Old 08-30-2014, 09:55 PM   #43
Poodles
Drives: 2015 Series.Blue
Originally Posted by wparsons View Post
At least with the KW kit if the belt snaps you aren't stranded. With the JR kit you're dead in the water if the belt snaps.
Same as any serpentine belt. Given that it's not happened to anyone yet, it's a moot point.
Unlike Vortech and their idler pulleys and wearing on the piping, or KW with their hard to find toothed belt that has snapped...
Poodles is offline
The Following User Says Thank You to Poodles For This Useful Post:
Yui-Chan (08-31-2014)
Old 08-31-2014, 04:57 AM   #44
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
The JR kit is the only one where nobody has broken a belt. To me that means nothing other than: it hasn't happened YET or we haven't heard about it.
It could possibly mean that jackson racing is the only shop capable of putting together a proper supercharger kit, but you'd have to be high as a kite (or work for CSG) to believe that shit.
Sellout is offline
Old 08-31-2014, 07:19 PM   #45
Poodles
And when it does, I can walk into a local O'Reilly autoparts and buy a replacement belt.
Your point?
Poodles is offline
Old 08-31-2014, 07:29 PM   #46
Sellout
Mr. Cranky Pants
Sellout's Avatar
Your point?
Simply trying to illustrate that a broken belt isn't much of a statement about the kit. Belts are going to break. You can tow your shit home and change the belt or walk to O'reilly and then change the belt on the side of the road, the KW owner can keep a spare in the garage and swap it after driving the car home.
Sellout is offline
Old 08-31-2014, 08:56 PM   #47
Foobar
SLO NO MO
Foobar's Avatar
Not to mention the datapoint of plenty other SC owners out there who have never snapped belts. I'm willing to bet that the reports of snapped belts on this forum make up a vocal minority of SC owners.
Foobar is offline
Old 08-31-2014, 09:06 PM   #48
Yui-Chan
Drives: Toyota
Does the JR kit use a standard and easily found belt (maybe from another application, car or easily available size) available at any auto store? If yes, then it doesn't matter since it's easily available.
Belts breaking is inevitable for any oem car or aftermarket kit. It's a wear and tear problem. If it gets old, obviously, you should replace it. Broken belts shouldn't be due to a supercharger kit's quality (unless something is really out of whack and really misaligned or too tight).
As for that special toothed KW belt...that is a disadvantage if it's a special order item and not found at a regular auto store.
It's always best if a company can utilize oem parts on wear and tear or damage prone parts for easy repair.
Yui-Chan is offline
Old 09-01-2014, 02:16 AM   #49
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
put one spare belt in your trunk with the needed tool and you are safe any time
Mars2 is offline
Old 09-01-2014, 02:38 AM   #50
CSG Mike
CSG Mike's Avatar
Both Rotrex kits require removal of the Supercharger to replace the belt.
It's just 3 (2x 12mm and 1x 14mm) bolts for the Jackson Racing kit, plus the OEM Tensioner (14mm).
I'm unsure with the Kraftwerks kit, as I've not actually read the manual... does anyone happen to have a link to an electronic copy?
CSG Mike is offline
Old 09-01-2014, 10:15 AM   #51
DJCarbine
Thupercharged
DJCarbine's Avatar
Vortech belt replacement also requires removal of the supercharger unit. You can do it be loosening the supercharger and sliding it out of the way if you want, but its just quicker to remove the unit (handful of 14mm bolts).
My belt broke once when I was using the wrong size belt (too tight), but has been fine with a gatorback belt for thousands of miles with no sign of wear. Even the gates belt that you get with the kit left a lot of rubber dust on the charge pipes (rubber dust = wear), but the gatorback has been the best belt I've had on so far.
You really don't want to have to plan for a belt breakage, but its a good idea to keep a spare belt and the required tools in the trunk.
It would also be a good idea to get a laser alignment tool (~$100) made for pulley alignment, as I still believe that to be the number one cause of belt failures especially if it is constantly a single rib that gets shredded. Would not be surprised to see the belt walking off a smooth idler pulley a rib or so when under stress if there is any wobble/play in an idler pulley.
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline
The Following User Says Thank You to DJCarbine For This Useful Post:
CSG Mike (09-01-2014)
Old 09-03-2014, 11:58 AM   #52
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
Sub'd
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline
Old 09-03-2014, 05:58 PM   #53
Yui-Chan
Drives: Toyota
Since this is my thread (hehe), we haven't addressed my other question yet:
"Cayman killer?"
Is a JRSC'ed 86 (let's say just modestly/lightly modified with good coilovers, wheels & sticky tires and AP Sprint kit, just to make it decent on the track) as good as a stock Cayman S or base 996 around the track, if not maybe even better?
Yui-Chan is offline
Old 09-03-2014, 06:01 PM   #54
CSG David
CSG David's Avatar
"Cayman killer?"
Is a JRSC'ed 86 (let's say just modestly moddified with good coilovers, wheels & sticky tires and ap sprint kit, just to make it decent on the track) as good as a stock Cayman S or base 996 around the track, if not maybe even better?
Here's our little fun video using a client's FRS that had the same exact setup as our CSG BRZ before the FI days. Stock power, TEIN SRCs, 225 RS3s on 17x9 TC105Ns, and Essex AP Sprint kit, and Project Mu 999 F/R brake pads. Power isn't everything. Proper setup and proper driving gets you there...unless you're driving on ACS which is a pure power track...
[ame="https://www.youtube.com/watch?v=HCWz5ymLKrI"]Scion FRS vs Porsche GT3 86Fest II - YouTube[/ame]
CSG David is offline
The Following 4 Users Say Thank You to CSG David For This Useful Post:
juliog (09-03-2014), number1Tango (09-12-2014), tahdizzle (09-03-2014), Yui-Chan (09-03-2014)
Old 09-03-2014, 06:48 PM   #55
Yui-Chan
Drives: Toyota
Yes, obviously. Many more things come into the equation, and power is only just a small part of the whole picture.
But we're specifically discussing the JRSC and its' benefit..and we're in the FI forums too
Yui-Chan is offline
Old 09-03-2014, 06:54 PM   #56
CSG David
CSG David's Avatar
The JRSC kit screws with people on track. A lot of WTF coming from the big power cars. That's all I have to say for now.
The Following 3 Users Say Thank You to CSG David For This Useful Post:
*LongFella (09-03-2014), Sirsimon (09-03-2014), Yui-Chan (09-03-2014)
ModBargains.com | Vortech Supercharger System for FRS/BRZ - 50-State CARB LEGAL!! ModBargains.com Forced Induction 59 01-20-2017 01:22 PM
CARB legal headers? mike_ekim1024 Engine, Exhaust, Transmission 23 05-31-2016 12:14 AM
Any CARB legal turbos on the way yet? Black Knight Forced Induction 3 07-15-2014 07:16 PM
CARB Legal Innovate Motorsports Supercharger Systems now available! Innovate Motorsports Forced Induction 33 12-27-2013 02:39 PM
Carb legal intakes EN2_Squirrel Engine, Exhaust, Transmission 2 04-18-2013 05:59 PM
