Old 09-06-2014, 04:31 AM   #1
636
636's Avatar
Drives: '23 CWP BRZ
Disable Turn Signal DRL?
Is there a way to turn off the amber DRL, except for turn signal use?
I don't really want to buy switchbacks, I have another plan for something there, but until I end up buying it, I just want to disable the amber.
I haven't really looked at the wires, but I'm assuming there's two wires? One that controls the turn signal, and one that controls the DRL right? So technically, I could just snip one of the wires?
636 is offline   Reply With Quote
Old 09-06-2014, 05:44 AM   #2
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Yes you could disable the parking light circuit by removing the pin by the connector that's on the headlight frame.. Or at the light bulb connector itself but you would have to wrap it in tape since it's still going to be live when the parking lights/headlights are on.. I'll also be getting your DRL mod made up and shipped out Monday.. Would be a good time to do this mod.. I'll try and remember to grab the wire color when I have the bumper off to install my supercharger Sunday.. I can't recall if it's the red wire or green wire
Gixxersixxerman is offline   Reply With Quote
The Following User Says Thank You to Gixxersixxerman For This Useful Post:
636 (09-06-2014)
Old 09-06-2014, 12:41 PM   #3
Createddeleted
Drives: 2014 BRZ - 2004 GLI
Techstream?
Createddeleted is offline   Reply With Quote
Old 09-06-2014, 12:56 PM   #4
636
636's Avatar
Drives: '23 CWP BRZ
From what I'm reading, it's the green wire.
But awesome, I appreciate the DRL mod
Old 09-08-2014, 01:58 PM   #5
FutureFT86
FutureFT86's Avatar
Drives: 13 Scion FR-S
You could also just replace the bulb with a single filament bulb. 4440 are the ones I believe. If you do the lights only come on when you signal. I think that's what you're trying to achieve if I'm not mistaken.
Edit: this is for an frs. Not sure if u have a brz...
Mike
Check out my build: Instagram @kawallito
FutureFT86 is offline   Reply With Quote
The Following 2 Users Say Thank You to FutureFT86 For This Useful Post:
636 (09-08-2014), Calidrifter (09-09-2014)
Old 09-08-2014, 02:20 PM   #6
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
i took some black electrical tape, and taped off one connector on the bulb
bam.. 2 minute mod
turn signals stay off when headlights are on, but blinks when activated
http://www.ft86club.com/forums/showthread.php?t=70076
The Following 2 Users Say Thank You to WhiteFRS69 For This Useful Post:
636 (09-08-2014), HATED1 (06-09-2015)
Old 09-08-2014, 09:04 PM   #7
636
636's Avatar
Drives: '23 CWP BRZ
bam.. 2 minute mod
Thank you! This is what I was hoping for.
The Following User Says Thank You to 636 For This Useful Post:
WhiteFRS69 (09-09-2014)
Old 09-09-2014, 05:26 AM   #8
thatfilipinoguy
thatfilipinoguy's Avatar
Drives: 87 Supra, 13 FRS, 05 FXT
disco the green pin from the plug, and tuck it into the black insulator.
thatfilipinoguy is offline   Reply With Quote
Old 09-09-2014, 08:20 PM   #9
KI_ZN6
KI_ZN6's Avatar
We have LED bulbs that are single filament and operate in the turn signal mode with the marker light mode disable. This would not involve any modifications to the OEM connector or wiring (we try not to modifying any OEM components if we don't have to)
KI_ZN6 is offline   Reply With Quote
The Following User Says Thank You to KI_ZN6 For This Useful Post:
D_Thissen (09-09-2014)
Old 09-13-2014, 08:10 PM   #10
636
636's Avatar
Drives: '23 CWP BRZ
Hey dude, for some reason I can't PM you..Could you send me the tracking number for the DRL mod? I never got one..
Old 09-14-2014, 09:09 AM   #11
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Link?
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
FS: OEM Turn Signal Stalk Zagmeister Exterior Parts (Aero, Lighting, Etc.) 4 07-05-2014 11:08 AM
Turn signal question OMGreta Cosmetic Modification (Interior/Exterior/Lighting) 6 01-27-2014 03:06 PM
Turn signal issue Asphaltfrs1 Issues | Warranty | Recalls / TSB 3 06-21-2013 07:06 PM
Is it possible to change turn signal to drl? Enraged21 Scion FR-S / Toyota 86 GT86 General Forum 4 02-22-2013 01:52 PM
Anyone seen these turn signal/drl less? djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 7 07-15-2012 04:32 AM
