Old 03-14-2014, 10:49 AM   #1
JR007
JR007's Avatar
Drives: Ultramarine FR-S
19" Wheels/Tires Advice
I've tried to use all the resources on the forum to figure out an answer to my question, but get lost in all the numbers. Can anyone please help me?
I'm looking at the following wheels/tires setup.
TSW rims
19x8
225/35R19
5x100
48 offset
I'm running stock everything and have no plans to change.
Does anyone know if the wheels/tires will fit and not rub and how far they'll stick out? I think they'll fit properly and whatnot, but looking for some help.
Any advice is appreciated...thank you.
JR007 is offline   Reply With Quote
Old 03-14-2014, 11:07 AM   #2
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
Lots of people on here think 19's are too big for this car. I'm running 18's and think they fit the car perfectly, although I was seriously considering 19's all the way up to the end. For me the determining factor was performance and ride quality. The 19's will be heavier than 18's, so acceleration and handling will be reduced the heavier your wheels are (abet not drastically worse). And ride quality will be harsher with 35 series tires. Lastly, your car likely will look 4x4 running 19's on stock ride height.
With that said, if you're still set on 19's, because some look really good on this car...I wouldn't get 19x8 +48 wheels, as they'll be sunk into the wheel well too much. You can use this guide to determine what width/offset will provide a more aesthetically flush fitment.
http://www.ft86club.com/forums/showthread.php?t=7535
Flush Wheel Offset Chart
Code:
WHEEL   |-- STOCK HEIGHT --|  |-- LOWERED 1" --|
WIDTH      FRONT     REAR       FRONT     REAR
8.0        +38       +31        +36       +26
Build Thread: Breaking-Bad SWP Build
OFFICIAL NM.FT86CLUB Facebook Page
mwjcyber is offline   Reply With Quote
The Following 2 Users Say Thank You to mwjcyber For This Useful Post:
JR007 (03-14-2014), lantsalot (09-03-2014)
Old 03-14-2014, 11:46 AM   #3
JR007
JR007's Avatar
Code:
8.0        +38       +31        +36       +26
Wow, thanks a lot for the very helpful advice...I really appreciate it!
Old 03-14-2014, 12:35 PM   #4
FunCon5
FunCon5's Avatar
I'd look at +40 or +35 offset. Also the MPSS is available in 235/30/19. There is a yokohama and pirelli available in 245/30/19. Both sizes are closer to stock than the 225/35/19, which is the most common (affordable) size.
Personally, I feel suspension changes ride quality more than low pro tires. Though it is easier to bend a wheel with lower profile tires. I looked at 19's, but feel that 18's provide better tire selection, weight, and a thicker sidewall for all the potholes in my area.
FunCon5 is offline   Reply With Quote
The Following User Says Thank You to FunCon5 For This Useful Post:
JR007 (03-14-2014)
Old 03-14-2014, 02:12 PM   #5
mrha
#1819
mrha's Avatar
Drives: Lightning Red Subaru BRZ
I have 19x8 +49 on 225/35/19 tires. They fit fine and give the car a finished look.
mrha is offline   Reply With Quote
The Following User Says Thank You to mrha For This Useful Post:
JR007 (03-14-2014)
Old 03-14-2014, 02:23 PM   #6
Jerf
Jerf's Avatar
Drives: 2013 FR-S 10 Series
Here is my 10 on Vossen 19's before I changed the suspension.
And here is after
Jerf is offline   Reply With Quote
The Following User Says Thank You to Jerf For This Useful Post:
JR007 (03-14-2014)
Old 03-14-2014, 03:06 PM   #7
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Teach a man to fish...
Forget the diameter of the wheel, as long as the tire diameter is close to stock, no issues there. It just means the sidewall is shorter. It's all about width (that's what she said).
You're looking into a wheel that's the same offset as stock, but one inch wider. Let's convert that to 25.4 mm real quick. So, since the offset line is a fixed distance from center, you can add half of that 25.4 to each side (so that the centerline does not change). Now you can go out to the car and measure 12.7mm on the inside and outside of your stock wheel and see if it would rub anywhere (it won't), and see how far it sticks out (it doesn't).
