Old 09-12-2014, 05:51 PM   #43
Ubersuber
Drives: BRZ Pearl White
It is very easy to see in what way Subaru changed the 2015 models from the descriptions of the handling.
As for comparing handling characteristics of heavier awd cars to the rwd BRZ by comparing spring rates that is just absurd.
Ubersuber is offline   Reply With Quote
Old 09-12-2014, 07:08 PM   #44
wparsons
wparsons's Avatar
Funny, you're the one that brought it up. Many times over. Let me refresh your memory:
Of course the Impreza is awd so can tolerate more rear roll stiffness under power. Lift off tuck in will be more assertive with higher rear roll stiffness on an awd car but that is generally a benign or even useful effect. The BRZ does not have the front drive forces which reduce the front grip in corners. Subaru seems to have overlooked the need to adjust the rear roll stiffness to compensate for the increased front grip resulting from no drive to the front axle.
flickr
Dipstik-sportech (09-12-2014)
Old 09-12-2014, 07:50 PM   #45
stonenewt
Drives: BMW 120d
My point was only that you don't fix handling problems with tire pressures. You fix handling problems first and then optimize tire pressures.
It all begins with the shape and temperature of the contact patch. You optimize your suspension to keep the contact patch the correct shape and pressure on the road and only then do you adjust tire pressures to fine tune those aspects of the tire. For road use the recommended tire pressure is the minimum pressure you should use. Generally speaking you can increase grip by increasing tire pressure from that recommended setting.
One thing we disagree on: running even a couple of psi low can seriously overheat a street tire especially when running at high speeds or with heavy loads. It is flat out dangerous which is the motivation behind the misguided TPMS regulations (misguided as currently implemented. The idea is sound and the technology is there to properly implement TPMS it just isn't being used properly).
Strange because I have two car manuals on my desk. One of which recommends a higher 3psi pressure when fully loaded. But in the paragraph underneath says that tyre pressures up to 0.3 bar (4.5psi) lower or 0.1 bar (1.5psi) are fine but may cause excessive or uneven wear of the tyre. The other doesn't even give a recommended tyre pressure but rather tells me to keep the tyre pressure between 23 and 35psi on the front and 25 to 37psi on the rear. The latter has several pages of information on choosing and adjusting the tyre pressures, a lot of that is talking about how to tune handling to your preferred feel & balance. Or in your terms 'fix'.
Two interesting points here, first of the manufacture with the narrower tyre pressure range seems to be far more concerned with over pressure than under pressure. Secondly 11-12psi is a huge pressure range if a couple of PSI really will cause overheating issues!
Carcass construction does indeed affect the recommended pressure as does tire section. However, higher performance tires have less sidewall support than lesser tires and lower profile tires with smaller air volumes require higher tire pressures than lesser tires. This is in general, there may be exceptions.
Actually they're all over the place! Let's take my 120d's 225/40R18 tyres. I can go from economy/touring tyres to high performance sports/fast road tyres. As a general rule er well.. it's all up in the air really! AD08s & Sottozeros like the same high pressure. The PSS like lower pressures. P7 Blue like high pressures about half way between & P7 work at the same sort of pressures as the PSS.
stonenewt is offline   Reply With Quote
The Following User Says Thank You to stonenewt For This Useful Post:
wparsons (09-13-2014)
Old 09-12-2014, 10:40 PM   #46
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Don't feed the troll. Use the ignore feature.
The Following 3 Users Say Thank You to EAGLE5 For This Useful Post:
Dipstik-sportech (09-13-2014), D_Thissen (09-13-2014), unsurety (09-13-2014)
Old 09-13-2014, 11:59 AM   #47
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
I was gonna say just that. On the bright side, a lot of people post insightful responses to him, so it's not all for nothing.
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline   Reply With Quote
Old 09-13-2014, 11:10 PM   #48
Ubersuber
Interesting viewpoint. Occasionally, those responses are useful but often they are full of misinformation. Lots of experts on this forum.
