Old 08-31-2014, 02:07 PM   #1
b1gb2olo
b1gb2olo's Avatar
Drives: 2014 BRZ A/T Limited
Pa inspection and Catless Header
I was going to buy Open Flash Header, but im worried I will fail my yearly inspections
I live in PA by Pittsburgh
Anyone from the area have any advice?
PA does OBD sensors ...
What will I have to do to pass?
Also is Catless that much more power than catted.. Im using OFT also
b1gb2olo is offline   Reply With Quote
Old 09-05-2014, 08:38 PM   #2
jflogerzi
jflogerzi's Avatar
Catless vs catted on a na car will make zero difference. Problem is finding a quality catted header. What type of emissions testing do they do? Sniffer or visual?
2013 Series 10 FRS #553
Old 12-05-2015, 07:38 AM   #3
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
For future reference in this thread (because I found it on google) In PA they require a Visual Inspection, Gas Cap check and OBD-II check, a tune will trick the OBD-II check and the gas cap check would pass anyway. As for visual inspection check here if your county requires it: http://www.drivecleanpa.state.pa.us/
In my case the car is so new a visual inspection is not required but most likely will be done anyway. Leaving the secondary cat and not taking it to a Toyota or Subaru dealer but rather another mechanic could bypass that.
Old 12-06-2015, 06:01 PM   #4
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
As a former PA resident:
As long as your OFT prevents the CEL, you're good to go provided that you do NOT take your car to the dealership for inspection. They're immensely more likely to actually check for the cat in the header. I usually just got to a psuedo performance shop that has an inspection license.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
The Following User Says Thank You to Laika For This Useful Post:
FRSBRZGT86FAN (12-06-2015)
Old 12-06-2015, 11:27 PM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
I sometimes think that in ideal world for all parties to be happy there simply should be some reasonable extra tax for such mods/to legalize them. Even with just one cat left, exhaust is cleaner then for some cars of not that distant past. If car will dump slightly dirtier exhaust gases vs stock that has specific taxes depending on what exhaust standards it was certified to fullfill, owner simply should pay a bit more .. but be legal without any need to fool dealership/cops/inspections. But as of now, enthusiasts will keep moding, State will keep fighting that. Given my lack of trust in common sense of humanity or polititians, it will stay this way .. maybe even will get worse for us in future :/. "Green" is powerful populistic way to easily gain votes, just like "fight" against alcohol/smokers. Hence it WILL be used, no matter how much sense in some cases pursuing it makes or not and if other areas of impacting environment are even more of polluters then car is.
Old 12-06-2015, 11:42 PM   #6
FRSBRZGT86FAN
This is important as well, but most dealership techs are too lazy to go an open up that panel I feel. In bucks county where I live at least only an OBD-II check and Gas Cap check are required....
Old 12-09-2015, 02:15 PM   #7
Lebby83
Drives: 2019 BRZ, 2016 Touareg
Good to know from a fellow Bucks County resident.
Rob
2019 BRZ Limited Sport
2016 VW Touareg TDI
Lebby83 is offline   Reply With Quote
The Following User Says Thank You to Lebby83 For This Useful Post:
FRSBRZGT86FAN (12-09-2015)
Top Speed Pro-1 Catless Header GA_Dave Engine, Exhaust, Transmission 6 07-27-2014 09:56 AM
no cel after catless header install vestal52 Engine, Exhaust, Transmission 14 05-22-2014 02:21 AM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
EJ20R 2.5" OEM Catless Header... On a FRZ? Kostamojen Engine, Exhaust, Transmission 0 09-21-2013 03:00 AM
SRT header back exhaust catless w/ tip A serial gixxer Engine, Exhaust, Bolt-Ons 6 12-04-2012 11:00 PM