Or...just look up any of the billion threads of people running 17x8 or 18x8 +48 wheels with 225 tires. Again, if you just ignore the diameter and focus on width/offset, it's all the same for comparing how they fit.
Hope that helps for future planning/measuring.
FWIW, I would shoot for a lower offset. An 8" wheel with +48 offset is still very tucked. Going to a +40 is only 8mm difference...that's barely over 1/2". And since you're going with 19s, I'd go wider but that's just my opinion. My 17x8 +48 5Zigens are spaced +22 and +23 F/R. That math means +26 F and +25 R effective offsets. I'm lowered on RCE Yellow springs and am not close to rubbing anywhere with 225/45 MPSS. The only thing I don't like is how narrow the wheels/tires are combined with that much spacer (which I needed to clear stock studs).
Sorry if the maths get confusing, but I find it's easier to just break down the numbers. Looking at all the mix of metric/US is funky, but when you really look at it, you can see that what seems like a big change might only be a fraction of an inch here or there.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
The Following User Says Thank You to 2point0 For This Useful Post:
JR007 (03-14-2014)
Old 03-14-2014, 04:25 PM   #8
JR007
JR007's Avatar
i didn't expect so much feedback and i have learned a few tricks too...so thanks a ton everyone!
Old 03-14-2014, 04:44 PM   #9
mrha
#1819
mrha's Avatar
JR007 (03-15-2014)
Old 03-17-2014, 08:46 AM   #10
FRSTRM
Baby LFA
FRSTRM's Avatar
Drives: Baby LFA
Size:  98.6 KBName:  ImageUploadedByTapatalk1395060320.271652.jpg
19x8.5 +45
Lowered on Eibach Pro Kit
FRSTRM is offline   Reply With Quote
The Following 2 Users Say Thank You to FRSTRM For This Useful Post:
JR007 (03-17-2014), mwjcyber (09-02-2014)
Old 09-02-2014, 01:43 PM   #11
kiloGT86
Drives: 2014 Toyota 86 GTX
Originally Posted by FRSTRM View Post
Attachment 70939Attachment 70940
19x8.5 +45
Beauty! which wheels are those?
Also, how's the ride quality? I'm thinking about installing 19s on mine and that's my only concern.
kiloGT86 is offline   Reply With Quote
Old 09-02-2014, 06:15 PM   #12
FRSTRM
Baby LFA
FRSTRM's Avatar
Drives: Baby LFA
Hey, those were the Five Axis S7:F or SF:7 - something like that. Ride quality was fine, since the tires were thinner bumps were slightly more noticable, and the power starting from 0 is a little bogged down, but again, barely noticeable. If you're getting 19s you care more about the looks than the ride quality anyway. BUT, like I said, really not much of a problem and I'd do it again.
I've owned 17s 18s and 19s with various tire sizes and suspension setups.
The Following User Says Thank You to FRSTRM For This Useful Post:
mwjcyber (09-05-2014)
Old 09-03-2014, 02:45 PM   #13
kiloGT86
Thumbs up
thank u!
Old 12-01-2014, 08:17 AM   #14
MadeInSweden
Drives: Nissan GT-R
Good thread! I have 19x8.5 ET30 laying around. Would this fit my GT86 with 245/30-19 all around?
Nurburgring 07:42 BTG
MadeInSweden is offline   Reply With Quote
Has anyone ever shoved 4 16" wheels and tires into their car? BRZZZZZZZZZZ BRZ First-Gen (2012+) — General Topics 28 02-15-2014 12:55 AM
Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! stratodyne Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-17-2013 02:21 PM
19" Five AD R5:F wheels and tires for sale xcon Wheels and Tires 7 06-18-2013 07:10 PM
WTB: OEM 16" wheels/tires or similar 16" skinny alloy wheels (USA, CA) smmmurf Wheels and Tires 0 04-05-2013 12:42 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
