Old 09-08-2014, 01:59 PM   #1
jflogerzi
jflogerzi's Avatar
Stock radiator + aftermarket Shroud to fit SPAL fans
I am about to order my JDL EL Base turbo kit. Based on what @jamesm mention for the power levels I am targeting, the stock radiator with a proper shroud should be fine. Which company makes these?
Old 09-08-2014, 04:18 PM   #2
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Stock shroud and fans work great
Old 09-08-2014, 05:06 PM   #3
jflogerzi
jflogerzi's Avatar
Then why does the out come with new SPAL fans?
Old 09-08-2014, 05:38 PM   #4
Ryan P
Fullblown's shroud works with JDL's kit. I have their rad + shroud on my car with the JDL EL kit
http://www.ft86club.com/forums/showthread.php?t=56378
Ryan P is offline   Reply With Quote
Old 09-08-2014, 05:41 PM   #5
kbye
kbye's Avatar
Drives: 2014 FR-S
Because the JDL kit (and many other turbo kits) require smaller fans for clearance purposes.
I don't know if FBM's shroud works with the stock radiator or if it only fits with the radiator they sell.
Carolina Dyno also makes an aluminum shroud, fits the stock radiator, comes with connectors for a plug and play affair.
kbye is offline   Reply With Quote
Old 09-08-2014, 05:56 PM   #6
SmsAlSuwaidi
Boosted
The kits comes with an upgraded fan because of the tight clearance. Why not just drop in a new radiator while you are at it, since its a good upgrade and not that costly !
Old 09-08-2014, 05:56 PM   #7
jflogerzi
jflogerzi's Avatar
Are you sure. I message them on the boards and they said it only fits the Koyo radiator.
Old 09-08-2014, 05:58 PM   #8
jflogerzi
jflogerzi's Avatar
I am thinking this might be the way to go.. sigh… more money.
Old 09-08-2014, 06:02 PM   #9
SmsAlSuwaidi
Boosted
Just go with FBMs cooling solution you won't regret it and its well worth the money
Old 09-08-2014, 06:44 PM   #10
Ryan P
FBM make a shroud for your OEM radiator. Just tell them you already have the fans
Old 09-08-2014, 07:05 PM   #11
jflogerzi
jflogerzi's Avatar
Thanks.
Old 09-08-2014, 08:00 PM   #12
mike the snake
I have the FB turbo kit, with their radiator, shroud, and Spal fans, and the system is work perfectly.
Old 09-08-2014, 09:22 PM   #13
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
I have a lightly used Full blown radiator w/ fan shroud assy(150 mile) for sale. I had it on my JDL kit. PM me if interested.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 09-08-2014, 09:40 PM   #14
kbye
kbye's Avatar
Drives: 2014 FR-S
Ah sorry my bad. For some reason I thought it fit stock.
Spal Fan Shroud & Koyo Radiator Carolina Dyno Forced Induction 64 12-14-2016 08:38 PM
FBM Aluminum Radiator Shroud Release FullBlown Engine, Exhaust, Transmission 7 09-28-2014 05:01 PM
radiator support shroud? WhiteFRS69 Cosmetic Modification (Interior/Exterior/Lighting) 4 07-18-2014 07:51 PM
Full Blown Stage 2, Rad + Shroud + SPAL install Ironsquid Forced Induction 3 02-11-2014 10:47 PM
FBM Aluminum Radiator Shroud Release FullBlown Engine, Exhaust, Bolt-Ons 0 01-22-2014 06:29 PM
