Old 09-18-2014, 01:02 PM   #141
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
Originally Posted by wparsons View Post
Challenge accepted.
The link you posted:
I REALLY hope you're better at fact checking before using anything in a court room than you are with arguing online. Although, I would LOVE to see you in action where you present evidence to defend someone that actually incriminates them further.
Will you go away now?
Getting owned by your own link? Priceless.
DylanFRS is offline   Reply With Quote
Old 09-18-2014, 01:04 PM   #142
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Adding some actual experience to this thread:
I got an oil change at Toyota and they put my tire pressures back to the "driver's side door" spec.
Guess what? They filled it on the coldest day this week (in the morning) and are probably a bit higher right now just due to temperature. The car almost snapped away from me when getting on the throttle on my favourite on-ramp. Didn't happen the day before...
Tire pressures recommendations are just a starting point!
drewbot is offline   Reply With Quote
Old 09-18-2014, 01:23 PM   #143
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
heh
this thread just reminded me of this little gem
[ame="https://www.youtube.com/watch?v=N2IWxqvsSY8"]Overdrift - YouTube[/ame]
Old 09-18-2014, 01:50 PM   #144
Challenge accepted.
And the WINNER IS!
Wparsons!!!!!!!!!!!!!!
Old 09-18-2014, 04:54 PM   #145
stonenewt
Drives: BMW 120d
Challenge accepted.
I just realised something. On the first page of text in the brochure:
Originally Posted by MichelinArticle:Page1
Setup information contained in this brochure is for your consideration only and is provided as a convenience to assist you with your new tire purchase. It is up to you to determine the best setup for your vehicle application, driving style and track conditions.
My emphasis.
stonenewt is offline   Reply With Quote
Old 09-18-2014, 04:54 PM   #146
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
And the WINNER IS!
when you're fight is with a bubble boy holding a megaphone... any victory feels empty
Old 09-18-2014, 04:55 PM   #147
stonenewt
Drives: BMW 120d
Torn between Wparsons and Stonenewt as the most credible at this point.
And we're both on the same page which after Uber's little Michelin Pilot Sport Cup fail is just
Old 09-18-2014, 06:44 PM   #148
Gonna start keeping a score board just for the pure entertainment value!
Old 09-18-2014, 08:52 PM   #149
wparsons
wparsons's Avatar
Eff that! A win is a win
flickr
Old 09-18-2014, 10:48 PM   #150
geezer86
Drives: 2014 FR-S red
I have these in a 225 45 17 on stock rims, as hard as I try I can't get the back to brake loose.
Could 1 cm make that much diff.? I wanna slide once in a while.
geezer86 is offline   Reply With Quote
Old 09-19-2014, 02:29 AM   #151
CSG Mike
CSG Mike's Avatar
you need to turn traction and stability control off to do that...
Old 09-19-2014, 10:40 AM   #152
ZDan
ZDan's Avatar
Drives: '23 BRZ
That was bad quote clipping. I was answering the sentence before that.
Not the second sentence that you quoted.
I don't see where I misunderstood, a little help?
Here's how it appeared in the thread:
I mean why do heavy cars use larger tires but roughly the same tire pressure?
To increase the contact patch area. The heaver the load the larger an area you need on the road to provide grip. Put it another way, would you be comfortable driving a 1 tone vehicle with a contact patch of 1.6 sq"?
You get a larger contact patch for free with the SAME SIZE tires under a higher load at a given pressure. Having a larger tire at the same pressure doesn't necessarily give you greater contact patch area (also, greater contact patch area doesn't necessarily imply greater GRIP). In fact, greater contact patch area means greater deformation and greater heat into the tire, which is why you increase pressure for a given tire under high loads. It *reduces* the contact patch area but INCREASES allowable load.
Greater contact patch area does not equate with greater load-carrying capacity.
Greater tire volume does give greater load-carrying capacity at a given pressure, even though contact patch area is roughly the same vs. a smaller tire at the same pressure.
http://www.bridgestonetrucktires.com...4/v3i4Tech.asp
You could say it's the number of air molecules inside that determines the maximum load. Higher pressure means more air molecules and higher capacity. And, a bigger tire can contain more air molecules-and therefore has more capacity-than a smaller tire at the same pressure. And there's one other factor.
http://www.goodyeartrucktires.com/pd...tread_S5_V.pdf
A tire requires proper air pressure
to adequately carry the load placed on
it. The “container volume,” material
properties and inflation pressure determine
the load carrying capacity of the tire.
Old 09-19-2014, 11:06 AM   #153
wparsons
wparsons's Avatar
We're not talking about extremely heavy loads here, we're talking about passenger vehicle tires.
If tire width doesn't matter, why don't you see BMW X5's driving around on 165's? The reason is because to get the contact patch area needed to support the heavy truck a 165 would need a very long contact patch (and a very flat looking tire), or extremely high pressures.
If you're talking about the difference between a 215 and a 225 on the same car, sure.
Take one car and two sets of wheels/tires. One set is a 215/45/17, the other is 215/50/16. Same tire make/model, so construction will be very similar. Both tires will have the same contact patch, and both have to support the same weight. Will the desired pressure in the 16's be lower because of higher volume?
flickr
Old 09-19-2014, 11:31 AM   #154
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
heh
Oh my god. I just, I don't even know.
Thank you so much.
The Following User _________ Stay_Puft(09-13-2014)
Says Thank You to
MmmHamSandwich For
This Useful Post:
MmmHamSandwich is offline   Reply With Quote
Michelin Pilot Super sport vs hankook vs nitto ft86me Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 52 03-21-2015 04:43 PM
How durable are Michelin Pilot Super Sport on the track? Ferrari Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 08-21-2014 11:55 AM
Michelin Pilot Super Sport 225/40/18 FastLane1000 Wheels and Tires 2 09-03-2013 12:04 PM
Michelin Pilot Super Sport - 245/35ZR18 Staf00 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 08-30-2013 06:13 PM
Michelin Pilot Super Sport 17 inch DieselBoXXer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 07-05-2012 10:17 PM
