Old 09-12-2014, 03:17 PM   #1
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
The new sprintex 335 supercharger
Hi guys, its come to my awareness that in USA there isnt much going on with the bigger 335 supercharger from sprintex. (innovate,cusco,bullet).
I thought id post up a few pictures to show you fitments and clearances as well as how much bigger it is.
jet86 is offline   Reply With Quote
Old 09-12-2014, 03:20 PM   #2
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
So this is what the bigger supercharger looks like, It fits directly on top of the current kit (intercooled or non intercooled).
It comes with the new throttle body inlet pipe to retain the exact same spot as the current kit.
The throttle body inlet pipe is actually a bit bigger (i assume to suit a larger bore throttle body), Another thing i noticed is the fittings are now on the rear of the inlet pipe rather than the bottom, this makes things so much easier as you dont have to remove the whole SC just to change a hose lol.
The Following User Says Thank You to jet86 For This Useful Post:
clayrush (09-28-2014)
Old 09-12-2014, 03:21 PM   #3
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
NOTE: I am sorry i cant do back to back testing as the car is twincharged and that just throws the power increase out the window.
Old 09-12-2014, 03:24 PM   #4
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
The install was a breeze, Remove entire old manifold and sc unit from the car, then swap the units on the manifold and then re-install.
This picture shows the sheer size difference
Another note: the white hoses are just methanol injection i use for cooling my intake charge rather than a air to air intercooler.
Old 09-12-2014, 03:37 PM   #5
The86Ghost
Drives: 2014 FRS (Whiteout)
how much power does it make?
The86Ghost is offline   Reply With Quote
Old 09-12-2014, 03:43 PM   #6
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
Old 09-12-2014, 03:48 PM   #7
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
In conclusion:
The power this has with its normal sized pulley makes more power that its smaller unit does with a 69-70mm pulley. The unit is rated to over 400hp with ease so adding a smaller pulley on it (i have a raceseng 70mm) should bump power up quite nicely.
The downside:
There is a disclaimer on this supercharger which is such: "This supercharger requires a built motor". As far as i know they broke a rod running this kit on regular pump gas when trying to push it as hard as they could. Id assume running e85 would work well with this kit if retaining a stock bottom end.
Old 09-12-2014, 04:27 PM   #8
xwd
There are a couple guys in the US who have the supercharger including one who posted a dyno with it out in Colorado about a month back. I can't seem to find the thread or remember his name though. The numbers were at high elevation and crappy gas so they weren't real impressive.
FYI, Sprintex is now doing their own distribution in the US as Sprintex USA, Innovate is no longer the US distributor. They actually posted a bunch of info on the 335 in the owners thread in the last day.
Old 09-12-2014, 04:52 PM   #9
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
oh thats good news then. i was unsure if innovate would be releasing the 335
Old 09-12-2014, 05:05 PM   #10
Dezoris
Dezoris's Avatar
Better to cut out the middle man on this, be curious to see how Sprintex handles it.
Old 09-12-2014, 05:23 PM   #11
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
as far as im aware, sprintex only recently got a new CEO, He is even contemplating not releasing the 335 to the public but only time will tell
Old 09-12-2014, 05:53 PM   #12
SprintexUSA
SprintexUSA's Avatar
Drives: 2014 FT86
Well, we don't want to fan the flames or try to put out every fire that pops up. We're looking at a limited release of the 335 and that may change. It will be on sale through dealers like the base kit. We don't expect a high volume of sales of these. Our thinking is that the 210 will have a broader appeal being more user friendly.
SprintexUSA is offline   Reply With Quote
The Following 3 Users Say Thank You to SprintexUSA For This Useful Post:
ALB (09-13-2014), brianhj (09-13-2014), xwd (09-13-2014)
Old 09-13-2014, 01:51 AM   #13
brianhj
Drives: 2017 Camaro 1SS
Welcome to the site @SprintexUSA! Good to have you aboard
brianhj is offline   Reply With Quote
The Following User Says Thank You to brianhj For This Useful Post:
SprintexUSA (09-14-2014)
Old 09-13-2014, 12:26 PM   #14
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
@jet86 the link to your build isnt working in your sig? Twincharger
GotBRZ1691 is offline   Reply With Quote
♦♦♦ IN STOCK ♦♦♦ SPRINTEX TWIN SCREW SUPERCHARGER ♦♦ Free Shipping 48 states! ♦♦ FT-86 SpeedFactory Forced Induction 136 09-30-2016 03:44 PM
Khorne's - AUDM Red 86 GTS Sprintex Khorne Member's Car Journals 53 08-31-2014 09:44 AM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 5 03-05-2014 07:26 AM
Sprintex Supercharger Sneak Peak!!! invisage Forced Induction 52 03-03-2013 06:11 AM
