Old 10-10-2013, 10:20 PM   #57
StancedLifestyle
Drives: 2014 Asphalt FR-S
Originally Posted by ill roller View Post
I've only had my car 2 weeks, but as far as I'm concerned that's two weeks too long to be riding around on stock suspension... It's not that the car didn't ride fantastic from the factory, because it did, but I can't stand the look of wheelgap.
A few days after I picked my BRZ up I started researching coilovers. I've owned lots of different coilovers in the past, Ground control, Tein, and H&R. And I've driven/rode in lots of friend's cars with Megan, KW, Bilstein, Moton, Fortune, etc. As of lately though, my last few cars I've run Stance GR+ or Stance Super Sports on, and loved them, as seen here:
Prior to using Stance coilovers on these cars, I was a huge supporter of Tein Monoflex coilovers because they rode great, and handled even better. The downside was that they didn't ever go as low as I wanted without getting rid of some of the preload on the springs, which in turn ruined the ride and the handling that I loved them for... This was one of the biggest things that got me interested in Stance coilovers, everyone that I knew who had used them said they went LOW and retained a good ride... And it turned out they did. It also didn't hurt that Stance is a company that is local to me, which meant that their already great customer service would be even better since I could deal with them face to face.
So when the time came to pull the trigger on coilovers for this car, the Stance Super Sports were at the top of my list. I would have loved some KW v3's, but the cost was out of my budget, and the car is just my daily driver/occasional drift car, so I wanted something that would improve handling, let me slam the car, and keep the ride as close to stock as possible. There were other options that were cheaper, and other options that may have looked as good on paper for the same money, but past experiece, and my trust for Stance to both make and stand behind a quality product meant that they were getting return business from me... It also doesn't hurt that they had them in stock, and I went to pick them up in person instead of having to deal with some shady 3rd party business and wait for shipping.
As for the coilovers themselves, their rates are 6K front and 6K rear, 15-way dampening adjustable, inverted monotube, adjustable camber plates, and they come with adjustable swaybar endlinks to avoid binding once the car is lowered.
So, on with the install:
BRZ Stance Coilover Install by AJ Gillett, on Flickr
The stock rear suspension was a piece of cake to remove on this car for anyone that's done coilovers before. One bolt on the bottom, two up top, and once everything is unbolted you either have to unbolt the control arm or have someone of a decent weight stand on the hub to get the stock suspension free. There is one piece of very important information that I wish I had known ahead of time though. On the drivers side of the trunk there's a trunk pop button on the liner that needs to be unplugged in order to peel the liner away enough to get to the suspension bolts. If you unplug this, DO NOT CLOSE YOUR TRUNK. I lucked out that I had the taillights out of the car to paint them, because I closed the trunk, and could not get it to open until I reached in the tail light hole and pulled the emergency release.
Stock parts coming out:
The two side by side:
That's with the coilover at max low by adjusting the lower mount, but with a good amount of preload on the spring. I could probably reduce the preload a bit without drooping the springs and get the car to sit lower still.
And the coilovers are in just as easy as they came out, just slip them in, tighten three bolts, and you're done:
The front was a little bit trickier, but still a very straightforward removal/install. Three nuts on the strut towers, two attaching the coilover to the knuckle, a swaybar endlink, and a series of bolts and clips attaching brake lines and wiring to the coilover. I was warned by the guys at Stance that the clips would be somewhat annoying to remove in one piece, but even that didn't prove to be too much hassle.
Here are the front coilovers with the adjustable swaybar endlinks. I opted to not put these all the way down since I wanted to avoid rubbing with the tire size I currently have.
Installing the fronts went as seemlessly as the factory stuff came out. At this height it was a two man job to get the knuckle to line up with the coilovers. All of the holes for the bolts and clips lined up perfectly, and popped right in. The swaybar endlinks left me scratching my head for a minute. They were both set to the same length, but once the endlink was installed on one side, the other wouldn't line up. We realized that there was load on the sway bar, and we had to jack up the opposite side up to get the holes to line up... And just like that, the job was done. I was really impressed with the ease that everything fit back together in front even with the coilovers this low. I figured at a certain height things may start to not line up so good, but I guess they planned for people like me.
Complete!
Having been driving on these for the last couple days, I couldn't be happier. More than anything I'm blown away by the ride, especially at this height. It rides about as good as stock over normal bumps and such, over really big bumps you can feel that it's more firm, but it is by no means going to shatter your hip like some coilovers I've driven on. Handling feels great from what I've felt so far, but I also have a wheel/tire change to take into account, so I can't be sure how much the coilovers are doing, and how much the bigger tires are doing. Regardless, the car feels much more flat around turns, and much more planted with quick direction changes. It seems very ideal for someone like me that just wants to street drive with occasional track days... They may not be the ultimate performer, but not everyone wants that. What's important is that no one attribute of the car's suspension has been comprimized in order to make another better. They feel awesome, they seem to handle great, and they go nice and low.
OMG! That was your FIT! You got a FRS/brz/gt86 too? me too!
This is my fit. I just sold it 3 weeks ago and got a 2014 asphalt frs. Owned the fit for a year, having some regrets selling it but whatever.
