Old 04-26-2012, 05:35 AM   #1
theaero
Drives: 2008 GSX-R600
How strong is tranny?
Is it going to be anything like the STI's 6 speed? Thanks for the info.
theaero is offline   Reply With Quote
Old 04-26-2012, 09:51 AM   #2
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
The az6 is capable of being plenty strong but it depends on what they specified for its internals. Not enough info yet to provide a solid answer.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-26-2012, 10:25 AM   #3
brianc
OCD
brianc's Avatar
We don't know for sure yet but from what we know so far, it should be a decent transmission. You can see what other cars use the AZ6, they all hold power and abuse well.
brianc is offline   Reply With Quote
Old 04-26-2012, 02:12 PM   #4
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
the az6 is 80% different than the s2000's az6, so really its up in the air, we can only believe its stronger
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 04-26-2012, 02:57 PM   #5
KaliKev
FT86 News Addict
KaliKev's Avatar
Drives: Toyota FJ
Not sure but she used to be a man...
KaliKev is offline   Reply With Quote
The Following 3 Users Say Thank You to KaliKev For This Useful Post:
Alias (04-27-2012), civicdrivr (04-28-2012), Guff (04-27-2012)
Old 04-26-2012, 05:23 PM   #6
carbonBLUE
Reverse Burnouts
look up is250 automatic transmissions, the A960E automatic is pretty reliable at stock power levels, not sure on what they can withstand, usually they can be reliable up to double the stock tq
for the manual (i keep seeing this transmission code pop up in the last few days ra62 and AZ6 transmission codes)
the RA62 was designed to be put in the tacoma and the fj cruiser(rwd versions), also it was designed around the supercharged versions of both cars, so its good to over 330lb-ft
so both transmissions should hold about 400 hp reliably for a while at least, as the car progresses we will see people break stuff and we will learn what exactly broke and what needed to be replaced to increase the maximum load of the transmissions
manual should be pretty bullet proof designed for a 330lb-ft engine on a 2 ton fj cruiser
that same transmission is going to be in a 2700lb car, so i could imagine higher torque capabilities
(wont forget you)
2011 Infiniti G37x
Old 04-26-2012, 11:04 PM   #7
fatoni
tranny strong...hulk no smash
Old 04-26-2012, 11:18 PM   #8
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
This is somewhat of an aside, but pertinent enough if we're going to start looking at how much power each transmission can handle. Kaizen Factor says that the transmission in the 86 coupes is not the RA62, but in fact the TL70, sharing a resemblance to the Aisin AZ6. The AZ6 should serve as a starting point for determining how much the 86's transmission can handle, but even then, it's assuredly been modified to the point that we won't be able to know anything with certainty until either someone more knowledgeable chimes in or someone breaks one.
Subie is offline   Reply With Quote
The Following User Says Thank You to Subie For This Useful Post:
jruhi4 (04-27-2012)
Old 04-27-2012, 12:24 AM   #9
serialk11r
Drives: '06 AM V8V Coupe
Interesting article, I hadn't seen that before. However the article failed to point out that the ratios appear to be exactly the same as on the S15... which I think is an important bit.
Old 04-27-2012, 12:46 AM   #10
carbonBLUE
Reverse Burnouts
the info is very mixed for the tannys going into the 86, just dug this up
Transmission Type TL70
Engine Type FA20
Gear Ratio 1st 3.626
2nd 2.188
3rd 1.541
4th 1.213
5th 1.000
6th 0.767
Reverse 3.437
Oil Capacity Liters (US qts, Imp.qts) 2.2 (2.3, 1.9)
Oil Viscosity SAE 75W-90
Oil Grade API GL-3
Weight (Reference)* kg (lb) 42.9 (94.58)
but at the same time
and also read this
(wont forget you)
2011 Infiniti G37x
The Following User Says Thank You to carbonBLUE For This Useful Post:
jruhi4 (04-27-2012)
Old 04-27-2012, 01:04 AM   #11
KeepGuessing
Drives: e30 150 deville etc etc
HKS offers a "6 speed Transmission upgrade from the Silvia S15"....The silvia S15's transmission was notoriously fragile....There's your indication..
KeepGuessing is offline   Reply With Quote
Old 04-27-2012, 01:07 AM   #12
86'd
86'd's Avatar
Drives: 2012 WRX Sedan
Engine Type FA20
2nd 2.188
3rd 1.541
4th 1.213
5th 1.000
6th 0.767
Reverse 3.437
Oil Grade API GL-3
and also read this
^ This is crazy.
I mean I wouldn't have thought it would have taken that much effort to create good shift feel.
You'd think they'd start with an AZ6, but it sounds like they started with a J160 went to replacing 80% of an RA62 to make it feel like an AZ6. Which should be called a TL70.
LOL.
86'd is offline   Reply With Quote
Old 04-27-2012, 01:10 AM   #13
(Stealth Inc.)
Drives: slow
we won't know how strong the tranny is until we get our hands on one and use it, that goes for transmissions too.
(Stealth Inc.) is offline   Reply With Quote
Old 04-27-2012, 01:24 AM   #14
#87
I usually post drunk
#87's Avatar
Originally Posted by (Stealth Inc.) View Post
we won't know how strong the tranny is until we get our hands on one and abuse it, that goes for transmissions too.
Fixed
#87 is offline   Reply With Quote
Australia - Confirmed Details & Strong Rumours Netrosis AUSTRALIA 81 05-22-2012 11:22 PM
MT vs AT tranny... better MPG, 0-60? subatoy BRZ First-Gen (2012+) — General Topics 163 03-26-2012 07:08 PM
Manual tranny takes another step into oblivion madfast Other Vehicles & General Automotive Discussions 76 03-06-2012 10:40 PM
name that tranny! (updated: AZ6 transmission from FR-S/BRZ/GT86) carbonBLUE Engine, Exhaust, Transmission 14 12-19-2011 05:00 AM
