Old 07-27-2013, 08:32 PM   #1
wparsons
wparsons's Avatar
Perrin front pipe + stock cat back, what gasket?
Anyone know which gasket is the correct one to use with a perrin front pipe and stock cat-back?
There's simply no way the included gasket will work with the stock cat-back, the hole spacing is about 1/4" too wide on the flange. The gasket works fine with the front pipe, it's the stock mid pipe that's the problem maker.
I got it together using the perrin bolts but stock donut gasket, doesn't seem to be leaking but it doesn't seem ideal to me.
Thoughts?
flickr
Old 07-27-2013, 08:34 PM   #2
jpit
Drives: Subaru BRZ
It's the donut gasket.
jpit is offline   Reply With Quote
Old 07-28-2013, 09:34 AM   #3
wparsons
wparsons's Avatar
Ok perfect. It didn't seem right when I was doing it, but it seems to work great.
flickr
Old 09-01-2014, 04:16 AM   #4
ysr50guy
ysr50guy's Avatar
Drives: brz
Bump
Is it really ok to use the stock donut gasket to connect the perrin front pipe to stock exhaust?
ysr50guy is offline   Reply With Quote
Old 09-01-2014, 06:51 PM   #5
BP1913
Drives: Subaru BRZ Limited MT
Originally Posted by ysr50guy View Post
Bump
I have the Motiv frontpipe on stock exhaust and they said to use the stock donut gasket as well. Perfect fit for me.
BP1913 is offline   Reply With Quote
Old 09-01-2014, 07:10 PM   #6
wparsons
wparsons's Avatar
Yep, mine worked great until I replaced the cat-back as well. The instructions for most front pipes will tell you to use it with the stock cat-back.
flickr
Migero86 (09-06-2014)
Old 09-06-2014, 06:51 PM   #7
Migero86
Migero86's Avatar
Drives: 2015 Trailhawk
I just did this with the q300 and it worked great. Couldn't get flat gaskets to seal properly. Donut gasket FTW!
Migero86 is offline   Reply With Quote
Old 09-06-2014, 08:53 PM   #8
-Tom-
Drives: Grey GT86
Just to add my 2 pence, I also used the stock donut gasket when fitting my milltek front pipe to the stock cat back.
For grins though, you should fit it without using any gasket between the front pipe and the cat back, sounds pretty good in my opinion! Albeit a bit broken.
-Tom- is offline   Reply With Quote
Old 10-08-2014, 02:56 PM   #9
wparsons
wparsons's Avatar
As per your PM, are you sure it's leaking at that joint and not the overpipe/frontpipe connection?
What does the Q300 say to use with the front pipe?
flickr
Old 10-08-2014, 03:03 PM   #10
Alaskan
FR-S Matt here since I got banned... lol
Q300 says to use the donut gasket. I have the invidia catted FP and Q300. The gap between both has the smoothed edges for the donut gasket.
You should be using that. Perrin on the other hand uses a flat gasket with their catbacks from my understanding.
Alaskan is offline   Reply With Quote
Old 10-08-2014, 03:21 PM   #11
Migero86
Migero86's Avatar
I have the Perrin frontpipe and the Q300, it uses the donut indeed. Just having a hell of a time getting it silent and sealed. I want to avoid using sealants since those a pain to clean up if you ever need to remove. I doubled checked all my other joints, they are perfect with no air escaping. Its the bloody frontpipe to midpipe connection, I may just say the hell with it and get it chopped and welded together like one guy in the U.S. did with his Q300.
Old 10-08-2014, 06:10 PM   #12
wparsons
wparsons's Avatar
You could try the flat gasket on the Q300 side combined with the donut? Possibly just try a new donut itself?
flickr
Old 10-08-2014, 06:22 PM   #13
Migero86
Migero86's Avatar
Yep. Tried that combo as well.
This is the first car in 24 yrs of driving and 10 cars that has been a total ball buster for getting the exhaust to seal properly.
Old 10-08-2014, 06:29 PM   #14
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Off topic, but why the hell did they ban you!?
Perrin 3" Front Pipe Taber Engine, Exhaust, Transmission 36 04-04-2015 08:17 PM
Invidia Down Pipe on Perrin Cat Back stu_dw Engine, Exhaust, Transmission 4 04-24-2014 11:34 AM
WTD: Perrin catted front pipe wbsrazzle Engine, Exhaust, Bolt-Ons 2 09-22-2013 11:26 AM
WTB: Perrin Over Pipe + Catted Front Pipe + Cat Back (Resonated) coolaron Engine, Exhaust, Bolt-Ons 0 07-13-2013 04:37 PM
