Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 09-23-2014, 09:46 PM   #29
Skorov
Skorov's Avatar
Drives: 86 GTS White
Originally Posted by CJBRZ View Post
Thanks! Where there any problems that you ran into while swapping out your LEDs that you'd like to share, or was it pretty straight forward?
Umm... Careful while taking out and putting in the LCD screens for the clock and HVAC. The pins bend easily.
Make sure you test before reassembling even if you are 100% sure you solder job was good. It's extremely annoying having to take everything apart again.
Oh! Very important. Take photos of your gauge needle 'zero' positions.
Good luck!
Skorov is offline   Reply With Quote
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
2JZ swap? jordydiaz Engine Swaps 44 05-21-2015 10:19 PM
Ej Swap koyv90 Engine Swaps 50 11-14-2013 07:59 PM
Key Fob Swap joergasm BRZ First-Gen (2012+) — General Topics 1 10-02-2012 11:40 PM
2UR-GSE Swap czar07 Engine Swaps 9 08-29-2012 01:43 PM