StancedLifestyle is offline   Reply With Quote
Old 10-15-2013, 09:02 PM   #58
ijuliusx
ijuliusx's Avatar
Drives: 2013 Scion FRS (ARGENTO)
which level of dampening are you set up in front and rear?
and i installed mine couples days ago, but mines been making a clunking noise for some reason, tighten all the bolts and and the endlinks, it went away but kind of came back after couple days.
and endlinks suppose to be installed both facing the opposite way right??
i found another diy that says it should be installed both facing the same direction.
ijuliusx is offline   Reply With Quote
Old 07-16-2014, 05:02 PM   #59
Gooby
Gooby's Avatar
Drives: 17 Toyota 4Runner, 14 Subaru BRZ
Rear's not as low as fronts?
Are your rears as low as your fronts? I seem to have a bit of thread left to keep going down but it stops. My rears are like an inch higher than the fronts. I do have the front camber maxed out also. I know camber makes a difference but that much? I just can't seem to get the rear to tuck the stock 17 tires. Have you went any lower since installation? Thanks man!
Gooby is offline   Reply With Quote
Old 08-15-2014, 10:28 PM   #60
drift94
Drives: 2013 scion frs whiteout
Does it matter what side they go on. I took them out of the box and mixed them up
drift94 is offline   Reply With Quote
Old 09-10-2014, 08:10 PM   #61
Jeeper_x
Jeeper_x's Avatar
Drives: Sweetness #4
Stance Super Sport coilover install/review
Don't put on these crappy ass endlinks!
Jeeper_x is offline   Reply With Quote
The Following User Says Thank You to Jeeper_x For This Useful Post:
07jazzrs5gt86 (10-06-2014)
Old 10-05-2014, 10:10 PM   #62
07jazzrs5gt86
Drives: Firestorm 86
Would stock endlink work fine with these stance coilovers?
07jazzrs5gt86 is offline   Reply With Quote
Old 10-06-2014, 11:09 AM   #63
illmattic
illmattic's Avatar
If you set your car up at stock height then yeah, but if you lower the car then you should go to a shorter endlink. Either use what Stance supplies or get something aftermarket. You could also cut and re-weld the OEM ones to shorten them. I ran that set up for over a year and it was fine but I switched over to Whiteline a few months ago.
-Flickr-
IG @illmattic86
illmattic is offline   Reply With Quote
The Following User Says Thank You to illmattic For This Useful Post:
Old 10-06-2014, 11:18 AM   #64
07jazzrs5gt86
Originally Posted by Jeeper_x View Post
Attachment 90517
Attachment 90518
Attachment 90519
How long did you have them on for them to fo bad like that ?
Did you track/auto cross the car?
Old 10-06-2014, 12:29 PM   #65
07jazzrs5gt86
Would it be fine to use stock one for 2-months as dd about 2k mile before i get a adjustable setup?
Also i got my stance setup used and just notice the wear as posted above should i just use it temporarily as mentioned above?
I'm getting some f/r sway bars + endlinks under bushing in a few months so i was thinking of doing that alittle later since i don't track autocross my xar. I really want to get rid of that wheel gap asap as that's very annoying to me now
Thanks
Old 10-06-2014, 03:20 PM   #66
illmattic
illmattic's Avatar
Thanks
Yeah I hate wheel gap so I understand. I think it will be fine to run the stock ones for a bit but they may bind alot and they also may hit the control arm. Maybe some one that ran that set up before can chime in.
-Flickr-
IG @illmattic86
Old 10-06-2014, 04:29 PM   #67
07jazzrs5gt86
So should i even attempt the wore out ones that come with the kit better than using the stock that can cause binding?
Old 10-07-2014, 10:56 AM   #68
illmattic
illmattic's Avatar
The main thing you need to worry about with the oem links is them hitting the control arm. If they clear then your good and just wait until your whiteline ones come in. But again this really depends how low your are trying to go. Just dropping it like an 1.5" it should be fine but if you go like 4" then you might run into trouble.
-Flickr-
IG @illmattic86
07jazzrs5gt86 (10-07-2014)
Old 10-07-2014, 09:16 PM   #69
07jazzrs5gt86
Got it installed today and used the stock endlinks. There's some clearance to it so i decided to go with for now. Took it for about 70miles test run and it felt great and didn't notice anything odd sounds. I set it to max soft setting for now but will definitely give it about 5-7 more clicks so it can be alittle firmer and to go from there.
Wonder what others set it to for dd/spirit driving?
Old 10-08-2014, 07:59 AM   #70
07jazzrs5gt86
When adjusting height and dampen settings should I jack up the car or leave it on the ground?
D2 RS/K-Sport Kontrol Pro Coilover Review DarrenDriven Suspension | Chassis | Brakes -- Sponsored by 949 Racing 62 04-08-2016 02:32 PM
Stance Super Sport Coilovers FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 06-28-2015 09:59 PM
►►Stance Super Sport Coilovers◄◄ Free Shipping - Photos and Video FT-86 SpeedFactory Brakes, Suspension, Chassis 43 01-31-2013 10:17 PM
Lutz Performance | STANCE (Super Sport & Supe Sport+) coilovers Diego@lutzperformance Brakes, Suspension, Chassis 1 10-04-2012 02:43 PM
