#2115 |
#2116 |
#2117 |
Mr. Cranky Pants
Drives: 2013 Argento FR-S
Centrifugal compressors can get pretty noisy the closer you get to the surge line. A restricted air filter would cause operation closer to the surge line than with a filter that's not restricted.
#2118 |
Drives: DGM BRZ limited
I would suggest doing a boost leak check.
#2119 |
Drives: 2013 BRZ Premium Dark Gray Metallic
No, just cleaned it when I installed the oil cooler and make sure that it's tight.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1 DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time) DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler |
#2120 |
Yes it's the intake tube.
#2121 |
Drives: 2014 BRZ
#2122 | |
#2123 |
Drives: 2014 BRZ
#2124 | |
Drives: Kraftwerks BRZ
#2125 |
Do you have a log that we can view to see if anything is weird?
So long as there are no leaks, loose clamps, etc. there should be nothing wrong but if the noise is audibly different, something would have changed to now hear the intake more. Did you notice this sound before or after the oil-cooler installation? Not saying the two are tied together but in removing the bumper, etc. something could have been bumped or loosened during the installation. |
#2126 | |
![]() @KraftWerks Please PM me to where I can email a log.
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1 DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time) DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler Last edited by zoth; 09-22-2014 at 07:57 PM. |
#2127 | |
#2128 |
By the way @KraftWerks, what is your opinion about some of the guys in here that are saying that we need a check valve for the intake manifold. I was hoping you guys can give us a solid answer to put the issue to bed. Thanks in advance.
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
