Old 08-15-2014, 11:09 PM   #659
Casey10s
Casey10s's Avatar
Drives: 2013 white limited BRZ
Originally Posted by BrianBlueBRZ View Post
How does this kit installed guys? is it a perfect fit or is anyone running int fitment problems and also what kind of wheel horsepower are you expected to get with the complete kit and the factory tune.. Also what kind of power can this motor be put through reliably?? I don't know what these Motors are capable of but it's the same motor in the WRx and if I am correct does that mean we could handle that power also or are there internals different
Too bad you are on the other side of the state. You could see mine. I did a conservative tune and I am seeing 220 whp up from 148 whp stock. I also had an Invidia Q300 with down pipe installed. Car really runs on 93 octane that we have in Pa. Really clean install.
Casey10s is offline   Reply With Quote
The Following 3 Users Say Thank You to Casey10s For This Useful Post:
*LongFella (08-15-2014), CSG Mike (08-15-2014), TONYpepperon1 (09-01-2014)
Old 08-15-2014, 11:43 PM   #660
CSG Mike
CSG Mike's Avatar
Extrapolating, that would mean...
148whp / 197 hp ~~ 25% drivetrain loss
220whp with ~25% drivetrain loss ~~293hp at the crank
*LongFella (08-15-2014), Avo1789 (08-25-2014)
Old 08-17-2014, 03:18 PM   #661
Sirsimon
Sirsimon's Avatar
Drives: 2021 GR Supra A91 Edition
Hey all,
How much power is left on the table if I go FI but leave my stock overpipe and front pipe?
I'll be going that direction initially, as I would rather spend the $ on an oil cooler. If I get an over/front pipe later (and retune as necessary), am I likely to gain much?
I already have a JDL UEL header (cat less).
Thanks for your advice,
Sirsimon is offline   Reply With Quote
Old 08-19-2014, 07:49 AM   #662
puma
crew chief
puma's Avatar
Drives: Race car FR-S
Anyone knows if it fits with the AC delete kit made in Japan?
puma is offline   Reply With Quote
Old 08-19-2014, 09:22 AM   #663
AJPG
Drives: 22RE, FA20, 4G63
Originally Posted by Sirsimon View Post
Hey all,
Completely agree oil cooler first!
As for the exhaust, the more power you gain, the louder it gets. Mine have header and cat delete 60whp more at top (also new tune, so...) and +45whp from 4k. I like the sound
AJPG is offline   Reply With Quote
Old 08-22-2014, 09:33 PM   #664
Sirsimon
Sirsimon's Avatar
Thanks. I decided to throw a combo pipe on during the SC install. :-)
DJ
Old 09-01-2014, 09:42 PM   #665
TONYpepperon1
TONYpepperon1's Avatar
Drives: 2013 CBS BRZ
When you say conservative tune, are you reffering to the OTS tune that it comes with or you had it custom tuned? If you say custom tuned, can more power be expected from the OTS tune?
TONYpepperon1 is offline   Reply With Quote
Old 09-01-2014, 09:54 PM   #666
CSG Mike
CSG Mike's Avatar
With zero other supporting mods? Maybe 10 hp, with an aggressive tune.
Old 09-01-2014, 10:47 PM   #667
TONYpepperon1
Well just a catback... I thought this kit produced numbers a little higher. These seem pretty close to those of the innovative kit.
Old 09-02-2014, 01:20 AM   #668
CSG David
CSG David's Avatar
Delta is more important than absolute numbers. Absolute high numbers mean nothing if it can't be performed consistently with zero cool down time.
Also if you want dynos that put out high wheel horsepower values, that can be arranged too.
Old 09-02-2014, 02:26 AM   #669
Yui-Chan
Drives: Toyota
Is this really possible from adding header, fp, exh and new tune?? Have any dynos?
Drift Office got 280 with a full catless system and their tuning (and they're some of the best from what I've read). And CSG got 245 from the OTS CARB tune. Both dynojet. That's +35whp gain.
+65 (or even +45) sounds very high and hard to do. Unless you change the pulley or maybe use E85.
Yui-Chan is offline   Reply With Quote
Old 09-02-2014, 03:20 AM   #670
CSG David
CSG David's Avatar
Every dyno is different. The delta on the particular dyno you are using is more important than the numbers off of someone else's dyno.
Old 09-02-2014, 07:06 PM   #671
Suddenly...
Suddenly...'s Avatar
Drives: 2013 High AT
I just need to post and thank Mike at CSG for all his help. Hopefully I will be going with the JRSC kit sometime soon and Mike has given me a wealth of information regarding my needs. Thanks Mike, you sir, deserve a beer
Suddenly... is offline   Reply With Quote
Old 09-02-2014, 10:03 PM   #672
TONYpepperon1
How does this kit hold up in the cold winter conditions? I live in NJ and we've had some very cold very snowy winters lately (storm sandy). The car is my DD through the winter
jackson racing, jrsc, rotrex, supercharger, track
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
HKS GT Supercharger (Rotrex) in development! madfast Engine, Exhaust, Transmission 206 12-14-2012 04:28 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 03:29 PM
