#1373 |
Drives: GT86
#1374 | |
Drives: 14 FRS Whiteout
except i hate having wires all over the dash
![]() how is the sound quality on the ca-fi head unit on upgrades speakers? where do you guys buy yours? directly from ca-fi website? any other vendor carries it for cheaper? Quote:
#1375 | |
SLO NO MO
I use stock speakers, but with a 100-watt powered sub in the trunk, sounds decent. Not gonna win any awards, but it's good enough for me. Ca-Fi is the only vendor, unfortunately. |
#1376 |
Drives: 2016 Cadillac CTS
If you have an iPhone 5 or 5S, you need Apple's $30 adapter (30 pin dock to Lightning) to listen to music with your phone plugged in. It also does a pretty long indexing procedure when you plug it in. Bluetooth is way easier/cheaper.
#1377 | |
There is no way to wire it to work with the oem USB connectors? I don't like to use Bluetooth becuase of the decrease in audio quality... |
#1378 |
Drives: Hyundai ix45
Part of owning Apple devices is that you're willing to sacrifice compatibility with way too many industry standards, such as USB connectivity to your stereo.
| The Following User Says Thank You to Orisai For This Useful Post: | DC2R (09-03-2014) |
#1379 |
Drives: 2014 Scion FR-S
Some results I'd like to contribute:
Freezing car home completely(including using the car home button disabled update) requires you run radio app before going to sleep in order to wake-up properly instead of cold boot. To work around this leave car home unfrozen and install home 2 shortcut from play store. Assign home button to the launcher of your choice via home 2 shortcut. Sent from my SM-N900T using Tapatalk |
#1380 | |
Drives: '13 Subaru BRZ, '06 Toyota 4Runner
#1381 |
Did you also freeze car home?
#1382 | |
Drives: Pegasus GTS86
Did you have any luck getting this to work? I'm having the same problem. Cheers. |
#1383 |
No, not working. I'm waiting for DashCommand to update so my USB would work with it. Torque is not interested in fixing this issue.
#1384 |
Drives: GT 86
I'm using Dashcommand and Torque with the OBD Link SX adapter without problems.
Maybe you could try the ODBLink app first to see whether its working? Torque needs some special settings. I can have a look later. Dashcommand did work out of the box. |
#1385 |
I tried ODBlink and it worked fine. No luck with either Torque or Dash Command.
If you have some setting that we could try it would be awesome. Thanks. |
#1386 |
Drives: GT86
I had Dashcommand before via my bluetooth unit but now it wont detect it
| REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo | SHIFTER | Electronics | Audio | NAV | Infotainment | 16 | 06-13-2017 06:23 PM |
| Android, bluetooth, Music, and the FR-S stock pioneer stereo | JayNutter | Electronics | Audio | NAV | Infotainment | 27 | 12-18-2014 03:54 AM |
| How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 | SHIFTER | Electronics | Audio | NAV | Infotainment | 29 | 04-07-2014 04:58 AM |
