Old 09-09-2014, 11:46 AM   #29
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Originally Posted by Sleepless View Post
Do this test: drive at 6000RPM for a few minutes and see what the oil temp does.
I hope you didn't mean 6k continuous for few minutes? Coz that would be ridiculous...
Fizz is offline   Reply With Quote
Old 09-09-2014, 12:44 PM   #30
jvincent
jvincent's Avatar
Depends on what he means by a "few".
Looking at some data from my lap timer, I'm above 4K 95% of the time, above 5K probably 75% of the time, and above 6K maybe 30% of the time on the track.
6K might be overkill but he ran continuously at 5k or 5.5K that would be a good estimation of track load. Ideally he'd cycle up/down between 5K and 7K.
Old 09-10-2014, 11:58 PM   #31
The Sentinel
Project BRZ-Boosted Autos
The Sentinel's Avatar
Drives: MY14 BRZ
Originally Posted by akyp View Post
I would bypass the throttle body coolant lines as well.
Want data for track/WOT pulls too.
Why bypass the TB coolant lines?
Surely they wouldn't over-engineer the TB to include a coolant loop if it wasn't needed.
Check out my ProjectBRZ YouTube Channel and Facebook Page for the latest reviews, guides and information.
The Sentinel is offline   Reply With Quote
Old 09-11-2014, 12:45 PM   #32
mike the snake
The throttle body coolant lines are there more for heating the TB on super cold mornings than for cooling anything.
Unless you live where it gets super duper cold, removing those lines from the TB won't hurt anything.
Old 09-11-2014, 01:23 PM   #33
eric6
eric6's Avatar
Drives: 93 MR2 Turbo; 2014 BRZ
Is this basically the same thing shown in this thread? http://www.ft86club.com/forums/showthread.php?t=50427
Just a different way of installing the coolant hoses?
eric6 is offline   Reply With Quote
The Following 2 Users Say Thank You to eric6 For This Useful Post:
ecko04 (09-13-2014), rice_classic (11-11-2014)
Old 09-11-2014, 01:26 PM   #34
stonenewt
Drives: BMW 120d
Good info & observations. I'll certainly be look at this cooling route my self, certainly more elegant than the Laminova air/water intercoolers I've used in the past.
stonenewt is offline   Reply With Quote
Old 09-11-2014, 06:51 PM   #35
The Sentinel
Drives: MY14 BRZ
Ahh yes! I forget not everywhere is as mild as Australia!
Old 09-12-2014, 12:59 AM   #36
nyfries
Drives: 14 FRS Whiteout
interesting when can we get some WOT/track analysis?
nyfries is offline   Reply With Quote
Old 09-13-2014, 12:23 AM   #37
nyfries
Would like to know too? Seem identical to the other one but double the price?
Old 09-13-2014, 09:24 AM   #38
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Thanks for pointing out the other thread
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 09-13-2014, 10:15 AM   #39
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Real-time Oil temperature Analysis - Pre/Post Coolant Loop Oil Cooler Install
Basically the parts you need are:
21311AA170
21317AA070
Gates 3/8" Heater Hose. Gates Part #28489
Some clamps
Total should be around $200 after shipping.
Old 09-13-2014, 11:11 AM   #40
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
https://www.subarugenuineparts.com/oe_parts_cat.html
Found good prices here
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
TIE Pilot is offline   Reply With Quote
The Following User Says Thank You to TIE Pilot For This Useful Post:
eric6 (09-13-2014)
Old 09-13-2014, 06:13 PM   #41
nyfries
^^ so the kit op posted is basically the same?
Old 09-14-2014, 07:59 AM   #42
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Yes
oil, oil cooler, oil temp, temperature
The need for an oil cooler when going FI (Temperature Data Inside) spdbydesign Forced Induction 145 11-05-2015 12:02 PM
Notes on injector / maf scalining using full time open loop mad_sb Software Tuning 40 03-03-2014 05:49 PM
Screencast: experimenting with full-time closed loop fueling jamesm Software Tuning 2 12-27-2013 10:19 AM
Perrin oil cooler real world review. Impressions. Racecomp Engineering Engine, Exhaust, Transmission 40 03-18-2013 02:31 PM
