and create some notches in the tray for the controller to slide into.
Thanks, it's a good start. Will revisit it next year to make it pure show. Unfortunately, the tank and compressors are hidden under the regular trunk floor.
The Following User Says Thank You to Jyn For This Useful Post:
diirk (09-25-2014)
Old 09-25-2014, 08:01 AM   #89
diirk
diirk's Avatar
Drives: 4Runner
Thanks for the update Jyn.
I'm laughing because the fact that it's all hidden under the regular trunk floor is my goal and it's an unfortunate side effect for you. But your setup looks good enough to run without the regular floor for shows. I'm hoping to get to work on it this weekend and come up with something similar.
diirk
Old 09-25-2014, 10:23 AM   #90
diirk
diirk's Avatar
Drives: 4Runner
Question
Originally Posted by zAnSh1n View Post
yea, 245 is too wide for the fronts, especially with that offset...
you obviously need to bring the front tires out more, but if you do that you will hit the fenders/side markers...
i'm running 18x8.5 +32 wrapped in 225/40/18 up front with -1.7 degree of camber...
my tires are ~0.5" away from my bags.
i'd get skinnier tires [225/45/17], but it will stretch due to your wide rims... you will also need to add spacers [5mm+] and run extended studs for safety reasons...
after that, you will have more room to play with and most likely not have to run any aggressive camber and deal with uneven tire wear...
use the tire calculator for a better analysis:
http://www.frsproject.com/tire_size.php
That calculator is awesome. I've spent WAY too much time on there...lol.
With that said, I'm torn between 225/45-17 and a 235/40-17 for the front with a 5mm spacer on the 17x9's.
Thoughts?
diirk
Old 09-25-2014, 11:19 AM   #91
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
it... really... doesn't matter, mang
Old 09-25-2014, 11:35 AM   #92
diirk
diirk's Avatar
Drives: 4Runner
Wow. That was less than helpful. Trying to bolster your post count?
diirk
Old 09-25-2014, 11:41 AM   #93
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
tell me, what exactly are you torn about... the moral dilemma of stealing bread to feed your hungry child?
the difference between a 225/45 and a 235/40 is nearly inconsequential considering that the rim is 9" wide! One size will look a bit more stretched than the other and that's it.
pick the size that won't rub and call it a day.
torn he says! good lord
Old 09-25-2014, 11:55 AM   #94
diirk
diirk's Avatar
Drives: 4Runner
My goodness. Settle down dude. The use of the word "torn" does not depict a moral dilemma. And honestly, stealing bread to feed my hungry child isn't a dilemma at all. Just saying.
The difference is about 3/4" in height and about 1/2" in width. The stretch involved will be part of determining whether the tire will rub on the bag.
SO the dilemma is if anyone has experience running these combinations in order to save me buying the wrong set of tires and having money left in my wallet to feed my hungry child.
The goal in asking is to determine which one won't rub while maintaining the widest possible tire with minimal stretch to reduce any potential issues while running on the track or canyons.
My appologies if my vocabulary offended you.
diirk
Old 09-25-2014, 12:00 PM   #95
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
do you have any particular reason for wanting a wider tire?
as the other user suggested, get the skinnier tire to avoid possible interference.
seems to me like you want to push the envelope, there's really no need to
Old 09-25-2014, 12:08 PM   #96
diirk
diirk's Avatar
Drives: 4Runner
Valid question.
The 225/45 is stretched on the 9" wheel. I just don't want to have to worry about it on the track. I've never run stretched tires. The 225/45 tire recommend a 7-8.5" wheel. The 235/40 is good for a 9" wheel.
Obviously, I could go to a narrower wheel, but I would prefer to save the money and run what I have if I can do so safely. If not, then I'll buy a 17x8 wheel and run a 225 or 235 on it. Oh, and I do like the concave look of the 9" wheel.
diirk
Old 09-25-2014, 12:29 PM   #97
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
what is the nature of your worry?
if this was a 205 or a 195 I'd raise an eyebrow... but a 225 (remember, mm, or aprox 8.6-8.8 inches) and a 45 (quite large) sidewall is by no means an issue for a 9" rim.
Old 09-25-2014, 12:36 PM   #98
diirk
diirk's Avatar
Drives: 4Runner
Well, that was the nature of my worry. That I would be at risk to roll the tire off the wheel.
diirk
Track Brake Pad Discussion Thread CSG David Tracking / Autocross / HPDE / Drifting 422 04-03-2025 10:13 PM
Anime Discussion Thread ERA Off-Topic Lounge [WARNING: NO POLITICS] 2698 02-14-2024 11:55 PM
Brake Pad Discussion Thread CSG David Suspension | Chassis | Brakes -- Sponsored by 949 Racing 36 06-26-2014 05:59 PM
Another Coilover discussion thread... nobody__ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 02-04-2014 10:49 AM
Forza 3 vs. GT5 Discussion Thread Snaps Off-Topic Lounge [WARNING: NO POLITICS] 386 03-06-2011 12:10 AM
