Old 09-01-2014, 03:28 AM   #1373
BlkR
Drives: GT86
Originally Posted by FrSnake View Post
I really like Waze and would prefer to use it, so if it works offline this HU will be mine. I really like everything about it so far.
Waze works offline no problems, I think I dislike Tomtom cos it needs 3xxmb of space for the australian maps, better to use Waze
BlkR is offline   Reply With Quote
Old 09-01-2014, 06:09 PM   #1374
nyfries
Drives: 14 FRS Whiteout
except i hate having wires all over the dash
how is the sound quality on the ca-fi head unit on upgrades speakers?
where do you guys buy yours? directly from ca-fi website? any other vendor carries it for cheaper?
Originally Posted by Foobar View Post
I plug one of these in to the console power outlet, powerful enough to charge my N5 at AC charging rates. Amazon.com: SCOSCHE USBC242M 12 Watt USB Car Charger for iPhone/iPad/iPod Lightning/Micro - Retail Packaging - Black: Cell Phones & Accessories
nyfries is offline   Reply With Quote
Old 09-01-2014, 09:00 PM   #1375
Foobar
SLO NO MO
Foobar's Avatar
Same amount of wires, mine are just in the center console now where the cupholders are, which takes them even further out of the way. Yours are plugged into the console below the headunit in front of the gear shifter, that's more in the way.
I use stock speakers, but with a 100-watt powered sub in the trunk, sounds decent. Not gonna win any awards, but it's good enough for me.
Ca-Fi is the only vendor, unfortunately.
Old 09-02-2014, 01:09 PM   #1376
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Can I still plug my iPhone in to listen to music on it?
If you have an iPhone 5 or 5S, you need Apple's $30 adapter (30 pin dock to Lightning) to listen to music with your phone plugged in. It also does a pretty long indexing procedure when you plug it in. Bluetooth is way easier/cheaper.
Prog is offline   Reply With Quote
Old 09-02-2014, 02:57 PM   #1377
nyfries
There is no way to wire it to work with the oem USB connectors? I don't like to use Bluetooth becuase of the decrease in audio quality...
Old 09-03-2014, 01:00 AM   #1378
Orisai
Drives: Hyundai ix45
Part of owning Apple devices is that you're willing to sacrifice compatibility with way too many industry standards, such as USB connectivity to your stereo.
Orisai is offline   Reply With Quote
The Following User Says Thank You to Orisai For This Useful Post:
DC2R (09-03-2014)
Old 09-03-2014, 01:13 PM   #1379
DC2R
Drives: 2014 Scion FR-S
Some results I'd like to contribute:
Freezing car home completely(including using the car home button disabled update) requires you run radio app before going to sleep in order to wake-up properly instead of cold boot.
To work around this leave car home unfrozen and install home 2 shortcut from play store.
Assign home button to the launcher of your choice via home 2 shortcut.
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 09-03-2014, 08:27 PM   #1380
SilverlightPony
SilverlightPony's Avatar
Drives: '13 Subaru BRZ, '06 Toyota 4Runner
I'm running the no-CarHome update firmware on mine, and I have not had this problem.
SilverlightPony is offline   Reply With Quote
Old 09-03-2014, 11:38 PM   #1381
DC2R
Did you also freeze car home?
Old 09-04-2014, 01:56 AM   #1382
Bigmaxy
Drives: Pegasus GTS86
Originally Posted by DriftEm View Post
I'm having problem with Torque and USB, I plug in USB dongle and torque starts but when I go to select USB device, it says no recognized device detected, I'm using a OBDLINK SX. Any ideas?
Hi DriftEm.
Did you have any luck getting this to work? I'm having the same problem.
Cheers.
Bigmaxy is offline   Reply With Quote
Old 09-04-2014, 02:04 AM   #1383
DriftEm
DriftEm's Avatar
Originally Posted by Bigmaxy View Post
Hi DriftEm.
Cheers.
No, not working. I'm waiting for DashCommand to update so my USB would work with it. Torque is not interested in fixing this issue.
DriftEm is offline   Reply With Quote
Old 09-04-2014, 02:23 AM   #1384
E1c
Drives: GT 86
I'm using Dashcommand and Torque with the OBD Link SX adapter without problems.
Maybe you could try the ODBLink app first to see whether its working?
Torque needs some special settings. I can have a look later.
Dashcommand did work out of the box.
E1c is offline   Reply With Quote
Old 09-04-2014, 03:47 AM   #1385
Bigmaxy
I tried ODBlink and it worked fine. No luck with either Torque or Dash Command.
If you have some setting that we could try it would be awesome.
Thanks.
Old 09-04-2014, 03:49 AM   #1386
BlkR
Drives: GT86
I had Dashcommand before via my bluetooth unit but now it wont detect it
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
