| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#127 |
I thought you had already contradicted yourself in this thread. I guess you aren't a reliable source then.
#128 | |
i'm sorry, what?
Drives: Canada
yes, you're so correct and informative that you can't keep the car on the road and spin out at the slightest hint of forward velocity. while the rest of us have grip and are enjoying driving our cars at a spirited pace.
#129 | |
Lost in Kansas
Drives: 2013 Scion FRS (Raven)
#130 |
Speak with authority but gets it wrong, people correct him but he refuses to concede so they must be wrong. Therefore he must be right.
Even this logic is ridiculously stupid.
#131 | |
Drives: BRZ Pearl White
Your car is only held up in the manner you suggest when all four tires are flat. The car is suspended on its tires at the hubs. The weight of the car hangs from the center of the wheel/tire assembly. The forces that hold the car off the ground are equally distributed inside the tire (which is round for practical purposes). The weight of the car is held up by ALL of the tire ALL of the time. The tire can do this only because of the air pressure inside the tire. Deformation of the carcass and the size of the contact patch are irrelevant to the "push/push" you refer to. Pressure, as you must know, exerts the same force everywhere inside the tire equally and in all directions which is what we mean by "pressure". All of that force holds the car off the ground, so in reality most of the tire holds the car up by "pulling" rather than "pushing". The contact patch no more holds the car up than the valve stem does. Bicycle wheels are a good illustration of this as the axle on a bike actually hangs from the spokes, the axle does not push on the spokes as must be intuitively obvious to anyone who thinks about it for a moment or two, well almost anyone I suppose. The higher the pressure, the more air is in the tire and the more load it can carry. The larger the internal volume of the tire the more load it can carry at any given pressure than a smaller tire at the same pressure because it contains more air. This is pretty simple to understand. The effect on the contact patch is another matter entirely. Tire grip is not proportional to contact patch size in the way many seem to think. A review of other pages on that Barry's tire site provides even more food for thought on the underlying (har har) issue raised by the initial post in this thread...it'll be really interesting to see what opinions are posted after reading all of that! |
#132 |
Drives: BMW 120d
#133 |
Drives: BMW 120d
#134 |
i'm sorry, what?
Drives: Canada
the worst part is that while in general, the discussion tire properties and construction is correct, Uber's application is inconsistent with the end goal.
Blindly following the manufactures recommendation for tire inflation when using a non-OEM tire is just stupid. The end goal is to achieve a good balance of grip and control, there is no magic formula for this, you generally do it through trial and error until you get the results you want. if the tire grips at a lower psi and the driver does not feel any negative steering feedback, then all is well in the galaxy.
#135 | |
Lost in Kansas
Wrong.
When you say "more air" are you talking volume or mass? Because they are different. And you keep talking about "more volume" and "more air". For a given tire on a given rim, volume is basically constant... (static tire deformation is negligible). So, then pressure is dependent on the mass of air in the tire at that point AND temperature. Quote:
The loads a tire can take depend on A LOT of things including tire construction AND pressure (not volume, they are different). Listen, talk all you want about hanging and how the car acts on the tires and all that but here is the simple math for you... A car weighs Fcar. That means, for a car to sit at rest and not fall into the earth, the ground pushed back on the car EXACTLY Fcar. Of course it is pushing back directly on the tires. So the force on each tire, in the simplest case, is Fcar/4. Ftire = Fcar/4 That means that the pressure one tire is exerting (Ptire) is: Ptire = Ftire/Atire Where Atire is the contact patch of a single tire in square units of length. Now here is the real kicker, this is gonna blow your mind. Ptire is also the air pressure in the tire!!!!!!!!!! Boom! Because, the air in the tire has to push back on the inside of the tire with the same pressure for the tire to stay rigid. Amazeballz! |
#136 | |
Drives: BMW 120d
#137 |
Drives: BMW 120d
#138 |
i'm sorry, what?
Drives: Canada
exactly why I drew that picture
#139 |
HA HA HA HA HA
I once told some body to "be carful of the info on here as some guys can't even agree what tire pressure to use". That was before I ever even saw this thread! Do you guys just follow each other around to debate? Once again tried to learn something and came out knowing less then when I went in because don't know just who to believe. Torn between Wparsons and Stonenewt as the most credible at this point. |
#140 | ||||||||
The link you posted: Quote:
Point number 1: Quote:
Will you go away now?
| Michelin Pilot Super sport vs hankook vs nitto | ft86me | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 52 | 03-21-2015 04:43 PM |
| How durable are Michelin Pilot Super Sport on the track? | Ferrari | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 08-21-2014 11:55 AM |
| Michelin Pilot Super Sport 225/40/18 | FastLane1000 | Wheels and Tires | 2 | 09-03-2013 12:04 PM |
| Michelin Pilot Super Sport - 245/35ZR18 | Staf00 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 08-30-2013 06:13 PM |
| Michelin Pilot Super Sport 17 inch | DieselBoXXer | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 07-05-2012 10:17 PM |
