Old 08-23-2014, 02:18 PM   #43
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Originally Posted by zdr93523 View Post
This is not an accurate statement or analogy. The transmission in the twins is sourced from Lexus and they have a TSB with a warning that use of fluid other than GL-5 will cause manual transmission damage. Toyota/Subaru just cheaped out on the fluid and I suspect this is why we are seeing lots of grinding issues. Subaru is notorious for this. Subaru manufactures Extra-S, which is excellent GL-5 fluid, but does not have it properly loaded in the Subaru supply system, so dealers don't stock it even though it will prevent problems in WRXs and STis and is a solid upsell. Instead, they just eat warranty repairs like the trans in my BRZ. Also, they do not specify which oil to use when they fill their engines and transmissions when new. You might get valvoline in one car, and something else in the next. It is just poor business practices, not that the trans was engineered to accept GL-3.
The transmission in the BRZ/86 shares nothing in common with any transmission ever used in a Lexus in North America. The transmission/TSB you are referring to is related to the RA62 (Aisin AY6) in the IS250, which is a completely different design than the one in the Zx6 (Aisin AZ6).
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 08-23-2014, 02:21 PM   #44
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
Jeff
I believe this is inaccurate. There's a reason why Subaru and Toyota replace and not rebuild the transmissions. Those who have rebuilt due to warranty denial have had source parts from Lexus because the internals are not in the Subaru parts catalog.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 09-01-2014, 03:25 PM   #45
axelo
Drives: Whiteout frs
At 29,000
At 29k, shifting clunks are harsher...i notice oil has lost its protective properties, shifting is different compared to 2 yrs ago...thus below is my Labor day fun...
axelo is offline   Reply With Quote
The Following 2 Users Say Thank You to axelo For This Useful Post:
flippy (09-12-2014), zdr93523 (09-01-2014)
Old 09-01-2014, 03:39 PM   #46
Fastbrew
Drives: 2014 Pearl White BRZ
I am putting in a full load of Pentosin MTF2 in the next couple weeks. So - we'll see how that goes.
Fastbrew is offline   Reply With Quote
Old 09-02-2014, 06:51 PM   #47
axelo
Do your transmission oil change now!!
Did today the change to Motul... Trans oil should be done sooner than specified on manual IMO...i have never launched my car, drive decent and at 29k oil was horrible, there's a huge change on the feel specially at 1st to 2nd shift, clunk is solid, strong...before, clunking was like "going to break" clunk, now is softer and smooth
I've not tried any oil other than stock, but i highly recomend by this experience to use motul 300 as soon as possible, your trans will last longer working properly.
The Following User Says Thank You to axelo For This Useful Post:
zdr93523 (09-02-2014)
Old 09-02-2014, 07:42 PM   #48
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
I cannot stress this enough, when I changed my rear differential fluid with Motul 300, my shift felt smoother, my clutch engagement point felt smoother, AND i also got rid of all those black gooey metal flakes that was magnetized onto the drain plug.
LeeMaster is offline   Reply With Quote
The Following User Says Thank You to LeeMaster For This Useful Post:
Old 09-12-2014, 02:23 PM   #49
Jeff Lange
Jeff Lange's Avatar
The only manual transmissions ever used in Lexus models in the USA were the E52 (ES250), W58 (SC300), W55 (IS300) and RA62 (IS250). None of which are related to the Zx6.
That said, in other countries like Japan and Europe, the Altezza/RS200/IS200 did use the J160 which is very similar to the TL70 in the FR-S/BRZ.
So in North America, no, in other countries, yes.
I don't know about Subaru not listing internals for the TL70 separately, but Toyota does.
Jeff
Automatic Transmission devinclfalcons Engine, Exhaust, Transmission 60 04-29-2014 09:42 PM
HKS SEQUENTIAL TRANSMISSION for the 86 ESBjiujitsu Engine, Exhaust, Transmission 20 10-30-2012 05:28 AM
Transmission? Pplater AUSTRALIA 1 06-05-2012 07:17 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
Which Transmission ? gatchaman Engine, Exhaust, Transmission 15 10-29-2009 12:48 PM
