Old 09-09-2014, 02:34 PM   #15
phastafrican
phastafrican's Avatar
Drives: 2013 Raven Scion FR-S
Originally Posted by ja1217 View Post
[/IMG]
Blue line was before the tune. So yes, it did help a bit, but I don't spend a whole lot of time in that RPM range on the track anyway.
Except T7 at RA - ~50mph turn and annoyingly leads unto the longest straight. lol...I hate it! 2nd gear hurts more than it helps unless you have a perfect rev match.
Emmanuel Baako: NASA-Southeast Race Control & NASA Florida Race Director
RaceCar:2013 Scion FR-S #986 NASA PTD || Tow:2011 Dodge Durango R/T
phastafrican is offline   Reply With Quote
Old 09-09-2014, 02:38 PM   #16
phastafrican
Here's my dyno sheet with a 93 tune + air filter + borla catback.
Old 09-09-2014, 02:42 PM   #17
phastafrican
Originally Posted by JustDoItMikey View Post
Well it looks like it at least made it climb back out faster, better than not tuning either way I suppose. We just need more E85 available at the track so we dont have to byoE85
I might be fixing that by the time you're ready to race. 55 gal fuel drum in my enclosed trailer full of E85. If we do get more 86 race cars.
You could just tune for 110 octane... just costs $9/gal.
Old 09-09-2014, 02:49 PM   #18
JustDoItMikey
JustDoItMikey's Avatar
Drives: 2015 FR-S
I was totally thinking turn 7 too. Cant tell you how many times I come out of there in the flat spot and it suuuuucks.
JustDoItMikey is offline   Reply With Quote
Old 09-09-2014, 02:55 PM   #19
JustDoItMikey
Drives: 2015 FR-S
Ya Im still kicking around if I want to buy a truck and trailer to tow the FRS, than carrying E85 is a moot point. Or the much more appealing thought which is just building a sub 1k lb (loaded weight) trailer to tow with the FRS, but then I need to run flex fuel vs full E85. Soooo many decisions. We just need E85 to be more readily available. And Im sure my insurance company would frown on me storing 55 gallons of E85 in my residence or else I would just do that. lmao
Old 09-09-2014, 03:30 PM   #20
phastafrican
This could be worth almost a second in lap times.
Old 09-09-2014, 03:40 PM   #21
CSG David
CSG David's Avatar
EcuTek + tune = +3 points?
Old 09-09-2014, 03:41 PM   #22
CSG David
CSG David's Avatar
So here's my current set up. I'm usually pretty competitive, but it always depends on who shows up. My last event I came in 2nd (Summit Point Main) but was 2 seconds off the pace (dang E36's, guy set the track record), but the previous event I won at VIR.
Current Total: 16 points
Tires (6 Total):
Hoosier R6: +10
225/45R17: -4
Suspension (8 Total):
Ohlins Road&Track: +8 (Shaft > 40mm = +5, inverted front struts = +1, aftermarket springs = +2)
Brakes (2 Total):
Essex AP Racing Sprint BBK: +2
Free Mods (0 points):
DSS CF Drive shaft
ACT Prolite clutch/flywheel
Perrin Engine Mounts
Shorai 5lbs. battery
Competition Weight: 2885 (need to have at least 1/3 tank of gas and I am carrying 70lbs. of ballast in the spare tire well)
WHP (Dynojet): 185
Next year I plan on adding more power by getting a header and high flow cat downpipe (or where ever that 2nd cat is) and I'll probably move to Maxxis RC-1's for there very generous contingency plans. It's probably still not a completely optimal setup, but I did a fair amount of stuff before even considering doing TT.
Theoretical Fastest Build (19 points total):
Tires (9 points):
225/40R17 Hoosier A6: 9 points (although with the A6 being replaced with the A7, which will be a higher point cost, currently its at 22!!!)
Suspension (5 points):
Aftermarket shocks/dampers: +3
Aftermarket springs: +2
Engine (5 points):
Header: +2
Exhaust: +2
Cats: +1
Then you throw in as many free mods (bushings, etc) as you can and run right at the power/weight limit for the class.
Also, as a side note, all aftermarket headers for the FR-S/BRZ will cost 5 points. The definition of a header, according to the rules, is just the primaries. Since all aftermarket headers I've seen for our car include primaries, remove/upgrade the cat, and will modify piping going to/from that cat they are seen as 5 point modifications. See http://nasaforums.com/viewtopic.php?...119352#p467349
I'm curious, who can I e-mail to find out if I have questions regarding gray area mods?
Old 09-09-2014, 03:42 PM   #23
ja1217
Drives: 2004 Toyota RAV-4 5M
No, since its still using the stock ECU. Flashes are free as long as you stay within the power/weight limits.
ja1217 is offline   Reply With Quote
Old 09-09-2014, 03:44 PM   #24
ja1217
To get an absolutely official response, email Greg@nasa-tt.com
Most questions can probably be answered on the TT forums at www.nasaforums.com
Old 09-09-2014, 03:44 PM   #25
CSG David
CSG David's Avatar
OH. That is beautiful.
Old 09-09-2014, 03:44 PM   #26
phastafrican
0 pts.
No points assessed for any tuning, unless using an aftermarket, stand-alone, or piggyback computer system.
Old 09-09-2014, 03:46 PM   #27
phastafrican
Interested in these gray area mods you're thinking about. You seem to always have something interesting up your sleeve.
Old 09-09-2014, 03:59 PM   #28
CSG David
CSG David's Avatar
Just interested in the interpretation of the rule set because the answers couldn't be found on the forums so we consider that "gray area" because it's not completely defined. It's nothing insanely special though.
Lets talk lug nuts Ibanezboy21 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 06-23-2014 03:42 PM
Lets talk tires... frs10 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 10-04-2013 05:21 AM
Lets talk about clutches charged86 Engine, Exhaust, Transmission 26 08-30-2013 04:13 PM
Lets talk exclusivity whitejdm BRZ First-Gen (2012+) — General Topics 33 02-15-2012 01:17 PM
Lets talk weight KaliKev Scion FR-S / Toyota 86 GT86 General Forum 63 09-12-2011 12:05 AM
