#2829 |
Drives: 2013 scion frs
Had 7500 miles on mine when I had complete failure..later diagnosed engine failure due to rod bearings, reason from over revving is what the dealer said. Warranty is being denied..
Only mod is catback and intake . Very extreme situation I am in... looking for any help from anyone that had similar issue with bearing failure. Any help.much appreciated message me on here or email Thank you Mathew cruz (760) 985-7663 Mathewcruz89@gmail.com |
#2830 |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Update:
Had scheduled appointment today for the computer replacement. Dropped off the FR-S this morning and just picked it up after work. Invoice shows SU003-04568 EGI Control Unit. Car runs much better, ran her hard to get the temps up (230+) and okay for now. No idle hunting like before and response feels smoother than ever. Just brushed the rev limited to see how it is and it's much better than before... doesn't shut everything down and drop revs like a rock (which the original computer did.) Will be stressing her out over the next few days to get a "warm fuzzy" that everything is as it should be...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
#2831 |
Drives: '13 SSM BRZ Limited 6MT
whew! i had similar symptoms to quite a few in this thread. car hunting RPMs, stalling out with skid lights and CEL coming up for a few days. Torque showed P0102 Turned out it was a loose bolt near the crank sensor. FYI though I have a Unichip. When I opened up the hood and prepared to remove the Unichip to rule that out, I found the bolt hanging on its own! Screwed it back and and now all is good.
this is the bolt here: [ame="https://www.youtube.com/watch?v=X7dd-hjbNMQ#t=122"]Scion FR-S Unichip Installation - YouTube[/ame] |
#2832 |
Drives: 2013 BRZ Limited
Just got my car back from the dealer after repairs for the rough idling/stalling. The dealer replaced the ECM, OSV, and A/F sensor. This was my second repair, the first time I had the same rough idling/stalling issue they replaced my shortblock.
I was experiencing idle blips after I got my car back. It's only been two days since I got it back and it's rough idling again. I parked it in my garage and popped the hood and it smelled pretty bad. The CEL started flashing and I pulled the codes P0300, P0017, P000B. I'm at 138xx miles on a 2013 BRZ. I'm gonna have to call the dealer again to see what they can do as this will be the third time bringing it back for the same issue. |
| The Following User Says Thank You to GeekB For This Useful Post: | Djratrap (09-04-2014) |
#2833 |
Drives: 2014 BRZ
add me to the list..... 2014 BRZ, 2800 miles, and bought new 4 months ago. CEL code P0171(too lean on bank 1) CEL and SC light came on at the same time exteamly rough idle/sluggish(been rough idle and slugish for about a month now) and when i pulled forward car felt like i had a flat tire... the drive feel went away when the SC light went out figure its something with the LSD check engin light is still on and have been trying not to drive it since the code came up but i just dropped the car off at the dealer today and they havent seen it before but from what ive been reading i dont see how there are obvisiouly so many more people experiencing the same type of problem. they said they are keeping it for a few days to see if they can clear the code and if it pops up again just hope that they can fix it before it becomes a bigger problem.
#2834 |
Drives: BRZ CSB Limited
Update #2, so the cell came back on for a P000B code (after putting rougly 2k on the new cam gears). I'm not sure what to do? My car is out of lemon law, mileage too high. I'm calling corporate in the morning. I took the car back to Subaru Puyallup today and they said it was a "not tightened gas cap." They code came back on about and hour after leaving the dealership. When i got home i ran the obd2 reader on it and pulled that code. Def not a gas cap.
#2835 | |
#2836 |
Drives: 2014 BRZ
2014 BRZ Manual. My VIN is in the range of vehicles that were released with the updated programming. Last of VIN is 604483. My car does the exact same thing that everyone is making videos of. I have just under 2000 miles on the car. The dealer was not able to duplicate at this time but so far it is sounding like they are going to try to pass it off as normal.
#2837 | |
Drives: 2014 BRZ
#2838 | |
Drives: Raven FR-S 6M
Common causes include: - Intake or vacuum leaks - Clogged or faulty Mass Air Flow sensor (MAF) - Faulty PCV valve - Exhaust leaks - Faulty oxygen sensor - Improperly installed aftermarket cold intake
“The World is Flat”
[||•]=(86)=[•||] Last edited by Apoc; 09-05-2014 at 12:57 AM. |
#2839 | |
Drives: 2014 BRZ
#2840 |
It is possible for the intake to be causing it. I would put the stock intake back on just to eliminate one possible cause. If it continues then at least you can get it fixed under warranty. They typically won't give a proper diagnostic if you have aftermarket parts that may be causing it.
“The World is Flat”
[||•]=(86)=[•||] |
#2841 |
Drives: 2014 BRZ
i noticed that while it was at the dealer... they didn't even drive the car it had the same millage on it as when i drop it off then tried to blame it on the cold air intake... would this cause significant problems in the future for the car if not repaired soon?
#2842 |
They don't need to drive it if they see data streams showing fuel trims way off and AFR above 14.7. It shouldn't cause any long term problems but I would take easy until you have it resolved.
“The World is Flat”
[||•]=(86)=[•||] |
| NW Owner List & Event Archive | DarrenDriven | Northwest | 1643 | 08-05-2016 06:48 PM |
| Idle issue? | yayforaddison | Issues | Warranty | Recalls / TSB | 891 | 07-14-2016 10:42 AM |
| Idle issue | scioneric | CANADA | 23 | 08-24-2012 01:40 AM |
| Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 12:00 PM |
| An unofficial message from TMCA | Courtz1074 | AUSTRALIA | 25 | 05-17-2012 10:00 AM |
