Old 05-10-2014, 03:58 AM   #15
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Anyone know if this will clear STI brembo calipers?
Fizz is offline   Reply With Quote
Old 05-11-2014, 12:26 AM   #16
Pish
#teamswagoi
Pish's Avatar
Drives: 2014 Raven FR-S Monogram
Lookin' good !
Pish is offline   Reply With Quote
The Following User Says Thank You to Pish For This Useful Post:
FRSKEV (05-11-2014)
Old 05-11-2014, 12:34 AM   #17
gramicci101
Off Topic
Originally Posted by The Tengu View Post
On Tire Rack look under 2003 VW Jetta GLS for 17x8 +35 in 5x100 for this wheel.
This is by far the most irritating "feature" Tire Rack has. How about instead of limiting my selection to what they think will work for my car, they let me look at all the sizes and offsets and choose for myself?
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
dradernh (07-25-2014), smg1138 (07-04-2016)
Old 05-14-2014, 05:54 PM   #18
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Old 06-30-2014, 09:04 AM   #19
Talus1
Talus1's Avatar
Drives: '06 Cayman, ‘23 BRZ Sport-Tech
Originally Posted by FRSKEV View Post
These are 17x8 +35 OZ Ultraleggera custom powdercoated metallic gray. Tires are 225/45/17 Kumho 4X.
How do you find the steering with the +35 offset? I'm thinking about getting some 17x8 720Form GTF1s, with 225/45R17 PSS or ExtremeContact DWs, but I'm concerned because the GTF1s
only come in the +35 offset. Steering feel is the main thing i love about my BRZ and I don't want to mess with it.
Talus1 is offline   Reply With Quote
Old 07-01-2014, 06:46 PM   #20
FRSKEV
Drives: FRS
Honestly the difference is barely noticeable and the feel of the car doesn't go away, I guess a little heavier steering but not enough to make it negative. I have 2 other sets of wheels and tires with wider stickier tires and love having even more grip.
FRSKEV is offline   Reply With Quote
The Following User Says Thank You to FRSKEV For This Useful Post:
Talus1 (07-01-2014)
Old 07-25-2014, 07:00 PM   #21
D_Thissen
D_Thissen's Avatar
Will this set up work a car with stock suspension?
Old 08-01-2014, 06:14 PM   #22
FRSKEV
Drives: FRS
Sure will!!
Old 08-01-2014, 08:43 PM   #23
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
I'm tempted to get these. Any poke with that offset? I can't tell in the pictures. I'd love to wrap them in some 245/40...
Edit: Also do you need hubcentric rings? I'm guessing since you have to switch to a different car just to find the +35 on tirerack they don't fit our car.
Nevermore is offline   Reply With Quote
Old 08-04-2014, 11:02 PM   #24
FRSKEV
Drives: FRS
There's no poke with the small drop from the springs, don't remember if they poked out on stock springs but sure aren't an aggressive wheel size or offset
Nevermore (08-05-2014)
Old 08-29-2014, 08:05 PM   #25
tunami
tunami's Avatar
Drives: 2013 FR-S 6spd Whiteout
@FRSKEV This looks really good on the car! Do they come out past the fenders? I'm deciding on these and don't know whether to get +35 or +48? What made you choose +35?
tunami is offline   Reply With Quote
The Following User Says Thank You to tunami For This Useful Post:
FRSKEV (09-02-2014)
Old 09-02-2014, 12:12 PM   #26
FRSKEV
Drives: FRS
They don't stick out past the fender, I had these wheels on my previous car an srt-4 and luckily they are the same lug pattern so I kept these. But even if I didn't I would have still bought the same offset because I personally don't like the pushed in look of the higher offset wheels.
It's really not an aggressive wheel size or offset at all.
2013 Scion FR-S
Autox - Track
Paint Protection Film Pro
Old 09-08-2014, 10:37 PM   #27
D_Thissen
D_Thissen's Avatar
Ordered these the other day in silver for my Argento.. Cant wait to get them!
Old 09-11-2014, 11:58 AM   #28
Createddeleted
Drives: 2014 BRZ - 2004 GLI
Any idea on how much camber can safely be run with this setup? I'm not looking to run more than -1.5. I believe it would clear but I just wanted to see if anyone was running it.
Createddeleted is offline   Reply With Quote
Wheel Directory: OZ Ultraleggera 18x8.0 +48 AkaJabari Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 54 11-02-2022 03:02 AM
Wheel Directory: OZ Ultraleggera 17x8.0 +48 Mageep Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 104 04-11-2021 12:03 AM
Wheel Directory: XXR 527 17x8.25 +35 MF_DEUCE Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 41 12-25-2019 06:37 PM
Wheel Directory: XXR 535 17x8.25 +35 PineappleFriedRice Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 10-24-2014 08:27 PM
Wheel Directory: XXR 522 17x8.0 +48 STEVEOSTI Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 12-13-2012 12:39 AM