Old 09-13-2014, 11:18 PM   #49
Dipstik-sportech
Dipstik-sportech's Avatar
There are also people who think they're experts and just spew nothing but misinformation, such as a certain suberman.
The Following 4 Users Say Thank You to Dipstik-sportech For This Useful Post:
chrisl (09-19-2014), D_Thissen (09-14-2014), jamomatt (09-14-2014), wparsons (09-14-2014)
Old 09-14-2014, 09:21 AM   #50
reardrv
Drives: 2013 Subaru BRZ
I have 225/45R17 PSS's on my BRZ and have noticed that do to the much stiffer construction than the stock tires the center on them balloons out at the stock 35PSI tire pressure to the point where the shoulder of the rear tires does not contact the pavement. There was definitely a sway and grip feeling from the rear at 35PSI. Dropping to 34 PSI front and 32 PSI rear cold tire pressure got rid of that feeling. These tires seem to like lower pressures than the stock tires. Even when I autocross I'm at 36 PSI front and 34 PSI rear hot compared to 42 PSI front and 38 PSI rear when I was on stock rubber.
reardrv is offline   Reply With Quote
The Following 4 Users Say Thank You to reardrv For This Useful Post:
Ferrari (09-14-2014), stonenewt (09-14-2014), tYtEn86 (09-14-2014), wparsons (09-14-2014)
Old 09-14-2014, 09:27 AM   #51
wparsons
wparsons's Avatar
Like when you claimed you should NEVER run less than 35psi in any tire on this car because it's not safe?
Useful real world experience that should help the OP!
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
Akari (09-15-2014), Ferrari (09-14-2014)
Old 09-14-2014, 09:34 AM   #52
stonenewt
Drives: BMW 120d
Oh look someone doing some measurement & evaluation based setup & finding that lower tyre pressures work better. This also matches my findings with PSS on a completely different car - PSS tyres work better at lower pressures.
Old 09-14-2014, 05:33 PM   #53
Ferrari
Ferrari's Avatar
Drives: Taking the bus
Lowered pressure to 34 in the rear, we'll see if it makes any difference. Thanks for the advice.
Ferrari is offline   Reply With Quote
Old 09-14-2014, 08:54 PM   #54
wparsons
wparsons's Avatar
Put a strip of chalk all the way across the thread on all four wheels and drive it like 100 feet straight at slow speed. See where the line is worn off. If it's just in the center, keep dropping the pressure until it's even across the tread.
If it's not wearing off at all, drive further. Just make sure it's straight, going around a corner will alter the contact patch.
flickr
D_Thissen (09-14-2014), unsurety (09-15-2014)
Old 09-15-2014, 01:00 AM   #55
Jrdad
Jrdad's Avatar
Drives: 2013 Scion FR-S 6M Argento
When I first got my MPSS in 225/45 I could turn left at a light in second gear and go wide open throttle half way through the corner on cold tires at 6*C in an attempt to drift, and the car would just stick. I was running 32PSI. Now I've overheated the tires too many times and have spun them shifting to third. All the fun of the primacys without the major difference when it rains now
Jrdad is offline   Reply With Quote
Old 09-15-2014, 01:55 AM   #56
troek
troek's Avatar
Drives: 2012 Toyota 86
im assuming this wouldnt apply to someone running aggressive camber?
troek is offline   Reply With Quote
Michelin Pilot Super sport vs hankook vs nitto ft86me Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 52 03-21-2015 04:43 PM
How durable are Michelin Pilot Super Sport on the track? Ferrari Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 08-21-2014 11:55 AM
Michelin Pilot Super Sport 225/40/18 FastLane1000 Wheels and Tires 2 09-03-2013 12:04 PM
Michelin Pilot Super Sport - 245/35ZR18 Staf00 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 08-30-2013 06:13 PM
Michelin Pilot Super Sport 17 inch DieselBoXXer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 07-05-2012 10:17 PM
