Old 09-13-2014, 02:39 PM   #141
JB86'd
JB86'd's Avatar
Drives: JAWS
Originally Posted by lucid215 View Post
did you get this fixed?
I bought a 30cm obd2 extension off Amazon and leave it permanently attached, no lost connection since then.
JB86'd is offline   Reply With Quote
The Following 2 Users Say Thank You to JB86'd For This Useful Post:
lucid215 (09-13-2014), solidONE (09-13-2014)
Old 09-13-2014, 04:30 PM   #142
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
I agree. I really does appear to be a bad connection in either the OBD2 plug or perhaps even the OFT cable. If you contact Robert on Monday, he can send you a replacement OFT cable. If it still happens, it's definitely the diagnostic port then.
Shiv@Openflash is offline   Reply With Quote
Old 09-13-2014, 04:50 PM   #143
jflogerzi
jflogerzi's Avatar
Originally Posted by solidONE View Post
What would happen if say I was going over 100MPH when this happens with someone close on my tail at the track? Mid corner on a high speed sweeper and the engine decide to bog down suddenly?
What ever gear your in you would be stuck at a max of 4000RPM(car goes into limp mode)
Old 09-13-2014, 05:49 PM   #144
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Yea I have talked to them about it and they said it might be a cable issue. I used to drive with mine hooked up all the time. Now I don't cause I don't want limp mode to kick in from me hitting a bump. The u0155 code is not the issue. It's the u0073
I've had both codes by themselves and at the same time trigger and CEL limp mode. I think if they came with a cable that comes out the side of the connector toward driver door instead of pointing downward it would not as likely cause a connection problem.
I've received a new cable maybe 1 year ago when I first encountered this problem and another one with a new OFT after I cracked the screen on the old one. Replacing the cable seems to fix the problem only temporarily until it goes bad again.
So if I'm going over 6000rpms mid corner it will suddenly cut fuel or however until it drops to 4000... not a situation I want to deal with.
The Following User Says Thank You to solidONE For This Useful Post:
lucid215 (09-14-2014)
Old 09-13-2014, 06:44 PM   #145
BoostedWrbBrz
Drives: 2014 Wrb Brz limited 6m
what on these tunes can I tweak to eliminate the obnoxious cold start these cars have with a cattless setup. Theres no point in the car attempting to warm up cats that I don't even have
BoostedWrbBrz is offline   Reply With Quote
The Following User Says Thank You to BoostedWrbBrz For This Useful Post:
B-R-Z (09-13-2014)
Old 09-13-2014, 07:04 PM   #146
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
See this thread: http://www.ft86club.com/forums/showt...t=55676&page=3
Td-d is offline   Reply With Quote
Old 09-13-2014, 07:51 PM   #147
PMok
Codename: Stitch
PMok's Avatar
I did the same. The OBD2 connector under the dash really appears to be pretty flimsy and I bought the extension cable so that I could leave that plugged in all the time, and just connect/disconnect the OFT as needed to the extension. That way over time if there is wear & tear from doing that, the damage happens to the extension (an easily replaceable component) instead of the car's OBD2 socket or the OFT's connector.
The Following User Says Thank You to PMok For This Useful Post:
JB86'd (09-13-2014)
Old 09-13-2014, 07:59 PM   #148
troek
troek's Avatar
Drives: 2012 Toyota 86
i unmounted my obdII port under my dash from that flimsy metal tab, plugged my OFT cable into and ziptied both in place under the dash, now my cable isnt angled down towards my feet and bent up around. now it goes strait up and comes out by the top of my steering column and up to my dash where my oft is mounted. i used to have this problem as well, and now i havnt had it since ive done that 6 months ago. lots of track days and bumps with this set up.
troek is offline   Reply With Quote
The Following User Says Thank You to troek For This Useful Post:
Old 09-13-2014, 08:00 PM   #149
solidONE
solidONE's Avatar
Just for reference, this is what the cable ends up looking like after a while plugged in and the tablet mounted on the upper left side.
Old 09-13-2014, 08:09 PM   #150
troek
troek's Avatar
yep, thats alot of stress on the connector, which is why i unmounted the OBDII from the metal tab so theres no stress on the connection point.
Old 09-13-2014, 08:54 PM   #151
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
What does the obd2 bracket mount to? Is it possible to stiffen up the mount with home depot stuff?
B-R-Z is offline   Reply With Quote
Old 09-13-2014, 11:16 PM   #152
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
You'd be better off permanently mounting a right angle cable from Amazon to the bottom of the dash and then plugging the OFT into that.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
The Following User Says Thank You to phobos512 For This Useful Post:
JB86'd (09-13-2014)
Old 09-14-2014, 08:18 AM   #153
lucid215
cool im gonna have to try this out. thanks for the info guys
lucid215 is offline   Reply With Quote
Old 09-14-2014, 08:43 AM   #154
solidONE
solidONE's Avatar
I think this is what I'll have to do.
JB86'd (09-14-2014)
OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] Shiv@Openflash Forced Induction 226 03-12-2019 09:26 PM
iOS 8 beta 1 not working on BRZ USB Kids Heart Off-Topic Lounge [WARNING: NO POLITICS] 4 04-13-2015 08:17 PM
v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT Shiv@Openflash Forced Induction 3 07-26-2014 12:23 PM
OFT 1.42 vs 1.5x Beta Who notices a Difference? Cross Software Tuning 11 03-21-2014 03:17 PM
Anyone want to beta-test some door speaker spacers? phenryiv1 Electronics | Audio | NAV | Infotainment 63 08-20-2012 09:02 PM
