Old 09-16-2014, 05:59 PM   #183
OnkelC
OnkelC's Avatar
Drives: 2017 Fiesta ST
Ah OK, my last .ver was 1.59, it was a nice commodity just loading up that single file and letting the oft do its magic on its own
OnkelC is offline   Reply With Quote
Old 09-16-2014, 07:06 PM   #184
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Originally Posted by Shiv@Openflash View Post
It wasn't included because the .bin files are all available. No sense in loading a .dev file when you have access to the .bin files
Isn't the .dev file the only way to update the OFT for auto build of tunes? Obviously if I'm home or have my Windows tablet with me I can use the .bin to load a specific tune but without that the .dev's the only way right?
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 09-16-2014, 07:11 PM   #185
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
The problem with automatic file generation is that it can only make so many changes. The changes required to update most older CAL IDs to B01C are too extreme. Only B00C and B01C ROMS can autogerate B01C based ROM files. So in those other cases, will need to upload the ROM file manually.
Shiv@Openflash is offline   Reply With Quote
Old 09-17-2014, 01:51 AM   #186
cookiesowns
Drives: WRB BRZ Series.Blue
Hey shiv, any updates on LC, and flat foot shift? Or is that not coming to D00C ROMS?
cookiesowns is offline   Reply With Quote
Old 09-17-2014, 08:16 AM   #187
Shady195
Drives: '13 10 Series FRS #1203
I noticed right after flashing that the throttle felt a little sluggish/unresponsive which I understood was normal as the ECU learned the tune.
After about a week now I still feel like there is still a bit of "dead" unresponsive area and I notice it mostly when Just starting off. Maybe its just me but I felt like stock the minute you touched the pedal you got some immediate input. No other issues otherwise.. I love the sound of the VVT kicking in, makes me giggle even after a week.
Shady195 is offline   Reply With Quote
Old 09-17-2014, 02:27 PM   #188
sprintamx
V2.x tunes definitely have a more "sluggish" throttle response in my experience than any of the 1.3x - 1.5x tunes I've tried. Having said that, I went from a Stage 2 1.59 E85 tune to the V2 Stage 2 93 tune, so there is reduced punch in general. Even so, the throttle lag is definitely pronounced.
sprintamx is offline   Reply With Quote
The Following User Says Thank You to sprintamx For This Useful Post:
Shady195 (09-17-2014)
Old 09-17-2014, 08:02 PM   #189
troek
troek's Avatar
Drives: 2012 Toyota 86
what are your guys' fuel trims that are experiencing this lag?
troek is offline   Reply With Quote
Old 09-17-2014, 08:44 PM   #190
chas3wba0
chas3wba0's Avatar
Drives: Yes
Here's a wild speculation: maybe the throttle calibration is specific to each car, so the cars on which these tunes were created (we will call them the "donor cars") have a specific throttle calibration that is saved on the tune. Some of our cars happen to be closer in calibration to the donor cars, and thus do not experience the throttle "lag" initially after flashing. As for the others, it takes a couple weeks of driving for the ECU to finally recalibrate the throttle positioning and for the "lag" to go away. That would also explain why I get the throttle "lag" after flashing certain maps, and not after flashing others.
As stated, it's just speculation. If there is no such value as "throttle calibration" that can be transferred on the tunes/maps, then I retract my hypothesis.
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 09-17-2014, 09:11 PM   #191
steve99
Drives: FT86
The Drive by wire throttle tables are in the ROM's , OFT tunes change almost nothing in those tables and from memory any changes were at high end not off idle.
Check your fuel trims LTFT and your IAM. If your IAM is less than one thenecu had retardes timing due knock this can cause sluggish response as can high fuel trims over say 5% at idle once car is up to temperature.
chas3wba0 (09-17-2014)
Old 09-17-2014, 09:50 PM   #192
Shiv@Openflash
Drives: 2013 FRS
There really shouldn't be any differences with regards to throttle response in any of our rent maps. Those things haven't been altered in a very very long time. It is possible that the newer B01C/D ROMs require more time to complete TPS calibration. But that is not mapping related.
Old 09-18-2014, 12:57 AM   #193
JB86'd
JB86'd's Avatar
Drives: JAWS
for you guys experiencing that lag, how long has it been since you flashed? I've noticed that it takes a couple hundred miles for the throttle and ecu to learn 100% and be spot on. I'm on B01C so Shiv you may be right.
I'm on stg 1 91 oct. and compared to stock the throttle response is much more instant and smooth, after given enough time to fully learn.
JB86'd is offline   Reply With Quote
Old 09-18-2014, 01:48 AM   #194
2much
I wanna go fast
Drives: 2013 FR-S 6MT
I just bought mine... shipped on the 15th and received today.
did it come with the new maps?
I flashed my first file today, it was the first in the list - stg1 AOC. And I definitely am experiencing the same throttle response as others are talking about. Seems to be much less sensitive, or you have to push the throttle further to hit the threshold.
2much is offline   Reply With Quote
Old 09-18-2014, 02:09 AM   #195
JB86'd
JB86'd's Avatar
Drives: JAWS
Yeah that's because you just flashed it. It hasn't learned, give it at least 50 miles.
The Following User Says Thank You to JB86'd For This Useful Post:
2much (09-18-2014)
Old 09-18-2014, 02:25 AM   #196
2much
I wanna go fast
cool thanks!
Maybe it's just me... but I am having a hard time finding documentation on this thing. Nowhere did it say that the ecu will continue to adjust after the initial startup.
Theres no descriptions of the stock tuning files... I guessed that UEL and EL were for different headers, but what does AOC mean?
The only engine mods I have at this point is a k/n air filter and a perrin inlet tube... out of the 5 tunes that came shipped, i chose the stg1 AOC - is that correct?
Thanks for your patience if you decide to answer my noob questions
OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] Shiv@Openflash Forced Induction 226 03-12-2019 10:26 PM
iOS 8 beta 1 not working on BRZ USB Kids Heart Off-Topic Lounge [WARNING: NO POLITICS] 4 04-13-2015 09:17 PM
v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT Shiv@Openflash Forced Induction 3 07-26-2014 01:23 PM
OFT 1.42 vs 1.5x Beta Who notices a Difference? Cross Software Tuning 11 03-21-2014 04:17 PM
Anyone want to beta-test some door speaker spacers? phenryiv1 Electronics | Audio | NAV | Infotainment 63 08-20-2012 10:02 PM
