#15 |
Off Topic
You're starting to track your car, right? Maybe a CG lock to start with, then move to a harness later? That way you don't need to install a harness bar right away.
| The Following User Says Thank You to gramicci101 For This Useful Post: | ZionsWrath (09-04-2014) |
#16 |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
This is exactly my dilemma, except I need a 2" drop from stock and to have better ergonomics...stock seats are not that great. Toss up between the Bride Stradia II's and Recaro Sportser CS, prefer the looks and better lowering potential of the Brides, but I know the Recaro will be comfortable and if custom make rails can have just as low... but I have a fear they may be just a little too wide (stock seats a fine width wise for me) Both run ~ $1500 per seat for the basic versions.
Bride Stradia II sports look like they were made for the FRS (but I would go with the low cushion option liked pictured, not the normal LowMax cushion...)
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
#17 |
Drives: 2015 Series.Blue
Looks like the STi Recaros retain the airbag in the seat... I know it's not that important to some, but it would probably explain the price.
#18 |
Thanks
Where are you buying those STI seats from? Are they just bolt in no modifications? How do they sit in height compared to stock?
My helmet has like 0 mm of clearance with the stock seat so if I got another seat it could not gain even 1 mm of height.
#19 |
Thanks
Yea I have been looking into that, how effective are those lockers? I always have to tighten my belt on the straights don't know why.
#20 | |
Off Topic
While this isn't ideal, it's still more secure overall than just the seatbelt and gives you a better feel for what the car is doing. I would not use one for normal driving, as it would not give way in an accident like the seatbelt would. If you're only just starting to track and you've not designated this car as a track-only vehicle, it's a nice step up during your progression. |
#21 | |
Drives: 2014 BRZ MT (Sold); 2006 V70R
As for the CG Lock... if you don't sit with the seat slid ALL THE WAY to the rear, then you don't need the CG lock. -Slide seat all the way to the rear -Strap in and lock seat belt -Slide seat forward to tension the seat belt (preventing unlock) -Go do your AutoX / laps around the track -When finished, slide seat back to unlock and release.
'14 BRZ LTD MT DGM
| The Following User Says Thank You to aznatama For This Useful Post: | tahdizzle (09-04-2014) |
#22 |
So elite I'm 1338
Drives: WRB Subaru BRZ
Recaro all the way. Functional
which model are the recaros in the tS? They look like the CS... but CS does not have sidebolster airbags or heating.
-Jack Burton |
#23 |
Recaro sportster CS I believe... The oem price, if I remember correctly, was almost 2k each, and had airbags. Not sure if it had seat heaters though.
'14 BRZ LTD MT DGM
#24 |
Drives: is300 / Fr-s
I remember seeing that they do have both heating and airbags optional . I'm curious if that would eliminate the airbag light on the gauge cluster
Daily Driver:2002 Lexus is300 Graphite Gray Pearl
Garage Queen:2014 Monogram Fr-s Asphalt 6MT my.is: iJAYDM Clublexus: JDis3 IG:@j0nathandiaz |
#25 |
If you have the one with the airbag, then it should, since it would be plugged in. The oem recaros have an airbag.
'14 BRZ LTD MT DGM
#26 | |
Off Topic
#27 |
So elite I'm 1338
If i could find them. I'd totally buy them. I can find them with the heated option, but not heat and airbags.
-Jack Burton |
| Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? | davidchoi | Cosmetic Modification (Interior/Exterior/Lighting) | 49 | 11-22-2014 10:17 PM |
| Bucket Seats on a Budget - Full Bucket & Reclinable - Starting at $190 - Sonic Motor | Sonic Motor | Interior Parts (Incl. Lighting) | 117 | 08-29-2014 08:32 PM |
| "Clicking" or "knocking" caused by rear seat pull down lever. | husker741 | Issues | Warranty | Recalls / TSB | 6 | 11-27-2013 02:30 PM |
| "My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") | levifig | BRZ First-Gen (2012+) — General Topics | 48 | 08-09-2013 06:34 PM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 12:59 PM |
