Old 09-10-2014, 02:13 PM   #1
Toyota GT 86
Toyota GT 86's Avatar
Drives: Toyota GT 86
Question Enkei RPF1 17x8 or 17x9 ¿?
Hello, people who ride enkei RPF1 in 17.... What wide should be better for autocross and trackdays ? 17x8? Or 17x9? I really would like to go with 17x9 but I don't know if it is to wide for the power and torque of my car (should be tuned with complete exhaust soon)...
I would like to achive the best times and performance and wILL be my ONLY FOR AUTOCROSS AND TRACKDAYS WHEELS . With SLICKS tyres,.
Thanks
Toyota GT 86 is offline   Reply With Quote
Old 09-10-2014, 03:31 PM   #2
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
I vote for 17x9 since it slightly stretches the 235-245 tires that results in stiffer sidewalls and more steering response
glamcem is offline   Reply With Quote
Old 09-10-2014, 03:40 PM   #3
CSG David
CSG David's Avatar
Depends on width of the tire and what class you want to run in.
The Following User Says Thank You to CSG David For This Useful Post:
zdr93523 (07-05-2015)
Old 09-10-2014, 04:16 PM   #4
Toyota GT 86
I would go with the proper straight width for both ... I mean in the case I found the best tire width option for the wheel for example 225 or 235 for the 17x8 or in the other hand 235 or 245 for the 17x9... What would perform a bit better ? Wider wheels but heavier? Or not so wide but widier enought and a but lighter?
Old 09-10-2014, 04:47 PM   #5
CSG David
CSG David's Avatar
It's still dependent on the tire type and size. We've ran 225 EHP tires on 17x9 wheels since EHP tires tend to run much wider than your standard street tire. R-Comps in the 225 size tire can also be much wider than street tires in general. Some sanctions will disapprove of wider wheels than a certain width so just check your organizations in case there are some sort of rules.
The suggestion is 17x9 for the potential to upgrade.
Old 09-10-2014, 04:50 PM   #6
wparsons
wparsons's Avatar
Also watch the offset, 17x9+45 will leave you with very little room to adjust camber on stock diameter springs unless you buy camber plates.
flickr
CSG David (09-10-2014)
Old 09-10-2014, 04:55 PM   #7
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
17x9 +35.
tigermack is offline   Reply With Quote
The Following User Says Thank You to tigermack For This Useful Post:
Toyota GT 86 (09-10-2014)
Old 09-10-2014, 05:08 PM   #8
Toyota GT 86
I run tein sreet flex coilovers, so if I choose 17x9.... Now what offset should be ? Hahaha
Old 09-10-2014, 05:18 PM   #9
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
-Jack Burton
The Following User Says Thank You to tahdizzle For This Useful Post:
Old 09-10-2014, 05:24 PM   #10
CSG David
CSG David's Avatar
+35 and +45 will work just fine.
Old 09-11-2014, 05:24 PM   #11
haison
Drives: 2014 Subaru BRZ
17x9 +35 if you plan on getting BBK later down the road.
haison is offline   Reply With Quote
Old 09-16-2014, 03:51 PM   #12
glamcem
glamcem's Avatar
that
17x9 +35mm will also help eliminating rubbing inside the tire and 9" wheel is a great size for 235 and 245 tires..
Old 09-16-2014, 05:22 PM   #13
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Unless you have some serious power, 17x8 with a 215 or 225 sticky tire is PLENTY for track use. The RPF1's in 17x8 +45 will clear a BBK (not sure about +35 though). We are running 215 NT01's on a 17 x 7.5 which has tons of grip at our power levels (191whp/156tq) and is a light weight setup.
However, autocross setups seems to prefer a wider contact patch for low speed grip.
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
The Following 2 Users Say Thank You to smbstyle For This Useful Post:
Espi (08-14-2021), ultra (04-28-2015)
Old 09-16-2014, 05:55 PM   #14
glamcem
glamcem's Avatar
I think it all depends on the BBK
Just curious, have you ever used a wider tire/rim configuration at the same day and conditions, I can almost guarantee you that a 17x9" wheels and 235/40/17 NT01s would result in better lap times since my friends did that test with their Miatas and we all agreed on that ..keep in mind, Miatas generally put about 140-150 whp on dynojet
Enkei RPF1 Wheels; Gunmetal/Bronze/Black/Silver/Gold, 17x8, 17x9, 18x8, 18x9.5 OAKOS Automotive Wheels and Tires 176 05-28-2015 12:09 PM
PA:WTB/FT black enkei raijin 18x8.5 18x9.5 for enkei rpf1 17x9 SterlingBrz Wheels and Tires 1 05-29-2014 12:36 AM
WTT: 17x8 RPF1 for 17x9 wheels TemeCal Brakes, Suspension, Chassis 0 01-20-2014 01:46 PM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 02:35 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 05:53 PM
