Old 09-18-2014, 01:37 AM   #197
JB86'd
JB86'd's Avatar
Drives: JAWS
Originally Posted by 2much View Post
cool thanks!
Maybe it's just me... but I am having a hard time finding documentation on this thing. Nowhere did it say that the ecu will continue to adjust after the initial startup.
Theres no descriptions of the stock tuning files... I guessed that UEL and EL were for different headers, but what does AOC mean?
The only engine mods I have at this point is a k/n air filter and a perrin inlet tube... out of the 5 tunes that came shipped, i chose the stg1 AOC - is that correct?
Thanks for your patience if you decide to answer my noob questions
A0C is your rom calibration. Yes stg 1 would be correct for you. Anytime your ECU is reflashed or reset it must learn, not just with the OFT. Theres youtube videos, and quite a few threads you can read through about tuning, datalogging, etc. find a post by @steve99 , in his signature he has some links to tutorials and a ton of great info. Read up!
JB86'd is offline   Reply With Quote
The Following User Says Thank You to JB86'd For This Useful Post:
2much (09-18-2014)
Old 09-18-2014, 01:52 AM   #198
2much
I wanna go fast
Drives: 2013 FR-S 6MT
2much is offline   Reply With Quote
Old 09-18-2014, 11:51 AM   #199
sprintamx
I've been on V2.06 Stg 2 EL 93 oct map for less than a week with about 30 miles, and was on the V2.01 map version for about 3-4 weeks prior. V2.01 had less throttle lag and "felt" like it produced a bit more power through 3.5 - 5K rpms, than V2.06. With the current map the lag is significant up to 3.5 - 3.7K rpms, and while power generation is smooth thereafter, it "seems" to build a bit slower than when I had V2.01 loaded.
Previously I ran V1.59 Stage 2 EL E85 and that tune rocked! But, I decided to move back to 93 oct for the winter and convenience since only one station by me carries E85.
If it helps work through this, I have a 2013 BRZ with a K&N drop-in (no other intake mods than removing and capping the sound tube) a catless EL header, and a Nameless catback (for sound and looks).
Disclosure: I've been lazy and have not captured any logs. If I need to do that for the sake of the community, I'll get off my duff and bone up on the process.
I will also comment that discussion seems to be all over the map regarding whether / if / how long the ECU needs to calibrate a new map. For those of us that only have a glimmer of tuning process and architecture it can be confusing.
Cheers.
sprintamx is offline   Reply With Quote
Old 09-18-2014, 02:42 PM   #200
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Cheers.
There are no mapping changes between any of the 2.0x ROMs. So v2.01 is identical to v2.06. The increment only indicates additional ROM support as the read me file documents.
Shiv@Openflash is offline   Reply With Quote
Old 09-18-2014, 03:15 PM   #201
KonTheory
Drives: '14 FRS
Hi,
So I recently updated my map from 1.59 to 2.0
at first it was different but now if feels great.. a few hundred kms later..
so I wanted to try out the launch control..
I came to a stop on an empty road and put the gas down, it was holding at around 5800rpm
but when I dropped the clutch it bogged right down, no wheel chirp at all, and felt really slow.. is that normal? I had trac control completely off.. and after I did it.. I could smell my clutch..
'14 Raven FRS - Toyota Badges - Helix Smoked Side Markers - K&N Drop-in - 3" Nameless Axleback 4" Mufflers - Tinted Back Windows - RCE Yellow Springs - Openflash Tablet - OLM HID Kit - Cusco strut bar - TRD Quickshifter - 17x9 Enkei RPF1's with Nitto NT05's
KonTheory is offline   Reply With Quote
Old 09-18-2014, 03:19 PM   #202
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by KonTheory View Post
Hi,
That's smell is your clutch slipping. Unless you are ready to replace it soon, I would refrain from the clutch dumps
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
chas3wba0 (09-19-2014)
Old 09-18-2014, 03:24 PM   #203
KonTheory
Drives: '14 FRS
LOL, I hope not, only 14000kms on my car, never tracked and commute to work 100kms a day... Im not even hard on it..
Old 09-18-2014, 03:32 PM   #204
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
Except when you dump the clutch
I kid I kid
Kronos is offline   Reply With Quote
The Following User Says Thank You to Kronos For This Useful Post:
raven1231 (09-18-2014)
Old 09-18-2014, 04:03 PM   #205
fantah
fantah's Avatar
Drives: 2013 BRZ Premium Black
Yep mines will be gone soon... But then again I rally my car hahahaha. Break stuff then get better ones!
I kid I kid
fantah is offline   Reply With Quote
The Following User Says Thank You to fantah For This Useful Post:
Kronos (09-18-2014)
Old 09-18-2014, 05:01 PM   #206
KonTheory
Drives: '14 FRS
I kid I kid
Well you know... had to try it out :P
The Following User Says Thank You to KonTheory For This Useful Post:
Kronos (09-18-2014)
Old 09-18-2014, 10:18 PM   #207
steve99
Drives: FT86
Im not supprised it bogged down on 17x9 wheels with nitto tyres thats serious rubber on a basicly stock car.
check the mod list in his signiture..... lol
The Following 2 Users Say Thank You to steve99 For This Useful Post:
KonTheory (09-20-2014), Trettiosjuan (09-19-2014)
Old 09-19-2014, 05:58 AM   #208
ZZT86
ZZT86's Avatar
Drives: BR86
@ Shiv - Who is that guy after the OFH OFT in your siggie ? Reminds of Juan Epstein from Welcome Back, Kotter
ZZT86 is offline   Reply With Quote
Old 09-19-2014, 08:25 PM   #209
troek
troek's Avatar
Drives: 2012 Toyota 86
andy samberg
troek is offline   Reply With Quote
Old 09-19-2014, 08:37 PM   #210
troek
troek's Avatar
ok, heres a log with the newest tune, ive never been able to realy log flkc before, so maybe ive always had this and never noticed. but theres over -1.0 flkc at top. maybe my afr is too lean? or is this small enough to not worry about. everything else seems perfect.
http://datazap.me/u/troek/v206-pull-...-4-5-6-7-10-12
OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] Shiv@Openflash Forced Induction 226 03-12-2019 09:26 PM
iOS 8 beta 1 not working on BRZ USB Kids Heart Off-Topic Lounge [WARNING: NO POLITICS] 4 04-13-2015 08:17 PM
v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT Shiv@Openflash Forced Induction 3 07-26-2014 12:23 PM
OFT 1.42 vs 1.5x Beta Who notices a Difference? Cross Software Tuning 11 03-21-2014 03:17 PM
Anyone want to beta-test some door speaker spacers? phenryiv1 Electronics | Audio | NAV | Infotainment 63 08-20-2012 09:02 PM
