Old 08-22-2014, 02:19 PM   #99
Scottemad123
Drives: 2014 SWP BRZ Limited
Originally Posted by CSG David View Post
Buy it once; buy it right. We've owned multiple wheels over the years and bent a ton of different wheels. What I can tell you is, the cost of replacing cheap wheels exceeds the cost of buying a set of high quality forged wheels. I would prefer we don't siphon money out just to replace things because we skimped out on something.
Again, everybody's goals are different. We just happened to learn the hard way and hope you guys appreciate someone else getting pwnd besides yourself. :p
I appreciate the work you guys do, just wanted to tease a little. Keep it up!
Scottemad123 is offline   Reply With Quote
Old 08-22-2014, 02:22 PM   #100
CSG David
CSG David's Avatar
Originally Posted by raul View Post
You used Raceseng and budget in the same sentence. LOL
Raceseng + OEM suspension >>>>>> most coilover setups available on the cheapo.
Old 08-22-2014, 02:23 PM   #101
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
You're probably right, but why not a set of less expensive camber plates? I'm getting the Racesengs myself because I'm a huge fan of their parts and the sheer beauty of their anodized orange, but still could pull it off with a simpler camber plate.
raul is offline   Reply With Quote
Old 08-22-2014, 03:00 PM   #102
CSG David
CSG David's Avatar
I trust Raceseng CasCam over the other camber plates for a fairly small difference in pricing. The Raceseng is also quite modular in a way where you can use it for OEM suspension or coilovers with a change of the perch and bolt. All of which are extremely high quality with very tight tolerances.
The Following User Says Thank You to CSG David For This Useful Post:
raul (08-22-2014)
Old 09-22-2014, 12:32 PM   #103
Timmy_Jones
Spun
Drives: 17' Focus RS
Anyone else have pics of these?
Thinking about the 18x8.5 or 9 width in gold, on a red FR-S.
Timmy_Jones is offline   Reply With Quote
Old 09-22-2014, 01:22 PM   #104
CSG Mike
CSG Mike's Avatar
We had 4 sets at 86Fest; I'm sure pictures will pop up
Old 09-22-2014, 01:24 PM   #105
Timmy_Jones
Spun
Thank you - they look gorgeous and imagine the gold may look very nice on a red car with just a few other subtle mods.
Old 09-22-2014, 01:31 PM   #106
CSG Mike
CSG Mike's Avatar
Not exactly what you're looking for, but from 86CUP round 9 on Saturday
Old 09-22-2014, 02:16 PM   #107
Scottemad123
Ok, now will 100% have to save some cash up for these.
Old 10-07-2014, 05:12 PM   #108
Alfalasy
2013 BRZ
Alfalasy's Avatar
I would like to know wheels specs on the white frs
Alfalasy is offline   Reply With Quote
Old 10-07-2014, 06:39 PM   #109
CSG Mike
CSG Mike's Avatar
18x9.5 +45
-3 camber front
-2.3 camber rear
255/35/18 Hankook RS3
We have 2 sets in that exact offset and color in stock, and another shipment of silver and gold coming in a few months.
Alfalasy (10-08-2014)
Old 10-08-2014, 09:04 AM   #110
tnle
Drives: Toyota 86 13'
19x9.5 +45
You scared me for a second. 19s on a track car :O lol
tnle is offline   Reply With Quote
Old 10-08-2014, 09:21 AM   #111
df.dima
Drives: FR-S and Mazda 3 Sky
Great picture! I would like to clarify regarding the difference in face look, I notice a difference in WRX and BRZ.
BRZ has spokes that are more in line with the rim, so the connection point looks straight.
On WRX, it looks like spokes are more inset vs the rim, so there's a transitioning that is rounded off as it connects to it.
Does that make sense?
I'll go look through this topic to find other width/offset wheel to see.
df.dima is offline   Reply With Quote
Old 10-08-2014, 02:02 PM   #112
CSG David
CSG David's Avatar
They look pretty similar. The WRX has 18x9.5 +40 / 5x114.3 wheels so you'll notice that the hub may look larger than the BRZ. Also note that the offset is a little different so TWS has another 5mm of pad spacing to work with over the +45 / 5x100 setup.
Wheel Directory: STR 603 18x9.0 +40 malubawla Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 05-06-2015 02:05 PM
Wheel Directory: Work VS-XX 18x9.0 +34/18x9.5 +39 mav1178 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-13-2014 05:09 AM
Wheel Directory: ESM 004 18x9.0 +38 beebo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 37 06-13-2014 02:34 AM
Wheel Directory: Work Meister S1 3-Pc 18x9.5 +29 / 18x9.5 +24 PradiG Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 12-12-2013 04:15 AM
Wheel Directory: XXR 531 18x9.5 +35 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-10-2013 03:41 PM
