Old 09-10-2014, 02:14 PM   #57
CSG David
CSG David's Avatar
Originally Posted by phastafrican View Post
Thanks for pointing that out. I sometimes forget that not everyone was involved in that clarification.
Any bolt on aftermarket headers on this car will be assessed a +5 pt because of the primary cat "blob" and piping aft of the header primaries, as well as the removal/non-btm cat inside that blob.
So everything else can still be stock except for that header and it'll be assessed +5 points?
Are camber plates assessed anything? I understand the LCA is a +4 modification I think.
Old 09-10-2014, 02:20 PM   #58
ja1217
Drives: 2004 Toyota RAV-4 5M
Yup, so you might as well do full exhaust while you are at it.
I probably will leave the stock cat back on my car as I'm already underweight and the muffler acts as a bit of a diffuser. Removing it would create a nice parachute area and I don't have the points to spend on a proper diffuser. That and I don't think the stock muffler will hold me back on power much, if at all.
ja1217 is offline   Reply With Quote
Old 09-10-2014, 02:23 PM   #59
CSG David
CSG David's Avatar
Catback does nothing to performance. Maybe a couple itches here and there, but not enough to justify the cost per benefit.
Old 09-10-2014, 02:26 PM   #60
phastafrican
phastafrican's Avatar
Drives: 2013 Raven Scion FR-S
Camber plates and bolts, and most bushings are free, thank God.
Emmanuel Baako: NASA-Southeast Race Control & NASA Florida Race Director
RaceCar:2013 Scion FR-S #986 NASA PTD || Tow:2011 Dodge Durango R/T
phastafrican is offline   Reply With Quote
Old 09-10-2014, 02:28 PM   #61
ja1217
Yeah, the main reason I would get a different cat-back would be the weight savings, but, like I said, I'm already underweight.
As for the camber plates, you don't need to take any points for those. You are correct about the rear lower control arms being 4 points. I'm not sure why they are worth so many points. Hard to believe that a little extra camber in the rear is worth as much as say a wing on the track.
The Following User Says Thank You to ja1217 For This Useful Post:
CSG David (09-10-2014)
Old 09-10-2014, 02:37 PM   #62
CSG David
CSG David's Avatar
I've been helping out a couple clients out on simple HPDE TA builds that also qualify in TTD. Glad my reading comprehension is working.
Old 09-10-2014, 02:37 PM   #63
CSG David
CSG David's Avatar
Because you gonna be a cheetah with those camber arms.
Old 09-10-2014, 08:01 PM   #64
THEmailman
Drives: Raven 6MT
I currently run a 225/45 size street tire with 17x8 for wheels. Since you get back 4 points for running that size, would there be a benefit to running a 215 wide tire? That would give you 7 points back and pretty much completely negate running semi-slicks/full slicks?
This would be at marginally higher than stock power levels (full exhaust, intake, tune for 93). Or at this point, are you wanting to keep the width to maximize cornering? And would running an 8" wide wheel work with the 215's?
Goodridge SS brake lines//ProjectMu 999's//Motul DOT 5.1 brake fluid//GrimmSpeed master cylinder brace//Jackson Racing Oil Cooler//Whiteline camber bolts//Raceseng CamCas plates//Kosei K4R 17x8//BFGoodrich Rivals 225/45
THEmailman is offline   Reply With Quote
Old 09-10-2014, 08:10 PM   #65
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Run a wide 225. I put the 225-45-17 Contis against my 225-45-17 RE070s and they were significantly wider, like 1" on each side maybe. Next time they are off the car I'll take a pic. So find the widest tires you can because the rule goes by what's printed on the tire
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
The Following User Says Thank You to AZP Installs For This Useful Post:
Old 09-10-2014, 08:59 PM   #66
juliog
juliog's Avatar
Drives: 86
Offtopic: do you think the 2016 Miata will be classed as a TTD car? My FR-S is overbuilt for the class.. :P
juliog is offline   Reply With Quote
Old 09-10-2014, 11:04 PM   #67
THEmailman
Drives: Raven 6MT
What types of coilover systems would only take the 3 point hit instead of 5 i.e. less than 40mm shaft and don't have an external reservoir? I k ow you still have to take the 2 points for springs...
Old 09-11-2014, 12:11 AM   #68
phastafrican
Kw v3, RCE T2, konis, BC racing, etc. come to mind
Purely guessing, yes with two stars based on estimated pwr/wt. The FoST is a D car at it's ridiculous HP so wouldn't be surprised.
Yes, it will fit on an 8" wheel, but you'll be compromising sidewall strength. 215 is simply too narrow to be fastest. Tire width costs points because, TYPICALLY, the more contact patch, the faster you are. 225 hoosiers are as wide as 235 toyos. 255 Hoosiers are assessed 275mm width points for their actual width just to give you idea how much wider they get.
But the points system allows varying configuration. I say try it and let's see. What rcomps are you getting in 215s? R888?
Old 09-11-2014, 01:30 PM   #69
THEmailman
Drives: Raven 6MT
I believe Kw v3 have more than two ranges of adjustments correct? That would be assessed 10 points total.....
Also if I were to go with a 215 size tire, I would run something similar to the R888 or just go full slick because I would get those points back. If 8" wide wheels are too big would 7" work then? I could pick up some different wheels to do that.
Also, since you could pick up those points you might be able to run aero or other beneficial parts to make up for the skinnier tires....this is only valid if those things help more than the wider tires would.
Old 09-11-2014, 01:47 PM   #70
phastafrican
KW v3 is a double adjustable coilover: Rebound & Compression.
*** Full slicks are worth +30pts ***
I don't think you'll find any other DOT R-compound in 215/17 other than R888. The approved wheel width is 7.0" - 8.0", so 17x8" should work just fine. Just keep in mind you are seriously giving up on some lateral grip by running the narrow tire. That could be a huge performance hit and corner speed disadvantage, but I'm interested in the results...
Lets talk lug nuts Ibanezboy21 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 06-23-2014 04:42 PM
Lets talk tires... frs10 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 10-04-2013 06:21 AM
Lets talk about clutches charged86 Engine, Exhaust, Transmission 26 08-30-2013 05:13 PM
Lets talk exclusivity whitejdm BRZ First-Gen (2012+) — General Topics 33 02-15-2012 02:17 PM
Lets talk weight KaliKev Scion FR-S / Toyota 86 GT86 General Forum 63 09-12-2011 01:05 AM
