Old 09-18-2014, 07:53 PM   #1
jxl00
Drives: scion frs 2014
sorry, newb question on Wheels
I just got an FRS
I would like 17x8 wheels that are lightweight (17ish lbs) at a reasonable price. Not looking for the best, just looking for some adequate ones that will be better than stock and improve the general riding experience at a low cost.
Any recommendations?
jxl00 is offline   Reply With Quote
Old 09-18-2014, 08:07 PM   #2
CSG David
CSG David's Avatar
Originally Posted by jxl00 View Post
I just got an FRS
What's your goal before going down this route? 17-ish pounds for 17x8 is relatively "heavy"...not lightweight.
Your stock wheels are actually good, however, it's purely up to what you're looking for in terms of application, looks, budget, and performance.
Old 09-18-2014, 08:29 PM   #3
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Kosei and OZ makes some decently light 17x8 that look pretty good
Old 09-18-2014, 08:36 PM   #4
jxl00
i want 2 sets of wheels.
i'm gonna put snow tires on stock wheels.
i want to have summer tires on a new set of wheels. i know it's not gonna be a huge difference but i want better grip/acceleration. i also want to stay at 17x8 and
Old 09-19-2014, 03:14 AM   #5
makesdrivingfunagain
Do you know what tire size you want to run? Also, consider the weight of the tire. I am not sure what type of driving you plan to do. But with a 17x8 wheel with a good tire, it may weigh more than the stock setup. Just consider the weight of them both when pursuing to lose weight in this department. And 17lbs for this wheel size isn't very light. There are many choices that are lighter. Tirerack is one site that has many rims and tires to choose from. However, I am not sure they sell many if any forged wheels for this car that I know of. As forged are lighter than cast.
makesdrivingfunagain is offline   Reply With Quote
Old 09-19-2014, 09:22 AM   #6
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
I just got an FRS
Not sure what you consider low-cost, but these are all under 16# and the Kosei's are the least expensive among them:
http://www.tirerack.com/wheels/resul...rSpecial=false
dradernh is offline   Reply With Quote
Old 09-19-2014, 07:21 PM   #7
jxl00
I probably am interested in 215-225/45/17. i want the wheels/tires to be similar dimensions to stock
Old 09-19-2014, 07:31 PM   #8
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Kosei are probablly the most inexpensive light weight wheels you will come by. Size is the question though.
-Jack Burton
Old 09-19-2014, 09:29 PM   #9
jxl00
thanks for answering guys. i'm gonna get 17x8 kosei when they are on sale.
another silly question,
when I get new wheels, do I have to buy a new tpms for it?
and how important is the offset? I know stock offset is +48. is there an ideal number or is this all preference? i'm looking at one with +42.
Old 09-19-2014, 09:47 PM   #10
dradernh
If you're in Mass, apparently not: http://www.tirerack.com/wheels/tech/...jsp?techid=214. I'd check with an inspection station just to be sure, though.
Old 09-19-2014, 09:54 PM   #11
Guzic
Clean as F86ck
Guzic's Avatar
Drives: 2014 Asphalt FR-S
I'm running 17x9 +42 and the wheels sit almost perfectly flush. With 17x8 you'll have a bit more clearance but they might be a bit tucked.
Guzic is offline   Reply With Quote
Old 09-19-2014, 10:15 PM   #12
dizzario
Drives: FRS
Rule 1: NEVER listen to anyone who has a fist-sized gap between the top of their tires and the fender in regards to sitting 'flush'.
I'm no advocate for 'hellaflush' but an offset in the 40s will only be flush out front. I have 17x9.5+40 TE37RTs and the front is 'flush' and doesn't rub at full lock. Yes, your TPMS will work with any wheel. My OEM ones are in my current wheels.
I'd say some 17x9+45F (closer to OEM...although I can't fathom WHY you'd want that) RPF1s should be good for you. My TEs are clocking in at 17+lbs but the RPF1 (and Weds TC105n) are hovering near ~15lbs...closer to 14lbs for the Weds.
Use Google, not the forum, to find information on wheels. You can also troll the wheel directory for anything your heart desires. You're going to have to shell out $$$ for lightweight wheels unless you buy used RPF1s. Most will say they're 'played-out' but then again, so is that term.
dizzario is offline   Reply With Quote
Old 09-20-2014, 12:50 AM   #13
86Toyobaru
Drives: 86 & GRB
I just got an FRS
Weds sport TC105N 17X8 +42 (6.75kg) ~350USD
Enkei RPF1 17X8 +35/+45 (7.01kg) ~250USD
Enkei PF07 17X8 +38 ~200USD
Enkei PF01 17X8 +35/+45 (7.82kg) ~200USD
SSR GTV02 17X8 +45 ~200USD
Advan RS-D 17X8 +47 ~ 350USD
86Toyobaru is offline   Reply With Quote
Old 09-20-2014, 01:19 AM   #14
ray7792
ray7792's Avatar
Drives: AT 2013 BRZ Limited
Some others in case you're not 100%
TSW Nurburgring 17x8 +35 [17.95lbs] @ $950 set of 4
Rota Titans 17x8 +45 [17.1 lbs] @ $700 lol set of 4; don't hate T.T
Mach V Awesome 17x9 +42 [17.9lbs] @ ~$1000
You don't have to get TPMS for them; inspection here in NJ doesn't care at least, probably the case for MA.
What can be annoying though is...if you drive more than 25 miles straight (without turning car off) the tire pressure light will come on but will go away after a few days. If your daily commute is less than 25 miles you'll have no issues.
Or you can just move the TPMS from stock to new wheels.
http://www.ft86club.com/forums/showthread.php?t=7535
According to the above thread, flush for 17x8 will be +38F/+31R @ stock height and +36F/+26R @ 1" lowered.
'13 BRZ (sold)
'17 STI
ray7792 is offline   Reply With Quote
Newb Brake bed-in (bedding?) question BigFatFlip Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 08-16-2016 03:40 AM
Newb question on cleaning engine bay swift996 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 7 02-09-2014 08:34 AM
Quick newb question Gt86_nick Cosmetic Modification (Interior/Exterior/Lighting) 1 01-17-2014 07:58 PM
Newb question- springs vs coilovers wbradley Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 09-12-2012 10:09 AM
newb rim question carbonBLUE Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 06-29-2012 01:07 AM
