Old 09-20-2014, 06:45 PM   #225
steve99
Drives: FT86
Originally Posted by KonTheory View Post
I figured maybe the revs werent high enough, in which case do you know how to raise the rev limiter for the OFT, 5800 doesnt seem high enough... lol
You can alter launch rpm read the OFT TIPS link below.
However i figure from your posts that your wide sticky tires had suffient grip on the road that the clutch let go before the tyres. ie the clutch burning smell. You will get a better launch letting the clutch out at a controlled rate rarther than just dropping it especially wiyh wide sticky tyres and a stock clutch. else all you will achieve is stuffing your stock clutch.
KonTheory (09-20-2014)
Old 09-20-2014, 07:15 PM   #226
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Originally Posted by zc06_kisstherain View Post
@Shiv@Openflash,
Shiv, I had chance to datalog 2 runs. would you please take a look at it and i am good?
http://www.datazap.me/u/zc06kissther...ta=1-6-7-11-12
Thanks
Can anybody look at mine??
Old 09-20-2014, 07:31 PM   #227
steve99
Drives: FT86
fuel trims good
afr fine
bit of minor knock
the fbkc knock is what has dropped your iam to 0.98 not serious
try some different brands of 93 gass some are better than others for knock resistance
zc06_kisstherain (09-20-2014)
Old 09-20-2014, 07:33 PM   #228
zc06_kisstherain
Drives: SWP BRZ
fuel trims good
afr fine
bit of minor knock
Thanks steve.
I only use shell 93. I will try sunoco when gas gets near empty.
Old 09-22-2014, 12:14 AM   #229
zc06_kisstherain
Drives: SWP BRZ
@steve99
should i run 91 tune instead of 93? if it's not too serious, i will just leave it with 93 tune i have. i havent tried different brand of gas yet
Old 09-22-2014, 01:46 AM   #230
steve99
Drives: FT86
@steve99
Its not that serious, and the 91 tune only pulls timing high rpm high load.
The IAM drop appeared to be caused by low rpm high load knock again not serious but you would have to manually edit table to correct that.
Old 09-22-2014, 02:28 AM   #231
rcampici
Drives: GTS86
I have loaded the new 2.06 files to my tablet, at the same time I have changed the exhaust to catted header Equal length, no second cat, 2.5 inch system.
I wish to know what is the best tune for me on 100 E10 Octane fuel here in Australia
Should I be on Stage 2 or remain on Stage 1.
Thank you
Robert
rcampici is offline   Reply With Quote
Old 09-22-2014, 03:13 AM   #232
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Thank you
Robert
Your safest map is Stg1 91.
It's VERY important you run this first as a baseline to make sure you have no leaks, no fuel problems (P100 is mixed on site), etc.
Then you can try more aggressive tunes. Don't be disappointed if they don't work.
Stg2 EL 93 - cam timing may be too aggressive for catted header
Stg2 EL 91 - try Stg2 EL 91 if Stg2 EL 93 KNOCKS OVER 6000rpm
Stg1 93 - try Stg1 93 if Stg2 EL 93 KNOCKS BELOW 6000rpm OR if Stg2 EL 91 knocks anywhere
Stg1 91 - fall back to Stg1 91 if Stg1 93 KNOCKS OVER 6000rpm
Message me and we'll add you to the Aussie OFT fb user group.
Finally, if you have to ask which is the best tune, the answer is Stg1 91 i.e. the OTS tune.
The Following User Says Thank You to Wayno For This Useful Post:
Annahra (09-22-2014)
Old 09-22-2014, 03:39 AM   #233
Wayno
Wayno's Avatar
On another note I have a knock free log for the first time.
OTS 91AKI map
United P100
Apexi filter
Stock exhaust except UEL header and op.
http://datazap.me/u/wayne/206-stg2-u...ta=1-7-9-11-12
steve99 (09-22-2014)
Old 09-22-2014, 04:52 AM   #234
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Aussie OFT Facebook user group? Why no invite?
Shiv@Openflash is offline   Reply With Quote
Old 09-22-2014, 07:14 AM   #235
tmichel
tmichel's Avatar
Drives: Sonic Blue 2014 GT86
keen to join too
tmichel is offline   Reply With Quote
Old 09-22-2014, 07:17 AM   #236
rcampici
Drives: GTS86
Thanks Wayno.... comments noted.
Old 09-22-2014, 08:44 AM   #237
troek
troek's Avatar
Drives: 2012 Toyota 86
Originally Posted by Shiv@Openflash View Post
That amount of knock retard is not really much to worry about. But you can always load the 91oct version of the map instead if you want it completely gone. There is no problem with running the 91oct map on 93oct fuel. If i had my way, I wouldn't even have labeled the two map options 91oct and 93oct. But rather "standard" and "aggressive".
great news. i was wondering why ive never had flkc show up before, and why it would be all of a sudden, and i had an epiphany. ive had a exhaust rattle that i had temp fixed that came unfixed recently. fixed that a little more permanently and now the knock is completely gone. did 3 back to back pulls tonight and zero flkc registered, about 2 hours before i fixed the rattle i did 2-3 pulls that got all the way to -2.0 flkc. guess it was just false knock. @steve99
troek is offline   Reply With Quote
Old 09-22-2014, 08:46 AM   #238
troek
troek's Avatar
Originally Posted by tmichel View Post
keen to join too
im also keen to join, if you dont mind havin a yank around.
OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] Shiv@Openflash Forced Induction 226 03-12-2019 10:26 PM
iOS 8 beta 1 not working on BRZ USB Kids Heart Off-Topic Lounge [WARNING: NO POLITICS] 4 04-13-2015 09:17 PM
v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT Shiv@Openflash Forced Induction 3 07-26-2014 01:23 PM
OFT 1.42 vs 1.5x Beta Who notices a Difference? Cross Software Tuning 11 03-21-2014 04:17 PM
Anyone want to beta-test some door speaker spacers? phenryiv1 Electronics | Audio | NAV | Infotainment 63 08-20-2012 10:02 PM
