Old 09-12-2014, 01:16 AM   #183
Atropine
Drives: 2021 Toyota Supra 2020 4Runner
Originally Posted by DylanFRS View Post
Did he tell you his idea for a perpetual motion machine?
LOL no.
Not wanting to "give it away", but it essentially boils down to an extremely efficient turbo system that would reduce friction and lost energy.
Now as far as his claim on not stressing internals...I don't see it being able to do that.
But more efficient engines/turbo systems are doable.
But I also think it goes into the classic car guy saying...
Speed, inexpensive, reliable... Pick two.
Also my point is...of course someone who can fabricate parts them self or they work at a junkyard and can get parts for super cheap...yeah they can do things for cheaper than a guy who does not have those alternatives.
While in military...I got to fire all kinds of big weapons for "free". That doesn't mean that if I want to unload with an M-60 or a SAW (think belt-fed M-16) for an hour...it will cost me a lot in rental fees and in ammo.
The whole, "build a twin to be a Z06 beater" falls into that same thing.
Sure, if you dad is the guy who runs Cobb tuning...I bet you can get a "deal".
Just like how CJSporl can keep dumping money into his BRZ...some people just have more options for various reasons.
Atropine is offline   Reply With Quote
Old 09-12-2014, 07:18 AM   #184
Twin4Life
Twin4Life's Avatar
Drives: '14 Genesis Coupe 3.8 Grand Touring
I re-tooled at home, my Huffy has become a Ducati killer.
Twin4Life is offline   Reply With Quote
Old 09-12-2014, 12:06 PM   #185
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
Originally Posted by Atropine View Post
LOL no.
Sure, axial compressors are cool (and very efficient at large scale, though they generally don't scale down well due to tip clearance issues and the large stage count required to get a good compression ratio), but that still doesn't avoid the isentropic heating, it'll still require an intercooler, and the air coming out the back will still be very hot.
In addition, modern turbos run at or near their peak efficiency point already run at >75% efficiency. Sure, a really good axial compressor can maybe do better (although I'm not convinced of that - see the next paragraph for details), but you're trading off a lot of complexity and cost to achieve that. An axial flow compressor can only achieve a pressure ratio of 1.2-1.3 or so per stage, you'll need a 3-5 stage axial compressor to get 15-20psi of boost. Efficiency is highly dependent on tip clearance too, which will require some pretty high end materials and machining (since you want to maintain as close to zero tip clearance as possible while spinning at very high speeds and across a wide range of temperatures).
In addition, although in large applications (jet engines, power plants), axial compressors are without question more efficient than centrifugal, I'm not convinced that's the case for small ones. Issues with achieving the right spin speed and tip clearance on a small compressor can wipe out almost all of your efficiency gains, and you also have a much longer driveshaft to balance and support at extreme RPM (and if it starts flexing, you can crash your blades into the housing, since you want as little blade clearance as possible for efficiency). The physical size of an axial compressor is also a lot larger than a centrifugal for the same flow and pressure ratio. These factors are enough of a problem even on larger engines that many smaller turbine engines (especially helicopter and turboprop engines) actually still use centrifugal compressors. The Pratt and Whitney PT6 is a good example of this.
That having been said, if you do get around to making this design work, I'd be curious to see pictures/details. Even though I doubt the gain is worth the amount of effort it will take, it still sounds like a fun engineering project.
chrisl is offline   Reply With Quote
Old 09-12-2014, 12:56 PM   #186
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
The axial compressor, was NOT what I was referring to..
The axial compressor supercharger is NOT what I was referring to.
It's an entirely different project.
Jaden
Jaden is offline   Reply With Quote
Old 09-12-2014, 01:06 PM   #187
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
Is it a comprex? lol
murdoc is offline   Reply With Quote
Old 09-12-2014, 01:35 PM   #188
Jaden
Road-hole
I made a huffy a Ducati Killer...
I easily made a Huffy a ducati killer, by strapping a parachute on my back...
Jaden
Old 09-12-2014, 10:04 PM   #189
inertia
inertia's Avatar
For all you Z06 lovers and engine-swap-haters out there... look up some of these fabulous builds:
@JoeDrifter @jet86 @Drift&Drag @WTF @slicktop @puma @OmarGC @SmsAlSuwaidi @FullBlown
inertia is offline   Reply With Quote
Old 09-13-2014, 12:58 AM   #190
fatoni
its not that those builds arent great. its just that they arent going to go as fast as the vette for as long as the vette while being as cheap as the vette
Old 09-13-2014, 01:53 AM   #191
abraxis
Drives: many
Fwiw, the article I recall had an Evo with about $12k in mods beat a stock GTR round the track.
