Old 09-07-2014, 01:30 PM   #57
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Originally Posted by sw20kosh View Post
@CSG David
You mentioned you were looking at 20 row series 9.
Well mkivsoopra and I installed 25 row series 9 setrabs.
Did the 6.5k rpm 3rd gear on freeway for 20 mins in 70 F ambient. Couldn't get it above 207 F.
Did the same for 5 mins on a mountain pass (still freeway) to stress the motor even more. Saw it max out at 220 F. Coolant never went above 203 F.
A month or so ago I did this same test with the 13 row series 6 and a few weeks before that a 7" Mocal laminova. Saw 260 F in less than 10 mins on flat freeway in same 70ish ambient.
VERY interested in this, do you have any pics of the mounting of the 25 row series 9 setrab? We are working on a setup for our track car and this looks like it may fit the bill.
Thanks in advance.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 09-07-2014, 06:24 PM   #58
sw20kosh
Drives: 2013 Black FR-S
Thanks in advance.
-Mike Paisan
I don't but I will snap one next time the bumper is off. It sandwithces right between the FMIC and the AC condensor.
Maybe @mkivsoopra has a pic?
Old 09-07-2014, 09:05 PM   #59
ddeflyer
Originally Posted by Dezoris View Post
Can't really do any logging since gauge is independent using oil gallery plug. (Testing on two different gauges.)
But I have been doing a long ass video about comparing the S2000 vs the 86 platform which has including about 10 hours of hard street driving and now track.
After about 200F you start seeing 55-60PSI at 7000RPM
After about 210F you start seeing 49PSI at 7000RPM
After about 220F you start seeing 43-45PSI at 7000RPM
After about 230F you start seeing 40-45PSI at 7000RPM
After that, I had my two testers never rev past 6000RPM, on the track session is over.
Now with that said, I have two UOA after long track days showing no metals. But I think at least for me, I am going to hang up any longer sessions with this car going forward because of this.
Could you explain a little more about how you have the oil pressure sensor installed? All the solutions I've seen so far seem a little hackish, but I would like to get one.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
Old 09-07-2014, 10:08 PM   #60
Dezoris
Dezoris's Avatar
Oil gallery plug by throttle body harness. Remove install new gallery plug with NBT threads, your choice of oil pressure sender with harness to interior to gauge, wire to fuse box.
The Following User Says Thank You to Dezoris For This Useful Post:
RehabJeff86 (09-08-2014)
Old 09-07-2014, 11:26 PM   #61
CSG Mike
CSG Mike's Avatar
@CSG David
Does that mean it's my turn to test?
Old 09-07-2014, 11:55 PM   #62
sw20kosh
Sure. As soon as I test it on track first.
Old 09-08-2014, 01:45 AM   #63
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
For those who daily drive our cars, is there any concern with moisture accumulation in the oil? Ambient temps can be a max of 50-60 F around here come winter time. It's a given that other areas can be much lower.
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline   Reply With Quote
Old 09-08-2014, 02:04 AM   #64
CSG David
CSG David's Avatar
Keep in mind there is a possibility to get the oil too cool. You want the oil to operate over 212F at least to "boil" off the water condensation that may be in the oil, hence why it's a good guideline to keep the oil around a specific operating temperature.
The Following 2 Users Say Thank You to CSG David For This Useful Post:
AZP Installs (09-08-2014), RehabJeff86 (09-08-2014)
Old 09-08-2014, 11:17 AM   #65
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
This is why I swapped out the 185F thermostat that came with my oil cooler kit for the 203F thermostat that Mocal sells. Keeps the temps in a happier place. Real easy to get to boiling point from there. All that being said, my car hibernates for the winter so I don't know what it would be like once the temperature dips below freezing.
BatStig is offline   Reply With Quote
The Following User Says Thank You to BatStig For This Useful Post:
Old 09-08-2014, 12:10 PM   #66
Dezoris
Dezoris's Avatar
That is the big issue, whats good for track is not good for street and vice versa.
The Following 2 Users Say Thank You to Dezoris For This Useful Post:
CSG David (09-08-2014), RehabJeff86 (09-08-2014)
Old 09-08-2014, 12:11 PM   #67
Dezoris
Dezoris's Avatar
Christ is that for an F350?
CSG Mike (09-08-2014), glamcem (09-08-2014)
Old 09-08-2014, 02:28 PM   #68
CSG Mike
CSG Mike's Avatar
It partially depends on where you're measuring oil temperature. Remember that while the oil temp sensor may read low, localized temps will still be higher; the oil is absorbing heat from the heads, engine itself, pistons, cylinder sidewalls, bearings, etc.
If you're just cruising around town, then you may not see temps high enough to boil off water, but the same would apply if you had the OEM FA20DIT cooler; the oil-water cooler stabilizes the oil at the temperature of the coolant, and you'd be sitting at around 195F or so without racing the engine.
If you want to make sure oil gets over 212F, just sit at high RPM for a minute or two (after the engine and oil are at fully warmed up!), and the temps will get there very quickly, particularly at low speeds.
unsurety (09-08-2014)
Old 09-08-2014, 09:18 PM   #69
AZP Installs
I agree on the T-stat being key on these installs.
Although I would think most of the folks who need these big coolers don't drive gently on the street and would work it up to that 212-215 range easily
-Mike Paisan
The Following User Says Thank You to AZP Installs For This Useful Post:
CSG Mike (09-09-2014)
Old 09-08-2014, 11:18 PM   #70
jflogerzi
jflogerzi's Avatar
@CSG David
Can you list the exact version you bought?
Is it this?
[ame="http://www.amazon.com/Setrab-row-oil-cooler-ports/dp/B0011FK01W/ref=sr_1_2?ie=UTF8&qid=1410232604&sr=8-2&keywords=setrab+series+9"]Amazon.com: Setrab series 9, 20 row oil cooler, M22 ports: Automotive[/ame]
HKS Oil Cooler Kit - Keep those oil temps down. - Photos FT-86 SpeedFactory Engine, Exhaust, Transmission 23 08-10-2015 03:08 PM
Robi-Cooler Install....Oil Temps under 180??? Deep Six Engine, Exhaust, Transmission 28 08-07-2014 12:30 PM
Oil Temps Fish Eagle AFRICA 13 07-22-2014 05:53 PM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 05:46 PM
