Old 09-12-2014, 08:17 PM   #141
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Car looks so odd without the FMIC
Rear fitment, going to do a little more work to the quarters
And yes, that's hearing protection that stays in my car lol
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
The Following User Says Thank You to OmarGC For This Useful Post:
humanshield (09-15-2014)
Old 09-15-2014, 10:22 PM   #142
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Well some more has changed...
Omar GC
Instagram: 2jzus
Old 09-15-2014, 10:26 PM   #143
humanshield
Drives: bucket
about your plate....
I thought all Supras were FR. Just playing...
car looks amazing. bold choice to do this swap and try and keep it low budget. it's members like you that help pave the way for others who want something similar in the future. thank you.
humanshield is offline   Reply With Quote
The Following User Says Thank You to humanshield For This Useful Post:
OmarGC (09-16-2014)
Old 09-17-2014, 08:29 PM   #144
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Got bored today and wanted to see how much the Treadstone TR10 filled the bumper opening. I'm 85% content with how much it filled, which I'll live with as it's was pretty cheap and scored a decent deal on it brand new. Keep in mind when it's actually mounted the bumper cover will be trimmed and the core will sit quite a bit lower and further inward, literally just wedged it into the cover to see how much of the length of the opening it took.
Omar GC
Instagram: 2jzus
The Following 2 Users Say Thank You to OmarGC For This Useful Post:
rusty959 (09-20-2014), shifter907 (11-10-2014)
Old 09-17-2014, 08:31 PM   #145
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Overall satisfied with the quality of the core, cast end tanks are pretty nice.
Omar GC
Instagram: 2jzus
Old 09-18-2014, 11:38 PM   #146
CubanPowered86
#1 Toyota Fan
Drives: 85 SR20 AE86, 95 RB25 S14, 94 FD3S
Great thread bro! Watchin u from the NW, just picked up a frs, 2015. workin on suspension during the winter but not sure what to do about the motor.. I wanted to boost the stock but bro i think i just wanna slap a LS or 2JZ in this bitch and call it a day. Can't wait to see how your car turns out, if you do it for $8k its a no brainer for me
CubanPowered86 is offline   Reply With Quote
The Following User Says Thank You to CubanPowered86 For This Useful Post:
OmarGC (09-19-2014)
Old 09-19-2014, 08:11 PM   #147
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
For a completely stock 2jz other than fmic, exhaust, intake, and piggyback utilizing a @Chase Bays harness I know it can easily be done. This is with new maintenance items included(timing belt, drive belt, idler pulleys, fluids, etc.)
I have kinda compiled some last minute extras that were completely unnecessary so when I get the car completed I'll make a break down of the cost with both needed items and items that are more so "desires". Also will give my final total after selling off my old parts.
Omar GC
Instagram: 2jzus
Old 09-19-2014, 08:13 PM   #148
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Oh yeah...
Wife is becoming unhappy slowly but surely lol
Omar GC
Instagram: 2jzus
Old 09-19-2014, 08:41 PM   #149
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Someone on Supraforums said:
i know of two people that i grew up with in arkansas that have it done and have seen one local in colorado driving around,you can even google 2jz frs and about two dozen different builds show up. Build looks good either way and look foward to seeing the progress.
Any idea? I couldn't find shit haha
In fact, our builds don't even really show on google without specific terminology. It's all sponsor builds (E.kanoo, Tuerck, etc)
slicktop is offline   Reply With Quote
The Following User Says Thank You to slicktop For This Useful Post:
OmarGC (09-19-2014)
Old 09-19-2014, 09:51 PM   #150
solus
Drives: 2014 Scion FRS (Ultramarine)
What about all of the accessories? Power steering, A/C, heat? No need?
solus is offline   Reply With Quote
Old 09-19-2014, 11:14 PM   #151
PhoKingCool
PhoKingCool's Avatar
There are still other mods that are needed to support the power which I have not seen you mention. Mods such as...
axles
rear-end
driveshaft
turbo manifold
suspension upgrades
a legit tune
fuel system (pump, lines, fittings, filter, regulator, and so on)
PhoKingCool is offline   Reply With Quote
Old 09-20-2014, 12:34 AM   #152
slicktop
axles
rear-end
driveshaft
turbo manifold
suspension upgrades
a legit tune
Hey, come to my thread next.
