Old 09-24-2014, 09:13 AM   #1
Thunderleg
Thunderleg's Avatar
Drives: Black BRZ
can I run just back studded tires?
Last season I had the blizzacks and they worked wonderfully, but I had to throw out my back pair when I switched to my summer tires. Now that the season is about to start up I was thinking of putting my blizzacks on front and getting a pair of studded tires for the back. Will I run into any issues with this?
I plan to put my winter tires on only when I'm going to the mountain to snowboard, or when it is going to snows in the city.
Thunderleg is offline   Reply With Quote
Old 09-24-2014, 10:14 AM   #2
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
You won't have problems until you get into snow and ice.
You'll have rear traction, but no front traction for turning or stopping. Thanks for turning yourself into a missile.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
The Following User Says Thank You to deucethemoose For This Useful Post:
JohnJuan (09-24-2014)
Old 09-25-2014, 03:51 AM   #3
Thunderleg
Thunderleg's Avatar
Drives: Black BRZ
Did you actually read what I wrote, or did you just comment on my title? My first sentence stated that I had non studded tires all around last season and they worked wonderfully. So how would adding studs to the back degrade the efficiency of my front tires?
Old 09-25-2014, 04:18 AM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Yes you're fine.
Same concept as chains on drive wheels (RWD).
-alex
Thunderleg (09-25-2014)
Old 09-25-2014, 04:27 AM   #5
Thunderleg
Thunderleg's Avatar
Drives: Black BRZ
Originally Posted by mav1178 View Post
Yes you're fine.
-alex
Awesome, thanks bud! This will give me a lot more confidence getting into the mountains this year.
Old 09-25-2014, 04:34 AM   #6
Mikko
Drives: 2015 WRB BRZ
You would be fine but matched set is still much safer, here's a good video of mixed vs. matched tires.
[ame="http://www.youtube.com/watch?v=rzB7hpWhqIA#t"]Tire Rack Tire Test - Winter Tires: Mixed vs. Matched Tires - YouTube[/ame]
EDIT: Noticed you were going to use Blizzaks on front, much better choice than those all seasons used in the video.
Mikko is offline   Reply With Quote
The Following 2 Users Say Thank You to Mikko For This Useful Post:
JohnJuan (09-25-2014), Thunderleg (09-25-2014)
Old 09-25-2014, 09:18 AM   #7
wparsons
wparsons's Avatar
In a panic stop, EBFD might have a hissy fit with so much more grip in the rear than up front.
Can't say for sure without trying it out, but it *could* potentially be bad.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
JohnJuan (09-25-2014), Thunderleg (09-26-2014)
20/25mm studded wheel spacers spitfire481 Wheels and Tires 3 02-25-2014 09:38 PM
Does TPS system need to be re-taught when going back to summer tires? NOHOME Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 05-25-2013 12:35 AM
Possible trade? Nameless axle-back for Perrin Resonated Cat-back GTB/ZR-1 Engine, Exhaust, Bolt-Ons 0 03-26-2013 02:51 PM
FRS on studded, upsized iPikes Khyron686 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 10-21-2012 11:43 PM