Twins are obviously superior to any low mileage C7's with blown engines, faulty brakes and airbags. Go GM! /thread
abraxis is offline   Reply With Quote
Old 09-13-2014, 02:58 AM   #192
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Here's my c7 z51 (not z06 but who cares), and my frs.
Size:  311.6 KBName:  ImageUploadedByTapatalk1410589761.441116.jpg
Both are amazing cars. The only point I'm going to make about these cars is this: The frs is liked more by guys, and the corvette is liked more by the ladies. No matter what modifications you do to your frs, it's probably not gonna pull much ***** compared to the corvette (unless you like high school girls). Let's not forget about resale value and all that junk. The frs, no matter how much money you put into it, will never be even a base model c7 stingray. They feel totally different in good ways. Anyway, enjoy the hurt feelings.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 09-13-2014, 10:16 AM   #193
Mikem53
Drives: FR-S 6MT
You have to laugh at all the ignorant GM haters who never owned one or even drove one complain about them and compare them..
Having owned several late model vettes, including 2 Z06's. I can tell you from experience that these are awesome machines that are in another league than the twins. They have a much higher mechanical grip and the power to utilize it.
The suspension is far more sophisticated with braking to match. The LSx engines are bullet proof and get descent mileage especially considering the power levels.
They have torque everywhere at any rpm.. A torque tube houses the driveshaft
And makes the car extremely rigid.. And it's not a unibody, but a full frame.. No flexing anywhere.. For those who don't like the body style... Just have a look underneath the car.. It's really pretty under there with a double wishbone SLA setup, aluminum suspension pieces.. You can see where the money was spent..
It's more racecar than car..
Many don't realize how well vettes hold their value.. These cars are very inexpensive to own over the course of ownership.. My vettes cost me a little more to own than my wife's Hondas over the years.. Except for the cost of tires.. These cars are extremely and surprising inexpensive to own..
World class machines at a reasonable price..
I love my FRS for its simplicity and minimalistic design.. It's a better car to drive in the real world as an everyday DD.. But it's no match for the performance limits of the vette..
Mikem53 is offline   Reply With Quote
Old 09-13-2014, 11:51 PM   #194
inertia
inertia's Avatar
Thumbs up
Originally Posted by CK_Bladesmith View Post
Anyway, I will enjoy my trips back to the dealership over the next several months.
Don't you already know the first year of a revised body style will have inevitable bugs or should I say recalls. Time to head back to the GM dealership and address those "factory" defects.
http://www.motorauthority.com/news/1...rolet-corvette
Old 09-14-2014, 12:11 AM   #195
CK_Bladesmith
Drives: Raven FR-S
Twins vs 2015 z06
How many factory defects do the twins have? It's in it's second model year and people are still having problems. Same story and no one cares.
No hate on the twins....I've had my frs since June 1 2012 and have enjoyed it as much as my c7, especially since the frs is supercharged. Either way, you can't compare the twins to a new vette....base, Z51, or Z06.
Edit: Mine is a 2014 model year c7, so it's not plagued with the issues you've stated above, or any issues at all with mine.
Old 09-14-2014, 12:29 AM   #196
abraxis
Drives: many
You have to laugh at all the Corvette owners that claim they never have issues at all. I'd say anyone who could stand sitting in the interior of a C6 or older already has a low bar and high tolerance for piss poor quality.
Nissan to enter 2015 24 Hours of Le Mans + 2015 FIA WEC mav1178 Other Vehicles & General Automotive Discussions 1 05-23-2014 10:47 PM
2015 86/BRZ vs 2015 Eclipse botbs FR-S / BRZ vs.... 55 04-16-2014 04:07 AM
Is it just me or Twins are everywhere now? DrawingWaves Scion FR-S / Toyota 86 GT86 General Forum 93 03-20-2014 09:31 PM
The twins pnig BRZ Photos, Videos, Wallpapers, Gallery Forum 2 02-06-2014 06:52 PM
The Twins!! iaclimber4 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 10-03-2013 02:20 AM
