Old 09-23-2014, 01:17 PM   #71
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by UrmyboyBLUE View Post
**Nevermind......got the issue resolved
Ah so you were the customer I heard Robert on the phone with this morning
Shiv@Openflash is offline   Reply With Quote
Old 09-23-2014, 01:53 PM   #72
UrmyboyBLUE
UrmyboyBLUE's Avatar
Drives: 2015 Subaru BRZ "Series.Blue"
yeah that was me, thanks.......do u recommend a cycling of the ignition after the flash? with like 20, sec intervals...to adapt the sitting TPS levels? or just let it idle for a couple minutes, before driving?
UrmyboyBLUE is offline   Reply With Quote
Old 09-23-2014, 03:09 PM   #73
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I usually let it idle for 10-15 minutes every time i reflash.
Old 09-23-2014, 03:14 PM   #74
Shiv@Openflash
Drives: 2013 FRS
I recommend letting it idle for 45 seconds or so after a flash process. If you start driving off right away, the VVT system will be disabled temporarily and you will notice a pretty dramatic power loss until it resumes operation
Old 09-23-2014, 03:14 PM   #75
phrosty
As I understand it there's nothing to adapt to, it simply needs 30-60sec to run a self-check diagnostic on itself then its good to go. I've always just opened up the logging screen and waited for the number to start fluctuating -- it'll be at 0 while it's doing the check.
phrosty is offline   Reply With Quote
Old 09-23-2014, 03:50 PM   #76
Shiv@Openflash
Drives: 2013 FRS
That's a very good approach to. When tuning on the dyno, I do the same thing after every write. I wait for the VVT intake value to move form 0 before I start running the car
Old 09-23-2014, 04:32 PM   #77
UrmyboyBLUE
Well.....very impressed with the Stage 1 93oct tune! It's pretty wild how much quieter the car idles and runs. much smother revs and throttle response. Not to mention coupled with my Perrin CAI and catback....a louder throatier (not a word lol) sound at 4500rpm and up. I'm still curious to know weither my AFR is running like it should with the CAI installed. I was watching the numbers and they didn't seem to crazy..plus the LT fuel trim was staying below 10 for the most part. I would stream some data for you guys , but im not sure how to do that yet. So far though....great product.
Old 09-23-2014, 05:02 PM   #78
KonTheory
Drives: '14 FRS
Incase anyone was still wondering, I had my car dynod after loading 1.59 map
I was at 179.7 on dyno dynamics on a hot day..
'14 Raven FRS - Toyota Badges - Helix Smoked Side Markers - K&N Drop-in - 3" Nameless Axleback 4" Mufflers - Tinted Back Windows - RCE Yellow Springs - Openflash Tablet - OLM HID Kit - Cusco strut bar - TRD Quickshifter - 17x9 Enkei RPF1's with Nitto NT05's
KonTheory is offline   Reply With Quote
Old 09-23-2014, 05:14 PM   #79
Readytoxplod
Tire Destroyer
Drives: Firestorm+snail
Random note, I've had the new 93 tune on my car since it was released. I noticed it had changed, idle was higher and car was louder again, so I reflashed the tune. Car was very different, quiet again, lowered idle etc. after the flash of the same tune it had been running. Is this because our ECU learns and adapts to the tune it slowly went back to over the past month?
Readytoxplod is offline   Reply With Quote
Old 09-23-2014, 05:20 PM   #80
Kodename47
Kodename47's Avatar
Drives: UK GT86
Did you mean exhaust? The exhaust AVCS is always the final bit to become active, the intake is normally active straight away in my experience.
Just an FYI for some, the exhaust AVCS only comes active after a other certain conditions are met. If you flash a cold engine, the calibration may be done after a minute but the AVCS may still be inactive. You also have to be stationary before it will start working, usually a 1 minute drive and then stopping sorts it out.
.: Stealth 86 :.
Kodename 47 DJ:
WTB: Stock MAP Sensor, Stock Frontpipe, Stock Midpipe. Sterz Engine, Exhaust, Bolt-Ons 4 07-02-2014 10:22 PM
TYC Colin Smoked Tail Lights | Stock FRS Tails | Stock FRS Reverse Bar BumpersFRS Exterior Parts (Aero, Lighting, Etc.) 1 01-11-2014 04:42 AM
WTS: Airaid Intake System, Stock Exhaust, Stock Radiator Hoses Sony Engine, Exhaust, Bolt-Ons 0 11-21-2012 12:10 AM
FS: Ecutek Cable, stock axleback exhaust, stock springs Philly Canada Classifieds 4 11-02-2012 09:50 PM
