#2143 |
Drives: The silvertrooper 10 series
Local's BRZ we did, went for E85 couple weeks ago and finally brought the sheet by
#2144 | |
Drives: 2013 BRZ Premium Dark Gray Metallic
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1 DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time) DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler |
#2145 |
Thats the only number i personally want.. 300 WHP.. i never really had a goal. and i know ill hit it 300 and im really happy with that.. the 400hp was fun to drive, but at the top of the first 3 gears its useless all id does is spin his 255's.. ill run the e85 because of the safety reasons, and i asked them to make is extremely safe.. id rather give 25hp and know ill be safe then try and push the limits..
#2146 |
Drives: 2015 Series.Blue
PCV absolutely does not need a "valve," and I can name plenty of cars off the top of my head that don't run valves.
Regardless, it appears the twins do run one, but I haven't taken it apart myself to see. |
#2147 |
Crankcase ventilation (which I am assuming is what you are referring to) and PCV are not the same
#2148 |
Incorrect: http://www.autoshop101.com/forms/h63.pdf
Regardless, valveless setup works under boost as well if it's routed correctly (as Toyota did for decades) |
#2149 | |
I've got Radium catch cans so I'm assuming I need a 1/2" checkvalve somewhere in that line going to the crank? I know the other line goes to the intake manifold, but the other line should be the crank case where you don't want it to see boost? Just making sure I understand it right. and the direction of flow goes Crank case ---> Catch Can ----> Intake Manifold or the other way around? I'm pretty sure you don't have to touch anything on the PCV side of things after reading about some of the turbo guys setups. It's mainly preventing the crank case from being pressurized. |
#2150 |
NASA SpecE30 Racer
That is the way it is supposed to work as the vacuum produced in the intake manifold pulls the crankcase pressure out. The problem is that in a forced induction application not only does that vacuum go away under throttle, but you are now pressurizing the intake manifold which is then going to attempt to pressurize your crankcase reversing that flow without a check valve.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#2151 |
Professional Smartass
Drives: White Out FRS
Check valves are like $5. They should just be installed for piece of mind knowing you're not putting 10PSI into the crank case regardless if there is a valve stock or not. Herp derp it does it doesn't have one stock, just put one in and be done knowing that it has one since you put it in.
#2152 |
this is like the third time this thread has veered off into 'check valve catch can land'......can we get it back on topic which is the KW SC kit? lol
#2153 |
Drives: 2013 Asphalt FR-S
#2154 |
Drives: 2022 BRZ Limited
I've seen this video on @KraftWerks Facebook page, good explanation of the system
[ame="http://youtu.be/EIR8GZxcfZ4"]http://youtu.be/EIR8GZxcfZ4[/ame]
#2155 |
@glamcem
I've seen this video on @KraftWerks Facebook page, good explanation of the system I was just coming to post this.
#2156 | |
![]() Awesome - Shoot us an email on how much you love it
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
