#99 | |
Drives: 2014 BR"ZED" Sport-tech DGM MT
#100 | |
Drives: 2013 DGM BRZ
Let me tell you, the first time I forgot to turn this off at the track and entered Turn 1 at The Ridge was not only a horrible experience but also a potentially dangerous one(At which point I had to try to hold down the button while shifting before turn 2). |
#101 | |
Drives: MY15 86 GTS
I have designed plenty of electroncis for cars and for me a micro is over the top in this application, but it could be a good way to learn some programming etc. One thing to be carefull with.... The elctrical environment in a car is very tough. Many micro circuits will reset, or in some cases burn out. The signal protection and power supply circuits need to be carefully designed to give long term reliable performance (Things like reverse polarity protection etc). If I were using a small micro for this application, I would have ended up with a similar (or larger) component count to end up with the same robustness. |
#102 | |
Drives: MY15 86 GTS
I guess what most people realy 'want' is a plug and play solution..... Thanks for fixing up the thread. Mig |
#103 | |
Drives: 2013 GBS BRZ Limited
powered from microUSB connector so the car already has clean power. the device is the size of your thumbnail (smaller than the PCB above) (it would fit on the back of that pushbutton) it is designed for potential customers for sewing into clothing so it is very robust And I exaggerated above, you need three pins. Two pins, one for each button on the console, and I forgot your enable pushbutton input. If you wired the device in, you must know the voltage supplied to the pushbuttons. I assume it is 5V since it comes from IO pins on the ECU. If 12VDC, you would need a couple of transistors to pull the signal down. I also suggested it because it could perform the pedal dance too, I just havent gotten around to trying it yet. ANd that whole device is just one "component" so your count would go down and not need a PCB |
#104 | |
Drives: FT86
see here for LAM module $50 LAM=Lazy Ass American ![]() http://www.ft86club.com/forums/showp...14&postcount=1 http://www.kptechnologies.com/docs/F...stallation.pdf . |
| The Following User Says Thank You to steve99 For This Useful Post: | DC2R (08-31-2014) |
#105 | |
Drives: MY15 86 GTS
Hey, Offourse that device could be used in this application. That wasn't my point, don't take me the wrong way.. But I design electroncis. Because I want to. So I woudn't personaly purchase an item like this, I would design a PCB for a micro. If you take that point of view and look at the components on the board (Remembering there is no power supply or conditioning components here) then to do it well (from my point of view) it needs more components and cost for no benefit. Remembering I needed to solder many up by hand so SMD is a pain if not realy required. I'm not some sort of anti micro guy. I work with all sorts of micros all the time. But for this PCB's original application it just didn't fit for me, didn't suit the criteria. I'm not criticizing the Beetle, or Aruduino generaly. Where the Beetle could be cool is when using more of it's processing power, For example to indicate the current mode via the button illumination (pulsating illumination level etc). Out of interest, where do you think you would take the 'clean' 5v power supply from in the vehilce? -Mig |
#106 | |
2 - The Beetle that I posted the link to is already soldered down to the PCB. It is a complete finished unit. You take it out of the ESD bag, plug in a USB cable, and thats it. It is ready to use complete with external IO solder pads. The clean power would come from the USB port which is rear IO from the stereo. The total cost of the unit is probably less than your discrete components Maybe this will help: ![]() In fact the "old school" method of just making a variable timing pulse was to use a 555 timer IC. This is now even easier and fewer components than even your basic 555 IC setup. Last edited by stugray; 08-28-2014 at 02:56 PM. |
#107 |
Drives: MY15 86 GTS
@stugray
I realy don't want to get involved in a Tit for Tat arguement that goes nowhere in this thread. I'm not realy sure what your point is, or why you want to push this solution as being so superior. I have already indicated that the beetle could work for this application. And since you already posted the link I don't see the need to then put up a picture (we can all follow links). As you are an engineer, you will understand the idea of designing for purpose. I have already indicated a number of times that this circuit was orriginaly designed for another purpose. In that application there is no 5v line available (race cars don't have stereos), so to use a micro (Any) straight away you have to add a power supply cirucit (in the case of the beetle this would be on another board). To put it in perspective, this board cost less than $5 (PCB + Components) and met my requirements of being quick to assemble (no SMD). It operates as required. Just to give some perspective that i know what I'm talking about and am happy to use micros look here on PG36: http://romeomanciu.no-ip.org:55555/M...%202008-05.pdf |
#108 |
Please make these!!!! I want to be first in line
#109 |
Drives: MY15 86 GTS
This was my first topic\post on this forum.
So far I have had one person tell me that I'm wasting my time. (spending quite a bit of his own to get the point accross). Another person seems to want to tell me how he would have done it better (according to his criteria). After taking a look through other posts on other threads, I've come to the conclusion that this is not the colaborative, constructive community I expected. Too much negativity, **** measuring, flamers and trolls. Lifes to short. Think I'll park my account and enjoy my car. -Mig |
| The Following User Says Thank You to mig86 For This Useful Post: | Akari (08-29-2014) |
#110 | |
Or having to solder SMD (SMD parts are already soldered). And the fact that this would be LESS cost and LESS work (and I guess nobody caught the part about me building one to do the pedal dance) SO I''ll just shut the fuck up then. |
#111 | |
Drives: 2013 Galaxy Blue BRZ
#112 | |
Drives: Toyota 86 GTS
Illuminated trunk switch?
| brake override DOES NOT diminish heel & toe | 4agze | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 09-17-2012 04:43 AM |
| Permanent Optimum opti-coat 2.0 ?? | Ericfrs | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 4 | 09-04-2012 02:11 AM |
| LF: rear fog switch picture | Silverdub | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 06-28-2012 08:34 AM |
| Anyone going to switch badges? | DougieFresh | Scion FR-S / Toyota 86 GT86 General Forum | 60 | 09-28-2011 02:56 AM |
| Brake override system in the FT-86? | mrKiKaZ | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 02-22-2010 11:33 AM |
