| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#113 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
Stick to law, not engineering please
Sent from my OnePlus One |
| The Following 3 Users Say Thank You to drewbot For This Useful Post: |
#114 |
Drives: 2014 BR"ZED" Sport-tech DGM MT
This got me thinking of how those tanker trucks will have extra sets of wheels that they can lower when they are fully loaded down thus increasing the size of the contact area that they have to spread the load arcoss.
| The Following User Says Thank You to FLYFISHR For This Useful Post: | wparsons (09-17-2014) |
#115 |
Oh lord no he won't!!!! He's going to attempt to explain why he contradicted himself and somehow make it seem that he's right
#116 | ||||
Drives: BMW 120d
Hint - "A modern statement of Boyle's law is: The absolute pressure exerted by a given mass of an ideal gas is inversely proportional to the volume it occupies if the temperature and amount of gas remain unchanged within a closed system." Quote:
"It is impossible to make a general recommendation on inflation pressure for a specific bicycle or a particular tire. The “right” inflation pressure depends mainly on the load exerted on the tire. This weight is mainly influenced by the weight of the rider and any luggage. Contrary to a car, the vehicle weight is only a minor part of the total weight. In addition there is a great diversity of individual preferences with regards to low rolling resistance or suspension comfort." Quote:
Last edited by stonenewt; 09-18-2014 at 11:28 AM. Reason: rephrasing awkward English & quote trimming |
| The Following 2 Users Say Thank You to stonenewt For This Useful Post: | Dipstik-sportech (09-18-2014), wparsons (09-18-2014) |
#117 |
Dismember
Drives: 2013 Red Scion FR-S
#118 | |
Drives: BMW 120d
If you hit 85-90% of the PSI limit of the tyre or rim then step up a tyre size. If you reach the minimum PSI of the tyre then drop down a tyre size. The maximum & minimum load of the tyre is directly proportional to the size of the tyres contact patch at 10% droop. Two interesting points: - It's completely independent of the wheel radius which kind of blows the whole volume theory out the water. - You can't apply this rule of thumb or a similar one to car tyres. |
#119 |
#120 |
Drives: BMW 120d
#121 | |
Drives: 2012 Toyota 86
#122 |
Yay, suberman ruins a handling thread again.
| The Following 3 Users Say Thank You to s2d4 For This Useful Post: |
#123 | ||
Drives: '23 BRZ
When you add load at a given pressure, you INCREASE the contact patch area. When you add air pressure at a given load, you are REDUCING the contact patch area, not increasing it. More contact patch area does not give greater load-carrying capacity. Too much tire deformation gives greater contact patch area and results in more heat into the carcass. You add pressure to reduce deformation and heat. Last edited by ZDan; 09-18-2014 at 08:57 AM. |
| The Following User Says Thank You to ZDan For This Useful Post: | stonenewt (09-18-2014) |
#124 |
i'm sorry, what?
Drives: Canada
#125 | |
Lost in Kansas
Drives: 2013 Scion FRS (Raven)
#126 | |
Drives: BRZ Pearl White
The variables for bike tires are tire section (as for cars but there are fewer standard wheel sizes for adult bikes). Tire slip angles work differently for bicycles (and motorcycles) so comparing the grip of one type of vehicle to another is fairly pointless. The volume of the tire and the tire pressure are correlated to load capacity in all pneumatic tires. Your remarks about adjusting tire pressures on bikes for ride and handling changes have no useful application to cars. The point and purpose of my posts is to provide correct and useful information. The contradictory posts are mainly just that: contradictory. I've yet to see any reference to any reliable source that actually contradicts anything I've said. I suspect this thread may get even longer before that happens although I am confident no matter how long it gets there will be no such posting. |
| Michelin Pilot Super sport vs hankook vs nitto | ft86me | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 52 | 03-21-2015 04:43 PM |
| How durable are Michelin Pilot Super Sport on the track? | Ferrari | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 08-21-2014 11:55 AM |
| Michelin Pilot Super Sport 225/40/18 | FastLane1000 | Wheels and Tires | 2 | 09-03-2013 12:04 PM |
| Michelin Pilot Super Sport - 245/35ZR18 | Staf00 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 08-30-2013 06:13 PM |
| Michelin Pilot Super Sport 17 inch | DieselBoXXer | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 07-05-2012 10:17 PM |