OmarGC (09-21-2014)
Old 09-20-2014, 12:48 AM   #153
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Chase bays harness retains factory electronic power steering, so I'm dropping the 2j ps pump. I will be retaining a/c & heat with the oem HVAC controls, the 2j compressor, and likely factory condenser and heater core with custom lines and hoses.(have a friend of a friends shop that will be handling this once the car is near completion.)
axles
rear-end
driveshaft
turbo manifold
suspension upgrades
a legit tune
Axles- will be running stock shafts initially, not overly concerned right away as I do not drag/launch. Also have plenty of axle angle correction mods(lowering rear top hats, rear diff risers, and subframe risers). I'll eventually undergo dss 600+ hp half shafts. Clutch kicks are the biggest worry lol
Rear end- assuming you mean rear diff, I'm more then confident with the oem rear diff holding above 500whp. Did plenty with altezza/is300 rear diffs throughout my life in Japan with numbers above what I'll be making and also have a spare altezza diff with a 1.5 way LSD. My single isn't very large and I doubt I'll see above 500whp ever.
Driveshaft- custom DSS Aluminum or steel one piece, both stupid cheap. Turn around time after giving needed specs is less than 3 weeks. 1 piece steel shaft is still significantly lighter than oem chaser/supra/etc DS and I'm not very fond of lightening the driveline/powertrain in excess and I'm already lightening in other areas so I'll likely go the steel route due to my uncommon preferences.
Exhaust manifold- have been given a manifold off my friends 2j 850+ whp s14. No clue what it is, but it'll be here sometime next week.
Wastegate- running a turbosmart 38mm as I felt no need to go with a 44mm gate as I no longer plan to run <14 since I will no longer be using stock Jdm aristo twins. (Gate was given to me for a case of beer). I know some awesome people
Suspension- custom front sway or no front sway at all(we'll figure this out when I redo my spring rates/valving/likely different coils in general). Currently on stance ss+ pros, white line rsb, adjustable rear control arms, bunch of random minor bits along with the stuff mentioned above.
Tuning- running dual ecu setup with the 2jzgte ecu being commanded with an apexi piggyback which will be tuned by a personal friend from Speed and Sound STL(well known jz tuning shop). Will switch over to ProEFI or AEM standalone with time, just trying to get it on the road without initially to show it can be done for a lot less than what's being tossed out. Who knows, if the piggyback does well I'll keep running it as the oem vsc/TCS will remain fully functional.
Fuel- fuel pump I'm still very undecided on what pump to run, but likely just the largest drop in tank I can find(frs fitment) unless we figure out a good way to run a large supra pump in tank, leaning towards making a bosch 044. As far as lines Chase Bays builds a frs to 1/2jz adaption kit in which will be ran with a Hybrid Racing FPR to stock aristo fuel rail and usdm 550's.
Omar GC
Instagram: 2jzus
Old 09-21-2014, 01:41 PM   #154
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Looks like I'll be running the @FullBlown walbro 485 fuel pump kit
Omar GC
Instagram: 2jzus
BRZ- Lemon? laxfogo Issues | Warranty | Recalls / TSB 24 04-05-2013 05:15 PM
So my FR-S is officially a lemon... frsinpa Scion FR-S / Toyota 86 GT86 General Forum 90 01-19-2013 11:50 AM
Anyone thinking about lemon law? Accurate Race Shop Issues | Warranty | Recalls / TSB 16 10-18-2012 09:11 AM
Lemon? grgonium Scion FR-S / Toyota 86 GT86 General Forum 13 10-08-2012 10:13 AM
