Old 08-11-2014, 03:33 AM   #15
cywinr
Drives: DGM BRZ MT
lol it's not hard u just have to reach behind the front bumper and hold the back of the nut in place while u undo the bolt from the front
pop the hood and undo 5 bolts and 2 clips on the top of your front bumper
the piece of rubber that seals the gap between your front bumper and the hood comes right off
then you can reach in under the front bumper with a small pair of vicegrips to hold the back part of the bolt in place and undo the license plate bracket bolts from the front
cywinr is offline   Reply With Quote
Old 09-23-2014, 09:00 AM   #16
SubaruLifer
Drives: 2015 ISM BRZ Premium
Bumping this one up because I got my car from a dealer in NJ (front plates required, so car came with bracket installed) and live in PA (no front plate needed).
I removed the metal/rubber piece as cywinr suggested above, but I'd need hands/arms the width of a pencil to be able to reach behind and hold the rubber grommets in place.
For anyone that's taken it off, did you go from underneath or did it require removing the entire front bumper skin?
I realize I'm going to have 2 big ugly holes after it's off, but I'd rather have 2 plugged holes than that bracket.
SubaruLifer is offline   Reply With Quote
Old 09-23-2014, 01:44 PM   #17
immaculate
immaculate's Avatar
Drives: 2017 Audi S3
I think the easiest way is by removing the skid plate. My dealer did it for a half hour labor.
immaculate is offline   Reply With Quote
The Following User Says Thank You to immaculate For This Useful Post:
SubaruLifer (09-24-2014)
Old 09-24-2014, 09:31 AM   #18
SubaruLifer
Thanks! I'll put it off until my first oil change then.
Old 09-24-2014, 10:50 AM   #19
ShibaYuki
Drives: 2013 WRB Subaru BRZ Sport-tech
I went to the dealer, to ask them to remove it for me. Which they did. While I was there, they changed my oil too. =P
ShibaYuki is offline   Reply With Quote
Old 09-24-2014, 01:41 PM   #20
kberkel
kberkel's Avatar
I removed the bumper, and glad I did. Those rubber nuts put up a fight, and I eventually used pliers to just rip them off.
The bumper is very easy to remove IMO. Be sure to put a towel around the corners when you go to reinstall if you're by yourself.
The metal tabs like to dig into the fender. I got lucky and it didn't happen.
It's been 5 months and I still haven't covered the holes. I never notice, though I should plug them.
kberkel is offline   Reply With Quote
The Following User Says Thank You to kberkel For This Useful Post:
SubaruLifer (09-25-2014)
Old 05-07-2016, 12:45 PM   #21
WRBrzRX
Drives: runs&drives
You can actually just pop these guys out as the hole for the rubberized rivet behind the bumper is nearly as big as the rubber gasket that seals it.
I finally manned up today and said I was going to get the plate holder off come hell or high water and removed the top of the bumper as suggested above. It's no fun on the forearms once you're in..
As I tried to grip the rivet from behind to spin it from the front I learned it had a rubberized coating which disintegrates, preventing grip. I cut away at that with snips but never could grab it well enough to unscrew from the front, it spun.
Fuck it, I'll drill the heads out. Small bit first, pilot hole, big bit. Pull the plastic plate holder away from the bumper a bit to look behind it and pop, off it comes from the bolt heads. Huh, that was easy. Other side. Just bolt heads in but the hole is clearly drilled large. Pop them right out too.
Shouldn't have waited so long. Didn't need anything but 20 seconds and the confidence to pop everything out. Off to score a plastic repair kit with mesh and such.
WRBrzRX is offline   Reply With Quote
Old 05-08-2018, 10:19 AM   #22
alec_mccammack
alec_mccammack's Avatar
Drives: 14' Subaru BRZ
Take the Front Bumper off and use a pair of pliers on the rubber and unscrew from the front. Very simple
alec_mccammack
alec_mccammack is offline   Reply With Quote
Old 05-08-2018, 10:21 AM   #23
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Old 05-08-2018, 05:09 PM   #24
CPO 76
Drives: '17 BRZ Limited w/PP
Wow......it only took slightly less than 4 years to solve this problem.
CPO 76 is offline   Reply With Quote
DIY - BRZ OEM Front license plate mount/bracket no-drill installation shiumai DIY (Do-It-Yourself) Guides 97 06-03-2021 12:11 AM
OEM Front License Plate bracket installation mwy23 Northwest 13 12-25-2013 04:50 PM
WTB: BRZ OEM Front license plate mount bracket KayoTrap Canada Classifieds 7 10-01-2013 02:08 AM
Frs Cap and OEM Subaru Front license plate bracket Xdragonxb0i Miscellaneous 1 01-16-2013 12:25 AM
USA front license plate mounting? Slimline bracket mount.. Help across the world :P WTF Scion FR-S / Toyota 86 GT86 General Forum 32 08-23-2012 07:25 AM
