Old 09-09-2013, 04:31 PM   #1
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Wink STI BRZ Side Skirts (genuine) Install ST96030AS020-A00
For general purpose here is .pdf version of Install Guide for Genuine STI side skirts (Japanese Only)
Trap63 is offline   Reply With Quote
The Following 3 Users Say Thank You to Trap63 For This Useful Post:
Busybee (06-15-2022), humanshield (09-11-2013), shiumai (09-09-2013)
Old 09-09-2013, 04:44 PM   #2
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
thanks for posting this. anyone have the TRD side skirt install instructions? i'm curious to see if it attaches any differently.
shiumai is offline   Reply With Quote
Old 09-10-2013, 07:42 PM   #3
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Are the 2 'ribs' on the back of the side skirt hollow or solid? Wondering if I could sand them off and then repaint them.
Old 09-11-2013, 04:31 PM   #4
Trap63
Trap63's Avatar
So the interior side near body car is concave and there are two long dual-adhesive strips along all length , no clips therefore.
About painting....this isn't a big issue (ABS), but on top border is there a soft PU adhesive strip (as for the late side of front STI lip) that cannot be painted. I don't know if removing these stripes the skirts will maintains a good profile without any spaces. I suppose yes but not sure.
The top soft stripes are not only for "look" but can avoid entrance of water and so on, causing adhesive stress.
I decide to install as so they are...on black (high quality painted)
Old 10-10-2013, 12:44 AM   #5
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
anyone got the instruction??
Old 11-17-2013, 07:12 PM   #6
ddk168
Drives: brz
Are there also instructions for the front lip and other STI parts? This will be my first attempt at installing anything on a car so can anyone comment on the ease of installation or should I buy the parts and bring it to a professional?
Would also be good to know if there are many holes that need to be drilled (for the STI kits)...
ddk168 is offline   Reply With Quote
Old 11-17-2013, 11:55 PM   #7
OrbitalEllipses
Drives: Attitude
I have a scan of the STI lip somewhere...plenty of drilling required.
Old 11-18-2013, 01:08 AM   #8
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
See attached.
SC10N FR-S #435 of 2500
azian_advanced is offline   Reply With Quote
The Following 2 Users Say Thank You to azian_advanced For This Useful Post:
Lverasky (11-18-2013), shiumai (11-18-2013)
Old 11-18-2013, 04:40 PM   #9
ddk168
Drives: brz
Was gonna let subaru fit them for me, but they charge like 4k for just the STI kits here in Australia, no wheels included or anything.... I could get alot better aftermarket ones for that price or an awesome Turbo kit...
Old 07-26-2014, 02:25 PM   #10
yaguphire
Drives: white-out FR-S
from the looks on the instructions; if im looking at it correctly no drilling is required?? thumbs up? ^^
yaguphire is offline   Reply With Quote
Old 09-16-2014, 03:53 PM   #11
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
No, you need to drill one hole up front, behind the wheel on each side. There's another sheet that has templates, you tape the template on and drill a pilot hole, then increase to 8mm. I think that worked out to 5/16. I forget exactly. Just enough to put the push-clip in.
Another template is used for the center of the side skirt, so you can mark how high it should be on the body (so it doesn't sag in the middle). Took a while to figure out since I can't read Japanese, but then I opened my door and it all fell into place. If I can find a long enough USB cable, I'll get that page scanned in and share it.
Does anyone know where to get a similar double-sided tape that these come with? I got my side skirts used and had to peel it all off. It was much thicker than the 3M tape I can find everywhere, so I doubled up but it's just barely not enough for the rear of the skirts where the emblem is. One side is pulling away and it bugs me. Can't seem to find a thick double-sided automotive tape, or most of them just don't list thickness. I think it's at least 1/8".
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
The Following User Says Thank You to 2point0 For This Useful Post:
JS + BRZ (04-06-2015)
Old 04-06-2015, 10:38 PM   #12
JS + BRZ
Drives: 2010 MS3
Anyone has a linky to that template?
And which 3M tape is good for this STi style sideskirts? I just got one used today.
Old 07-17-2015, 12:54 PM   #13
FTemplar
Drives: BRZ Sport-tech 2013
@Trap63 Here is the english install PDF :
http://techinfo.subaru.com/proxy/772...r2013MYBRZ.pdf
FTemplar is offline   Reply With Quote
The Following User Says Thank You to FTemplar For This Useful Post:
Trap63 (07-17-2015)
Old 07-17-2015, 03:30 PM   #14
Trap63
Trap63's Avatar
Originally Posted by FTemplar View Post
Thanks mate!!!
The Following User Says Thank You to Trap63 For This Useful Post:
FTemplar (07-17-2015)
Side skirts for BRZ cslntuee Cosmetic Modification (Interior/Exterior/Lighting) 23 04-27-2017 12:27 AM
DIY side skirts ML Cosmetic Modification (Interior/Exterior/Lighting) 46 04-11-2016 10:11 PM
Anyone install a front lip and/or side skirts? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 78 04-06-2015 05:08 PM
BRZ Polyurethane CS Side Skirts JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 102 10-02-2014 07:02 PM
Side skirts Ryan86 AFRICA 6 01-17-2013 08:08 AM
