Old 08-12-2014, 10:14 AM   #99
EMS Guy
The cynic
Drives: An ambulance
Originally Posted by MAPerformance View Post
Yep You nailed it. Same issues we had on the Evo X throttle bodies. Those issues have been resolved, we just have had the FA20 TB's on the back burner. Hopefully we can get this started back up.
Yeah...damn drive by wire.
EMS Guy is offline   Reply With Quote
Old 08-12-2014, 10:54 AM   #100
MAPerformance
Drives: Asphalt FRS
Yeah, I know. Don't worry, we will make it work
MAPerformance is offline   Reply With Quote
The Following User Says Thank You to MAPerformance For This Useful Post:
zohare (09-04-2014)
Old 09-04-2014, 07:25 PM   #101
zohare
zohare's Avatar
Drives: '13 Firestorm Base AT
woo! keep at it. Someday, someone will solve the question to making N/A power on these cars... Thanks for working at it! Always cool to see a company doing some real development, even if it ends up doing nothing, well, one more variable eliminated, we would know that it does in fact, not help (on setups x, y, z)
zohare is offline   Reply With Quote
The Following User Says Thank You to zohare For This Useful Post:
MAPerformance (09-05-2014)
Old 09-04-2014, 07:58 PM   #102
charged86
charged86's Avatar
interested as well
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
The Following User Says Thank You to charged86 For This Useful Post:
Old 09-05-2014, 11:14 AM   #103
MAPerformance
Drives: Asphalt FRS
We keep getting set back with the Evo X DBW throttle bodies. We need to master those before we finish the FRS/BRZ ones. On the plus side, the same issues we had in testing with the FA20 throttle bodies, is also happening with the Evo X ones. I think if we can figure it out, we can apply that to the FA20 TB's as well. I will keep everyone posted.
zohare (09-06-2014)
Old 09-21-2014, 12:45 PM   #104
charged86
charged86's Avatar
thanks IAN
Old 12-01-2014, 03:55 AM   #105
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Going into one year. Any updates?
Carlitoz3 is offline   Reply With Quote
Old 12-01-2014, 11:14 AM   #106
MAPerformance
Drives: Asphalt FRS
No sir sorry to say. This is still on the back burner of projects we need to finish. I promise I will update this thread with good or bad news when we are ready.
Carlitoz3 (12-01-2014)
Old 12-03-2014, 08:45 PM   #107
86drift
86drift's Avatar
Drives: Toyota 86 GT
Just an idea. With the same % opening to achieve 650rpm idle with 65mm throttle plate you'll have a larger air flow with the 68mm throttle plate, which results in higher idle rpm. Basically you'd need to add some form of bias. Either mechanically or electronically.
86drift is offline   Reply With Quote
Old 04-29-2015, 03:11 AM   #108
8686
8686's Avatar
Drives: 86
@MAPerformance is there any news on this item
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 06-14-2015, 11:21 PM   #109
icauntdrive
Drives: a few things
Well, im running 68MM tb with FI setup and have no luck with the cel. First it was the TB sensor code then its the P0068 MAF/MAP code that was related to Throttle position correlation. Im thinking of going back to stock TB. Plus The larger TB make the car idle high up to 3000rpm some random times when you clutch in and put it in gear. I dont know if its just me or is anyone else experiencing the same?
icauntdrive is offline   Reply With Quote
Old 06-15-2015, 08:47 PM   #110
Turdinator
Señor Member
Turdinator's Avatar
What brand are you using?
1974 TA22 Celica
2013 86 GT
Old 06-16-2015, 10:00 AM   #111
nelsmar
Did you adjust the throttle angle g/s table? You may also need to adjust the cylinder fill one as well. I at one point had adjusted my throttle angle compensation as my turbo pushes air into the engine at idle higher than the ecu expects and the car was drifting upwards and would take a moment for the ecu to shut the throttle.
My flickr - Canibeat
Local magazine scout
Old 06-16-2015, 11:50 PM   #112
icauntdrive
Alex Motorsports. Its one of the cheaper one.
Cusco Throttle Body? track_warrior Engine, Exhaust, Transmission 66 06-28-2016 06:28 PM
Dirty throttle body AVOturboworld Engine, Exhaust, Transmission 11 05-11-2016 10:58 AM
Heated throttle body? Turdinator Engine, Exhaust, Transmission 19 04-06-2014 11:21 AM
YR-Advance Throttle Body ANREX Engine, Exhaust, Transmission 9 10-30-2012 01:45 AM
